CMK version:
2.0.0p19cre
OS version:
Debian 10
I don’t know what is wrong. I have looked at other forms with no luck. And I have succesfully setup notifications using pushover in the past with no issues. But the logs say that it is properlly sending using pushover but it will never come through. I’ve done a curl -X POST command on the server cli and it sends just fine. So I don’t think it has anything to do with connectivity. Any ideas? (Logs below)
2022-02-10 11:27:00,086 [20] [cmk.base.notify] ----------------------------------------------------------------------
2022-02-10 11:27:00,086 [20] [cmk.base.notify] Got raw notification (Septic-Plug) context with 36 variables
2022-02-10 11:27:00,086 [10] [cmk.base.notify] Raw context:
CONTACTEMAIL=
CONTACTNAME=check-mk-notify
CONTACTPAGER=
DATE=2022-02-10
HOSTACKAUTHOR=
HOSTACKCOMMENT=
HOSTADDRESS=10.0.40.22
HOSTALIAS=Septic-Plug
HOSTATTEMPT=1
HOSTCHECKCOMMAND=check-mk-host-ping!-w 200.00,80.00% -c 500.00,100.00%
HOSTDOWNTIME=0
HOSTGROUPNAMES=check_mk
HOSTNAME=Septic-Plug
HOSTNOTIFICATIONNUMBER=1
HOSTOUTPUT=CRITICAL - 10.0.40.22: rta 809.979ms, lost 0%
HOSTPERFDATA=rta=809.979ms;200.000;500.000;0; pl=0%;80;100;; rtmax=981.585ms;;;; rtmin=646.694ms;;;;
HOSTPROBLEMID=490
HOSTSTATE=DOWN
HOSTSTATEID=1
HOSTTAGS=/wato/iot/ auto-piggyback ip-v4 ip-v4-only lan no-agent no-snmp ping prod site:cmk
HOST_ADDRESS_4=10.0.40.22
HOST_ADDRESS_6=
HOST_ADDRESS_FAMILY=4
LASTHOSTSTATE=UP
LASTHOSTSTATECHANGE=1644510418
LASTHOSTSTATEID=0
LASTHOSTUP=1644510357
LONGDATETIME=Thu Feb 10 11:26:58 EST 2022
LONGHOSTOUTPUT=
NOTIFICATIONAUTHOR=
NOTIFICATIONAUTHORALIAS=
NOTIFICATIONAUTHORNAME=
NOTIFICATIONCOMMENT=
NOTIFICATIONTYPE=PROBLEM
SERVICECHECKCOMMAND=$
SHORTDATETIME=2022-02-10 11:26:58
2022-02-10 11:27:00,088 [20] [cmk.base.events] Computed variables:
CONTACTS=
HOSTFORURL=Septic-Plug
HOSTSHORTSTATE=DOWN
HOSTURL=/check_mk/index.py?start_url=view.py%3Fview_name%3Dhoststatus%26host%3DSeptic-Plug%26site%3Dcmk
LASTHOSTSHORTSTATE=UP
LASTHOSTSTATECHANGE_REL=0d 00:00:02
LASTHOSTUP_REL=0d 00:01:03
MICROTIME=1644510420087297
MONITORING_HOST=1ea47fcec3d8
OMD_ROOT=/omd/sites/cmk
OMD_SITE=cmk
PREVIOUSHOSTHARDSHORTSTATE=UP
PREVIOUSHOSTHARDSTATE=UP
WHAT=HOST
2022-02-10 11:27:00,089 [10] [cmk.base.notify] Preparing rule based notifications
2022-02-10 11:27:00,089 [10] [cmk.base.notify] Found 1 user specific rules
2022-02-10 11:27:00,090 [20] [cmk.base.notify] Global rule 'PushOver'...
2022-02-10 11:27:00,090 [20] [cmk.base.notify] -> matches!
2022-02-10 11:27:00,091 [20] [cmk.base.notify] - adding notification of ccasteel, cmkadmin, automation via pushover
2022-02-10 11:27:00,092 [20] [cmk.base.notify] User ccasteel's rule ''...
2022-02-10 11:27:00,092 [20] [cmk.base.notify] -> matches!
2022-02-10 11:27:00,093 [20] [cmk.base.notify] - adding notification of ccasteel via pushover
2022-02-10 11:27:00,093 [20] [cmk.base.notify] Executing 2 notifications:
2022-02-10 11:27:00,093 [20] [cmk.base.notify] * notifying ccasteel via pushover, parameters: api_key, recipient_key, priority, sound, bulk: no
2022-02-10 11:27:00,094 [20] [cmk.base.notify] executing /omd/sites/cmk/share/check_mk/notifications/pushover
