CMK version: 2.2.0p9
**OS version:**rocky9
the Availability Report is showing only todays availability .
what needs to be done, if i have to check total month availability?
Thanks kdeutsch for reply
curretly we have set
online time 3 am to 17.30 (same as notification time daily )
down time 23 to 2 am (this is down time daily)
if i select only during notification filter as shown in screenshot
availability report still considers downtime of 00:38:37
2024-02-28 00:38:37
am i missing anything here?
hi kdeutsch
thank you for the reply.
currently we have set the time period the same way only.but still availability is showing time period before 3 am .
Hi kdeutsch
Thanks for the reply.
i have not yet set this rule.will set the same and check the result and update on case.
meanwhile , can you please tell me , if we set the rule Service period for services = 3.00 to 17.30 , then other than this time , what impact will be on monitoring ? notification?
if any service ot host will be down in time period other than 3.00 to 17.30 , those will show in dashboard or Not ? and what will be impact on Notifications?
yes , we have assigned the time period Service period for services and Service period for Hosts
can you please suggest , how i can check the effect of the the same on my availability report ? if i have to check for say availability of tomcat process.
I tried to apply the service period filter on Monitor->It Infrastructure effeciancy → Windows ( [Windows [CPU & Memory])
If we apply host in service period , we dont see any data , if we ignore the filter of host in service period, we can see the report.
could anybody please suggest if we are missing anything ?
