Sorry another question. I’m currently running 2.2 Raw edition on Docker.
I’ve configured a number of Proxmox hosts by installing the usual Checkmk Linux Monitoring Agent, that works fine.
I’m now attempting to get the special agent working. I’ve followed the blog post by Alexander Wilms.
I’ve attached a screenshot showing most services show ok, but am getting a “[piggyback] Missing data” error.
I’ve downloaded the “agent output”, and at the bottom of that log it has “<<<proxmox_ve_node_info:sep(0)>>>” with the VMs and other info listed under it.
If I download that log on another Proxmox host (without the special agent config), it doesn’t have that additional info at the bottom.
Would that indicate that the special agent is communicating with the first Proxmox host successfully, and if so, any idea why am getting the piggyback data error?
I have watched that video several times and I cannot get the part where he is adding the VM guest on it. After I add the “Proxmox VE” check to my Proxmox host in CheckMK, I then try adding another host in CheckMK using just the name of the VM, but when I try to do s Service Discovery. it gives an error saying it couldn’t find the DNS name of the host name I am tryin to add.
Yeah, I did see that, and that is what I did. The VM I am trying to ad dis called “Test-Server-1” and that is exactly the name i am putting in CheckMK (including the capitlization)
