CMK version: Checkmk Enterprise Edition 2.3.0p17
OS version: Debian 12
Error message: Periodic service discovery crashes with “check failed - please submit a crash report!” message
Summary
value store: synchronizing
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/counters/csesx01-ilo
Got lock on /omd/sites/prod/tmp/check_mk/counters/csesx01-ilo
Releasing lock on /omd/sites/prod/tmp/check_mk/counters/csesx01-ilo
Released lock on /omd/sites/prod/tmp/check_mk/counters/csesx01-ilo
Checkmk version 2.3.0p17
+ FETCHING DATA
Source: SourceInfo(hostname='csesx01-ilo', ipaddress='172.22.3.181', ident='special_redfish', fetcher_type=<FetcherType.SPECIAL_AGENT: 6>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f22576cd130]
Read from cache: AgentFileCache(csesx01-ilo, path_template=/omd/sites/prod/tmp/check_mk/data_source_cache/special_redfish/{hostname}, max_age=MaxAge(checking=0, discovery=2700.0, inventory=2700.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 974 sec, allowed is 0 sec)
Calling: /omd/sites/prod/local/lib/python3/cmk/plugins/redfish/libexec/agent_redfish -u checkmk --password-id uuid93cbad9e-849b-438a-afa1-f23159086e22:/omd/sites/prod/var/check_mk/passwords_merged -P https --timeout 20 172.22.3.181
Get data from program
Write data to cache file /omd/sites/prod/tmp/check_mk/data_source_cache/special_redfish/csesx01-ilo
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/data_source_cache/special_redfish/csesx01-ilo
Got lock on /omd/sites/prod/tmp/check_mk/data_source_cache/special_redfish/csesx01-ilo
Releasing lock on /omd/sites/prod/tmp/check_mk/data_source_cache/special_redfish/csesx01-ilo
Released lock on /omd/sites/prod/tmp/check_mk/data_source_cache/special_redfish/csesx01-ilo
[cpu_tracking] Stop [7f22576cd130 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.55, children_system=0.04, elapsed=3.8599999994039536))]
Source: SourceInfo(hostname='csesx01-ilo', ipaddress='172.22.3.181', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
Read from cache: NoCache(csesx01-ilo, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'csesx01-ilo'. Skip processing.
No piggyback files for '172.22.3.181'. Skip processing.
Get piggybacked data
[cpu_tracking] Stop [7f22576cd130 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f22576351c0]
+ PARSE FETCHER RESULTS
<<<check_mk:sep(32)>>> / Transition NOOPParser -> HostSectionParser
<<<redfish_manager:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_system:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_ethernetinterfaces:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_processors:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_memory:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_storage:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_networkinterfaces:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_drives:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_volumes:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_chassis:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_power:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_networkadapters:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<redfish_thermal:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
HostKey(hostname='csesx01-ilo', source_type=<SourceType.HOST: 1>) -> Add sections: ['check_mk', 'redfish_chassis', 'redfish_drives', 'redfish_ethernetinterfaces', 'redfish_manager', 'redfish_memory', 'redfish_networkadapters', 'redfish_networkinterfaces', 'redfish_power', 'redfish_processors', 'redfish_storage', 'redfish_system', 'redfish_thermal', 'redfish_volumes']
HostKey(hostname='csesx01-ilo', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
Perfdata(name='02-CPU 1 PkgTmp', value=54.0, levels_upper=('fixed', (95.0, 95.0)), levels_lower=None, boundaries=(None, None))
Perfdata(name='03-CPU 2 PkgTmp', value=67.0, levels_upper=('fixed', (95.0, 95.0)), levels_lower=None, boundaries=(None, None))
CPU 1 Type: CPU, Model: Intel(R) Xeon(R) Gold 6442Y, Cores: 24, Threads: 48, Speed maximum 4000 MHz
CPU 2 Type: CPU, Model: Intel(R) Xeon(R) Gold 6442Y, Cores: 24, Threads: 48, Speed maximum 4000 MHz
Check_MK Agent Version: 2.0, OS: iLO 6 - 1.63
Drive 0-480GB 6G SATA SSD Size: 447GB, Speed 6.0 Gbs, Media Life Left: 100%
Drive 1-480GB 6G SATA SSD Size: 447GB, Speed 6.0 Gbs, Media Life Left: 100%
Fan 1 Speed: 19.0%
Fan 2 Speed: 19.0%
Fan 3 Speed: 19.0%
Fan 4 Speed: 19.0%
Fan 5 Speed: 19.0%
Fan 6 Speed: 19.0%
Fan 7 Speed: 19.0%
Memory Summary Capacity: 512GB, with State: Rollup State: Normal
Memory proc1dimm10 Size: 64GB, Type: DDR5-4800 MultiBitECC
Memory proc1dimm14 Size: 64GB, Type: DDR5-4800 MultiBitECC
Memory proc1dimm3 Size: 64GB, Type: DDR5-4800 MultiBitECC
Memory proc1dimm7 Size: 64GB, Type: DDR5-4800 MultiBitECC
Memory proc2dimm10 Size: 64GB, Type: DDR5-4800 MultiBitECC
Memory proc2dimm14 Size: 64GB, Type: DDR5-4800 MultiBitECC
Memory proc2dimm3 Size: 64GB, Type: DDR5-4800 MultiBitECC
Memory proc2dimm7 Size: 64GB, Type: DDR5-4800 MultiBitECC
Network adapter DA000000 Model: BCM 5719 1Gb 4p BASE-T OCP Adptr, SeNr: 1CH0150001, PartNr: BCM95719N1905HC
Network adapter DE080000 Model: HPE SN1610Q 32Gb 2p FC HBA, SeNr: MY540220V7, PartNr: R2E09A
Network adapter DE081000 Model: BCM57416, SeNr: VNM3390CJ0, PartNr: P26255-001
Network adapter DE082000 Model: BCM57416, SeNr: VNM3390GM5, PartNr: P26255-001
Physical port 10 Link: LinkUp, Speed: 1000Mbps, MAC: 04:32:01:9b:5f:85
Physical port 11 Link: Unknown, Speed: 0Mbps, MAC: 04:32:01:9b:5f:86
Physical port 12 Link: Unknown, Speed: 0Mbps, MAC: 04:32:01:9b:5f:87
Physical port 141 Link: LinkUp, Speed: 10000Mbps, MAC: 04:32:01:b6:30:00
Physical port 142 Link: LinkUp, Speed: 10000Mbps, MAC: 04:32:01:b6:30:01
Physical port 77 Link: LinkUp, Speed: 10000Mbps, MAC: 04:32:01:b7:92:50
Physical port 78 Link: LinkUp, Speed: 10000Mbps, MAC: 04:32:01:b7:92:51
Physical port 9 Link: LinkUp, Speed: 1000Mbps, MAC: 04:32:01:9b:5f:84
Power supply 0-HpeServerPowerSupply 0.0 Watts input, 201.0 Watts output, 228.0 V input, Capacity 800.0 Watts, Typ 865438-B21
Power supply 1-HpeServerPowerSupply 0.0 Watts input, 174.0 Watts output, 228.0 V input, Capacity 800.0 Watts, Typ 865438-B21
Storage controller DE00C000 Everything looks OK - 1 detail available
System state System with SerialNr: CZJD0L00DK, has State: Component State: Normal, Rollup State: Normal, This resource is enabled.
Temperature 02-CPU 1 PkgTmp Temperature: 54.0 °C
Temperature 03-CPU 2 PkgTmp Temperature: 67.0 °C
Volume 239 Raid Type: RAID1, Size: 446.6GB
[cpu_tracking] Stop [7f22576351c0 - Snapshot(process=posix.times_result(user=0.030000000000000027, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.03999999910593033))]
[special_redfish] Success, [piggyback] Success (but no data found for this host), execution time 3.9 sec | execution_time=3.900 user_time=0.030 system_time=0.010 children_user_time=0.550 children_system_time=0.040 cmk_time_ds=3.270 cmk_time_agent=0.000
Output of “cmk --check-discovery hostname --debug -v”:
Summary
+ FETCHING DATA
+ EXECUTING DISCOVERY PLUGINS (14)
File "/omd/sites/prod/bin/cmk", line 114, in <module>
File "/omd/sites/prod/lib/python3/cmk/base/modes/__init__.py", line 70, in call
return handler(*handler_args)
File "/omd/sites/prod/lib/python3/cmk/base/modes/check_mk.py", line 1639, in mode_check_discovery
with error_handler:
File "/omd/sites/prod/lib/python3/cmk/base/errorhandling/_handler.py", line 66, in __exit__
*_handle_failure(
File "/omd/sites/prod/lib/python3/cmk/base/errorhandling/_handler.py", line 103, in _handle_failure
raise exc
File "/omd/sites/prod/lib/python3/cmk/base/modes/check_mk.py", line 1642, in mode_check_discovery
checks_result = execute_check_discovery(
File "/omd/sites/prod/lib/python3/cmk/checkengine/discovery/_impl.py", line 143, in execute_check_discovery
services = get_host_services(
File "/omd/sites/prod/lib/python3/cmk/checkengine/discovery/_autodiscovery.py", line 605, in get_host_services
**_get_node_services(
File "/omd/sites/prod/lib/python3/cmk/checkengine/discovery/_autodiscovery.py", line 659, in _get_node_services
discovered_services = discover_services(
File "/omd/sites/prod/lib/python3/cmk/checkengine/discovery/_services.py", line 125, in discover_services
File "/omd/sites/prod/lib/python3/cmk/checkengine/discovery/_services.py", line 186, in _discover_plugins_services
yield from plugin.function(check_plugin_name, **kwargs)
File "/omd/sites/prod/lib/python3/cmk/base/checkers.py", line 884, in __discovery_function
yield from (
File "/omd/sites/prod/lib/python3/cmk/base/checkers.py", line 884, in <genexpr>
yield from (
File "/omd/sites/prod/lib/python3/cmk/base/api/agent_based/register/check_plugins.py", line 71, in filtered_generator
for element in generator(*args, **kwargs):
File "/omd/sites/prod/local/lib/python3/cmk/plugins/redfish/agent_based/redfish_voltage.py", line 32, in discovery_redfish_voltage
yield Service(item=entry["Name"])
File "/omd/sites/prod/lib/python3.12/site-packages/cmk/agent_based/v1/_checking_classes.py", line 117, in __new__
item=cls._parse_item(item),
File "/omd/sites/prod/lib/python3.12/site-packages/cmk/agent_based/v1/_checking_classes.py", line 128, in _parse_item
raise TypeError(f"'item' must be a non empty string or ommited entirely, got {item!r}")
TypeError: 'item' must be a non empty string or ommited entirely, got ''
Hi
I updated yesterday from 2.2 to 2.3 and switched from Andreas’ HP iLO Plugin to the new builtin Redfish Plugin to monitor HPE iLO devices. All devices we have with iLO6 are now crashing with the periodic service discovery. Manual discovery seems to be working though and monitoring too. Older generations of iLO don’t have a problem.
Our firmware wasn’t on the newest version, we had v1.58, so we updated iLO firmware to the newest available v1.63, but that didn’t change anything.
