Reverse proxy not working with Checkmk
Hello everyone, I hope if any colleague has done something similar he can help me.
  • I have a reverse proxy server called: gobcan
  • I have a checkmk 2.1 server called: compadre
  • The name of the Checkmk site: mysite
I want to be able to navigate from the proxy to the checkmk using the following url:
http://gobcan/app/mon
server “gobcan” (proxy reverse)
In my proxy I have the following:
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_http_module modules/mod_http_connect.so
LoadModule proxy_http_module modules/mod_proxy_http.so
<Virtual Host *>
       DocumentRoot /var/www/html
       SSLProxyEngine on
       ProxyRequests off
        ProxyPreserveHost off
        ServerName gobcan
        ProxyPass "/app/mon/" "http://compadre/mysite/"
        ProxyPassReverse "/app/mon/" "http://compadre/mysite/"
</VirtualHost>
Server “compadre” (checkmk)
and in the Checkmk I have configured:
cat mysite.conf
Include /omd/sites/mysite/etc/apache/mode.conf
Capturing the packets of compadre (checkmk) I get that:
The last packet is a 302 which should redirect to:
Location: /mysite/check_mk/login.py?_origtarget=index.py
But as observed, it stops. There is no redirection to the final route.
Does anyone know where the error is or can you share your configuration?
Thank you
Why using a second server? The system Apache on the CMK server is already acting as a reverse proxy for all running sites on this machine. You can extend the config of the system Apache with your needed “ProxyPass”.
It is a Reverse Proxy common to the entire organization.
Web requests have to go through that server (gobcan).
My setup is an example of a lab. It is not the real one.
This works for me:
<IfModule mod_ssl.c>
<VirtualHost *:443>
    ServerAdmin       support@*****
    ServerName        server@domain.com
    ProxyRequests     off
    ProxyPreserveHost On
    ProxyPass         / http://<IP of CheckMK server>:80/ retry=0 timeout=15
    ProxyPassReverse  / http://<IP of CheckMK server>:80/
    SSLCertificateFile /etc/letsencrypt/live/<sitename>/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/<sitename>/privkey.pem
    Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
</IfModule>
You can skip the SSL stuff if you don’t need it. For me that’s one of the main reasons for putting it behind the proxy.
Also, I don’t know what version of Apache you’re using, but isn’t LoadModule deprecated. I think you should use ‘a2enmod’ to enable Apache modules.
For this I have:
proxy_module
proxy_balancer_module
proxy_http_module
Or, if you’re on SUSE, like I am, enable them in /etc/sysconfig/apache2.
thanks @louis
with this configuration it does work with http://gobcan/mysite
          ProxyPass "/" "http://compadre/"
          ProxyPassReverse "/" "http://compadre/"
However, I need to pass the following path to the URL: http://gobcan/app/mon
that’s why i’m using
but it doesn’t work. :frowning:
SSL I will configure it at the end.
I think you’ll need to do something with URL Rewrite (rewrite engine), but I’m no expert on that, sorry.
Maybe you can try something like this:
a2enmod rewrite
And then in the configuration:
RewriteEngine on
RewriteRule ^/app/mon/ /mysite [NC]
But you’ll have to play around with than. Like I said, I’m no expert on that.
Good luck,
Louis
Hello @louis,
Thank you for your interest and for your help. I am not an expert either and the Apache configuration is quite complex for me.
It seems that I have found a configuration that works. I need to do more tests. I copy it here in case someone needs it in the future:
<VirtualHost *>
        SSLProxyEngine on
        ProxyRequests off
        ServerName gobcan
        ProxyPassReverse "/app/mon/" "/mysite/"
        ProxyPassReverseCookiePath  "/mysite/" "/app/mon/"
</VirtualHost>
