The idea is to keep collecting monitoring data for certain hosts and services and be able to view them on demand.
At the same time, disable all notifications and also remove these hosts and services from the main dashboard.
I have completed the first part by disabling notifications for hosts and services (label based).
Now I want the main dashboard:
Host statistics
Service statistics
Host Problems (unhandled)
Service Problems (unhandled)
Events of recent 4 hours
to be cleaned and only show real issues that I care about.
Is that possible at all?
that should be doable by saving a filtered version (use the labels to filter) of the main dashboard and using this as your new “main”
See sreenshot for example (of course, I only created the filter ad hoc to illustrate this, but you can save the filtered version of a dashboard (for builtin dashboards clone first, then filter the clone). You can also just use the URL of the filtered dashboard:
Getting there, thanks.
Ignoring “Host problem has been acknowledged” is working as expected.
For the label though (NOTIFY:off in my case) I’m unable to specify any action.
The default action is opposite to what I’m trying to achieve.
I.e. it’s only showing hosts with this label:
