for my Robotmk Testsetup I followed the installation description by Simon Meggle: https://www.simon-meggle.de/tutorial-robotmk-schnellstart-teil-1/ (and part 2). It might be a little outdated, but I guessed it should still work.
When I call the agent the robotmk section displays this:
<<<robotmk>>>
FATAL ERROR!: Robotmk cannot start because of a missing Python3 module (Error was: No module named ‘robot’)
Please execute: pip3 install robotframework pyyaml mergedeep python-dateutil
But these modules are already installed on my Windows Server 2019 Testhost.
Requirement already satisfied: robotframework in c:\program files\python38\lib\site-packages (5.0.1)
Requirement already satisfied: pyyaml in c:\program files\python38\lib\site-packages (6.0)
Requirement already satisfied: mergedeep in c:\program files\python38\lib\site-packages (1.3.4)
Requirement already satisfied: python-dateutil in c:\program files\python38\lib\site-packages (2.8.2)
Requirement already satisfied: six>=1.5 in c:\program files\python38\lib\site-packages (from python-dateutil) (1.16.0)
If I call the plugin directly from the agents plugins directory (robotmk.py) the output displays fine without any missing module problem.
I thought this might be an environment variables problem, since the checkmk service is running as local system user and I would call the plugin as my own (admin) user, but when I call the agent.exe on the host itself, I get the same missing module result (with my user).
Does anyone have a clue, why these modules are seem to be missing, though they are installed?
CMK version: 2.0.0p19 (CEE)
RobotMK version(MPK): v1.2.9
BR
Benjamin
