RabbitMQ monitoring
Hi
I am trying to monitor RabbitMQ queues, but it seems when I add the RabbitMQ service to an already existing host. It seems it’s unable to add the service because there was an empty response from the agent; meaning there was no data contained in the response from the agent that held any information regarding RabbitMQ.
RabbitMQ is running in a docker container but is exposed to the server on the normal ports (5672).
Can it still be monitored or is that my problem?
Can that be solved in anyway?
I had the issue in 1.6 that the plugin was not running in case I use an IP address in the host configuration. I had to use FQDN instead. Íts just a little change in the plugin but I am not sure if the developer did it.
BR
Michael
