Hi folks,
I have some problems regarding RRD files.
Some interfaces on some of the monitored switches do not show performance data.
I was able to identify (maybe) the root cause of this.
In cmc.log I found the below error message.
So it looks like the RRD .info file is missing for the interfaces.
I found information to identify missing RRD files in the following document:
How-to debug graphs not being created - Checkmk Knowledge Base - Checkmk Knowledge Base
But my problem is a missing .info file!
So I have modified the script line to identify the RRD files without .info file but now I don’t know how to create it?!
So here my question:
How do the system create the .info file in folder /opt/omd/sites//var/check_mk/rrd/ regularly and how can I create the missing ones now?
Restarting the site was not helping.
Rules for “Configuration of RRD databases of hosts/services” exists.
Thanks and Regards
Eike
CMK version:
1.6.0p30
OS version:
RHEL 7.9
2024-04-29 11:50:24 [4] [main] [rrd] [RRD helper 2073] >> Error creating RRD for cmc_single;;;dot11g;0;dot11a;0: Invalid RRD info file /opt/omd/sites//var/check_mk/rrd//.info: [Errno 2] No such file or directory: ‘/opt/omd/sites//var/check_mk/rrd//.info’
