CMK version:
2.4.0 Raw
OS version:
Docker Linux
I’m testing Checkmk Raw with Redfish. I can successfully pull metrics from a Dell iDRAC8, but power usage metrics are not being retrieved.
I’ve checked and data is available via the Redfish API at:
/redfish/v1/Chassis/System.Embedded.1/Power
I’m specifically interested in PowerConsumedWatts.
Anyone know of a solution?
At the moment the check only looks for the values with the following names.
PowerOutputWatts
LastPowerOutputWatts
PowerInputWatts
LineInputVoltage
PowerCapacityWatts
Is there a file i can edit to add the value?
Not so easy, as the data you want resides inside the PowerControl branch of the Power endpoint. The current checks only use the PowerSupply branch.
For this a new check would be good to build that shows the complete power consumption data of your system.
Something like “PowerControl system” as a check name.
