It is possible to give a user permissions only to edit/delete the hosts he created?
Is it possbile to assign permissions (basic settings) to all hosts in a specific folder? And that this permissions persist even when the hosts will be moved to another folder?
Yes, you can set properties in the folder and they will be inherited.
If you use “bulk edit” (aka “Edit attributes on selected hosts” in the Hosts menu) then the properties will be set directly on the host(s) and therefor will also move with the host.
