So far I have only worked with the WebAPI, which has to be adapted before switching to REST-API.
My task is quite simple. I need all hosts with a defined user defined attribute. For processing, I only need the host name and the IPv4 address. This was done in the previous solution with 2 lines of code.
I don’t know which version exactly you are using. But since 2.0 you can go inside the navigation bar, select Help and then open up the interactive GUI of the REST API.
I just took a look and I would use /objects/host_config/{host_name}
The problem with this is that with almost 5000 hosts, I don’t want to query all hosts individually, which would also be a time problem.
I thought that I could simply filter the list with the RESTAPI.
your call is not that efficient as you are getting data and then showing it away.
just call a normal view with output_format instead, or create a view that have only the columns you need
you can also do this with live status and is perhaps the most efficient solution.
