Hello guys
i just installed the last version of checkmk and get trouble around discoring proxmox services.
i have the agent installed, i get cpu ram etc
id’ like to have my nodes discovereed so i try to implement the API of proxmox so i created a rule in : Setup Agents [VM, Cloud, Container] [Proxmox VE]
i provided a pve user / password to this rule but the service discovering do not find the proxmox
Do you create the virtual machines as it’s own host objects?
The name needs to be the same as inside Proxmox or you use the piggyback data renaming rule.
But for a first test it would be best to use the same name aus inside Proxmox
These hosts can be configured without SNMP and without agent.
It should show these services then
Andreas is right. But
“can be configured without SNMP and without agent” to get just the services shown in the screenshot above. But installing the agent additionally will give much more insights.
i tried to let it discover the child nodes. but my error seems to be a problem around authentification, right ? The name of the node is exactly the same and no relation discovered.
I would start debugging on the command line in this case.
Run cmk -D HOSTNAME for one of your Proxmox hosts. It shows the commandline for the Proxmox special agent under “Type of agent:”. You can add --verbose and --debug to its arguments and start it to see what is happening.
The Proxmox special agent generates piggyback data for nodes and VMs. You can use this data (in CEE) with the dynamic host configuration to automatically create host entries in the checkmk configuration.
