hello all,
is there another way to publish views & dashboard like check the button in view-settings “publish to all users”?
I did it this way but doesn´t work.
hello all,
after little bit testing, i found a strange behavior when try to publish views to all users.
expected: create view, set to publish to all users, save and slave site user could see the new view
But what i get: new created views are only available for slave site user, after i change the user role to a different role and back…
What did i wrong? Anyone else same issue?
Version: RAW
PL: 1.6.0p9
Setup: distributed
I think the slave site user should also see your changed view after the next config push.
The role change make a config push in the background but not your creation of a view.
