Dear friends of Checkmk,
the new stable release 2.1.0p19 of Checkmk is ready for download.
This maintenance release ships with 31 changes affecting all editions of Checkmk,
7 Enterprise Edition specific changes and 0 Managed Services Edition specific changes.
Support periods can be found here: Checkmk versions
Changes in all Checkmk Editions:
Agent bakery:
- 14707 FIX: agent_receiver: Fix crash in activation after omd cp…
- 15085 FIX: mk_postgres: relax strict instance process name filtering…
- 14706 FIX: mrpe: Fix missing output in agents if async execution enabled…
BI:
- 14177 FIX: BI aggregations: Services did not receive downtimes from host
Checks & agents:
- 14710 mssql_jobs: New option for monitoring job state…
- 14971 FIX: Checkmk agent: cached sections are never invalidated…
- 14790 FIX: Handle special oracle version 12.1.0.1…
14571 FIX: KUBE: Allow invalid value for
names
field of Node… - 14570 FIX: Kube: Fix crash upon specifying power-of-two unit with CPU resources…
- 14962 FIX: Running cmk-agent-ctl leads to segfault on SELinux systems…
- 15083 FIX: agent_prism: remove newline during authorization header generation…
- 14709 FIX: aws: Missing regions added
- 14708 FIX: fileinfo: Fix crash with negative file age…
- 15082 FIX: mk_postgres.py: adjustment of LINUX process match patterns…
- 15106 FIX: mounts: “failover” cluster mode always reported UNKNOWN
14768 FIX: mssql.vbs: some database specific sections contain data from a different database…
NOTE: Please refer to the migration notes!
Event console:
- 15036 FIX: Forwarding of Logwatch messages to Event Console: Remove unwanted escaping
REST API:
- 15057 REST API: Implement event console endpoints…
- 15056 aux_tags: rest-api endpoint implementation…
- 15058 FIX: REST_API: Show currently running activations was returning a 500 internal error…
Setup:
- 14394 FIX: Changing password fails when a password policy is enforced…
- 14990 FIX: Repair invalid SNMP v3 credentials potentially written via WebAPI…
- 15063 FIX: Resetting password expiry, change enforcement for automation users…
- 14176 FIX: Setup: Fixed invalid contact group configuration in deprecated hosts.mk file…
Setup, site management:
- 15044 FIX: Improve Setup search performance…
User interface:
- 15117 FIX: Fix host and service label sorting and grouping in views
- 15007 FIX: Fix missing separator for some values on effective parameters page
- 15120 FIX: Fix possible error on using host or service level filter
- 15006 FIX: Fix possible error on view “Crash reports”
- 15119 FIX: Fix service custom notes for multiple hosts
- 15072 FIX: Inventory history crash upon sorting
Changes in the Checkmk Enterprise Edition:
Checks & agents:
- 14855 FIX: Fix hitachi_hnas_volume OID for virtualVolumeTitanQuotasUsageLimit
Event console:
- 14854 FIX: Use system MIB for OID translation in EC
Other components:
- 15065 SEC: Path-Traversal in MKP storing…
Reporting & availability:
- 15118 FIX: Fix adding of content elements “for multiple” to reports
Setup:
- 15008 FIX: Fix macro usage in host check command “Use the status of the service…”
The Checkmk Micro Core:
- 14688 FIX: Increased metric queue sizes…
User interface:
- 15009 FIX: Fix “invalid syntax” error on adding metrics to custom graphs…
Changes in the Checkmk Managed Services Edition:
NO CHANGES
You can download Checkmk from our download page: Download Checkmk for free | Checkmk
List of all changes: Werks
Please mail bug reports and qualified feedback to feedback@checkmk.com.
We greatly thank you for using Checkmk and wish you a successful monitoring,
Your Checkmk Team
