Hey,
I was trying to find a way to create some kind of a report for a few hosts.
I do know this was part of the enterprise edition but as of right now still need to prove the raw edition.
Is there any plugin to give something similar to these reports?
not aware of any plugin that does this.
Depending on the type of report you need, you can maybe export data via livestatus as json/csv and transform it into a document (xls, pdf) using python packages.
Depends on how much your time at work is worth compared to the CEE price
