Push agent in Raw edition?
Is there a way, we can configure or get push agent in Raw edition ?
using the RAW edition normally involes a central config management like ansible. Otherwise it is only a question of time that problems with the configmanagent appear.
The bakery is an enterprise feature.
Ralf
No, the “official” push agent is currently a Cloud Edition only feature.
You can implement something like the official push agent yourself.
We have build a system where a cronjob on the host starts the agent and uploads its output to a webdav share. The monitoring server then reads the file from that share.
That’s basically what I’ve been doing with hosts behind dial-up connections for years. On the host a cronjob that does:
#!/bin/bash
check_mk_agent | ssh me@myserver 'cat > /home/me/agent_output/nas.tmp ; mv /home/me/agent_output/nas.tmp /home/me/agent_output/nas'
On the Checkmk a datasource program that runs:
cat /home/me/agent_output/$HOSTNAME$
Using the same SSH user might be OK for small installations, on larger ones prevent one from overwriting stuff of others.
Hi Nav, I’m using this project for push agent to checkmk.
It’s old, but It works grate for me.
Hope it helps
