RAW 2.4 vmware ESXi SSL error
Root cause was a 3rd party library (urllib3), which was updated for 2.4, where the maintainers removed a lot of ciphers.
We have a solution for this problem to re-add compatibility with older systems.
@genitguy3 and @TomR - would you be willing to test our fix before we release? If so, please send me a PM with your email-address and we will reach out with a patch.
Anyone else who has the same problem can also write me a PM with their email-address.
Hi Martin,
Thanks for that.
My PoC address the issue caused by the changes in urllib3, by using the function create_urllib3_context in the new version of this library, to allow a fine tuning of ciphers that are used during the connection.
Take care,
Tom.
after checking the fix with @TomR and @genitguy3 (thank you!)
  • :white_check_mark: HTTPS / TLS connection is working again. Will likely be public with the next patch release next week.
  • :no_entry: for @TomR there are still VMware related services missing in the overview.
I will open another internal ticket for the missing services.
Hello @TomR,
we’re looking into that part again:
Is that error still reproducible from your side?
Sunny Greetings and thank you
Hartmut
Hi @HartmutLeister,
I’ve upgraded my Checkmk version to 2.4.0p8 in order to make sure, but it’s still the same as in @genitguy3’s comment above (RAW 2.4 vmware ESXi SSL error - #16 by genitguy3). I’ve sent the result of some debug commands to @Hannes (in 2.4.0p7, but I don’t think it changes anything), but I remain available to test some more if needed.
Take care,
Tom.
Regarding the missing services, I took a look a the diff of the agent_vsphere.py file between the two versions, and I found the issue in the --vm_pwr_display part. The default (with was the “right” value for me initially) has been changed (in order to add a new third option), and I simply need to adapt my config to get back all the services, from:
to
Thank you for your time helping me diagnose this issue, you can close the internal ticket about that and sorry for the noise, I should have check the new rule for “VMware ESX via vSphere” more thoroughly.
Take care,
Tom.
