Are you a partner for Thruk or DevOps? Seems to me you know your stuff on the topic. ![]()
You can test the application using the url Thruk - Demo using the credentials admin/admin. After logging in you can access the left Menu > Reports > Reporting and others options also. Those reports can also be customized and I hope that they fulfill your needs.
The livestatus connection can be added in System > Config Tool > Backends / Sites.
Here is the link explaining how to install Thruk inside a standard Ubuntu Server. The next step is to connect in our CheckMK instance using livestatus.
@TLI @elias.voelker
I think this thread shows not only the need for the removed feature (I do also understand why it has been removed in the first place), but also shows the lack of flexibility in the reporting module of CMK itself.
To be fair the timeline and availability reports solves my problem when talking about reporting in the Raw edition. Thruk offers more features to deliver more robust reports.
Just got my connector to LiveStatus working, definitely right on the robust reporting/commands you can integrate into CheckMK, thank you again Paulo.
Itās possible to retrieve data from Thruk using json, Iām using that actually. You can create your own spreadsheet to load and process that data.
