I have my proxmox monitoring working fine but when I try to use the proxmox specific agent it does not work. I have local SSL with Traefik so “https://pve1.xxx.xxx.xxx” points to “https://192.168.x.x:8006”.
But even when I change the “port=8006” to “port=443” the agent fail.
[Check_MK]
agent] Success, [special_proxmox_ve] Agent exited with code 1: Caught unhandled ConnectionError(HTTPSConnectionPool(host='pve1.xxx.xxx.xxx', port=8006): Max retries exceeded with url: /api2/json/access/ticket (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f0c6106db50>: Failed to establish a new connection: [Errno -5] No address associated with hostname'))) in /omd/sites/cmk/lib/python3/cmk/special_agents/utils/agent_common.py:135CRIT, execution time 2.0 sec
[Check_MK Discovery]
no unmonitored services found, no vanished services found, no new host labels, [special_proxmox_ve] Agent exited with code 1: Caught unhandled ConnectionError(HTTPSConnectionPool(host='pve1.xxx.xxx.xxx', port=8006): Max retries exceeded with url: /api2/json/access/ticket (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f2709d3ff10>: Failed to establish a new connection: [Errno -5] No address associated with hostname'))) in /omd/sites/cmk/lib/python3/cmk/special_agents/utils/agent_common.py:135CRIT```
**CMK version:**
Free (trial)
**OS version:**
Docker
**Error message:**
See above
**Output of “cmk --debug -vvn hostname”:** (If it is a problem with checks or plugins)
Command does not work
