I have a distributed setup and would like to use the REST-API to set downtimes, when running ansible tasks (patchruns).
As API url I am using the master/central GUI. In the cmc.log I can see that it tries to set the downtime but fails
My guess is, that since the target host (myhost) is on different site, it cannot set the downtime. Is the API on the central site not able to set this on the corresponding host/site? When doing this manually in the master GUI directly, this does not seem to be a problem.
The thing is, that the master site does have connection to all it’s sites, but the host that is running the ansible tasks does not.
Or maybe I am just on the wrong track here, …
thanks. I know the REST-API is very new, but I thought this case was already considered, since the base ability of downtiming was there. I will have to use the “old” method for now, but I’m looking forward to have this ability. I think the REST-API is a great improvement, per se.
Hi @benjamin.alfery ,
We are also stuck similar to your case. which is OLD method are you using, if possible share some thoughts so we can also try it.
we utilized the downtime script, which can be found in ~/share/doc/check_mk/treasures/downtime.py, in an ansible playbook, to set downtimes just ahead of patch runs.
