I have forgotten the admin password. I use the command to reset the password, it shows it has been updated, but I can’t login in with the new password, it shows it is wrong.
I use the following commands.
– su - mysite
– htpasswd -m etc/htpasswd cmkadmin
Could you please help me to solve this problem? Thanks in advance.
There is a simpler way to unlock the local admin account. You can edit $OMD_ROOT/var/check_mk/web/cmkadmin/cached_profile.mk. Change the value of ‘locked’ to False
