REST-API: Problem with service discovery
CMK version:
Checkmk Raw Edition 2.1.0
OS version:
Debian 10 and RockyLinux 8
Description:
I am trying to automate my hosts creation with the new REST API.
I copy paste the example that we can find on this link : Configuration via the Checkmk REST API
Everything works fine but when it comes to Service Discovery it didn’t work, I mean it doesn’t show me an error i have got a return code 200 but it did nothing.
I tried to do it with bash and python but the result is the same. Here an example of what i am trying to do:
#!/bin/bash
HOST_NAME="example.com"
SITE_NAME="cmk"
API_URL="https://$HOST_NAME/$SITE_NAME/check_mk/api/1.0"
USERNAME="automation"
PASSWORD="GdqssfqfzaadAO"
out=$(
  curl \
    --request POST \
    --write-out "\nxxx-status_code=%{http_code}\n" \
    --header "Authorization: Bearer $USERNAME $PASSWORD" \
    --header "Accept: application/json" \
    --header "Content-Type: application/json" \
    --data '{
          "mode": "refresh"
    "$API_URL/objects/host/myhost/actions/discover_services/invoke")
echo $out
resp=$( echo "${out}" | grep -v "xxx-status_code" )
code=$( echo "${out}" | awk -F"=" '/^xxx-status_code/ {print $2}')
# For indentation, please install 'jq' (JSON query tool)
echo "$resp" | jq
# echo "$resp"
if [[ $code -lt 400 ]]; then
    echo "OK"
    exit 0
else
    echo "Request error"
    exit 1
fi
Here the result :
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   371  100   332  100    39    410     48 --:--:-- --:--:-- --:--:--   458
{"links": [{"domainType": "link", "rel": "self", "href": "https://example.com/cmk/check_mk/api/1.0/objects/service_discovery/myhost-services-wato", "method": "GET", "type": "application/json"}], "domainType": "service_discovery", "id": "myhost-services-wato", "title": "Services discovery", "members": {}, "extensions": {}} xxx-status_code=200
  "links": [
      "rel": "self",
      "method": "GET",
  "members": {},
  "extensions": {}
OK
I had to re-activate the legacy web API to do what i want but it is not a solution…
Thank you for your answer !
Regards
EDIT : with 2.0.X version it’s working not with 2.1.X version
Hey, i have the same problem since i upgraded in 2.1.x but worked 2.0.x
Have you resolved this problem?
I am also having this issue. Occurs when calling the API directly and with the Ansible Collection
Updating to the latest version fixed it for me
if anyone is having some trouble with discovering services over REST-API/Ansible,
please take a look at this post:
https://forum.checkmk.com/t/service-discovery-via-api-not-working-as-expected/37504/8?u=max
KR,
Max
