Hi, I try to clean up our Checkmk application for our admins.
Is it possible to remove all the kubernet features, because we do not need them?
For example I would like to remove all the integrated kubernet dashboards.
Thank you very mutch!
Julius
Julius
@julius82 Welcome to the forum!
I assume (hope) you don’t want to actually remove the features in the sense of ripping out the code base for them, just not show them.
This can be done through Customize → Topics
EDIT: I just found out you can’t hide an entire topic like that. You have to hide the specific views. If no views for a topic are visible, the topic disappears.
Alternatively, maybe a little quicker, you can remove these views from the roles’ permission. (if you have many roles, that might take longer than editing each view, but if you only have 1-2 roles, it’s quicker :))
