RRDcache crashing again and again - Checkmk not storing monitoring data
CMK version: OMD - Open Monitoring Distribution Version 2.2.0p22.cre
OS version: Ubuntu 20.04.6 LTS
Error message: Stopping rrdcached…/omd/sites/monitoring/etc/rc.d/20-rrdcached: line 77: kill: (202325) - No such process
rrdcached going crash time to time because of that checkmk not storing monitoring data.
The reason for a rrdcached crash are most times invalid performance data.
Do you use any active classic Nagios checks in your environment?
If yes - then please inspect the output from these checks.
I didn’t make any changes. I installed Monitoring APP months ago and it is like that unit now.
No one changed any configuration of monitoring. RRDcache crash came out of nowhere.
Can you please provide steps I have to follow to fix.
Thanks
As you use the RAW edition you can have a look at the pnp4nagios log files if there is anything usable inside.
I don’t think so - this is not coming out of nowhere.
Most likely it is an active classic Nagios check with broken performance data.
Do you have any classic Nagios checks in your environment? Or any strange local checks?
I don’t know anything about Nagios checks. Can you please give me commands which will help me to check logs?
By default following nagios plugins are running:
OMD[monitoring]:~$ ll ~/lib/nagios/plugins/
total 3652
-rwxr-xr-x 1 root root   60760 Feb 13  2024 check_apt*
-rwxr-xr-x 1 root root    8816 Jan 23  2024 check_bi_aggr*
-rwxr-xr-x 1 root root    2319 Nov 30  2023 check_breeze*
-rwxr-xr-x 1 root root   61112 Feb 13  2024 check_by_ssh*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_clamd -> check_tcp*
-rwxr-xr-x 1 root root   48152 Feb 13  2024 check_cluster*
-rwxr-x--- 1 root omd    60632 Feb 13  2024 check_dhcp*
-rwxr-xr-x 1 root root   56728 Feb 13  2024 check_dig*
-rwxr-xr-x 1 root root   65472 Feb 13  2024 check_disk*
-rwxr-xr-x 1 root root   10139 Nov 30  2023 check_disk_smb*
-rwxr-xr-x 1 root root   64888 Feb 13  2024 check_dns*
-rwxr-xr-x 1 root root   39352 Feb 13  2024 check_dummy*
-rwxr-xr-x 1 root root    4385 Jan 23  2024 check_elasticsearch_query*
-rwxr-xr-x 1 root root    5175 Nov 30  2023 check_file_age*
-rwxr-xr-x 1 root root    6400 Nov 30  2023 check_flexlm*
-rwxr-xr-x 1 root root   12850 Jan 23  2024 check_form_submit*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_ftp -> check_tcp*
lrwxrwxrwx 1 root root      10 Feb 13  2024 check_host -> check_icmp*
-rwxr-xr-x 1 root root   56440 Feb 13  2024 check_hpjd*
-rwxr-xr-x 1 root root  111256 Feb 13  2024 check_http*
-rwxr-x--- 1 root omd    68576 Feb 13  2024 check_icmp*
-rwxr-xr-x 1 root root   48280 Feb 13  2024 check_ide_smart*
-rwxr-xr-x 1 root root   15270 Nov 30  2023 check_ifoperstatus*
-rwxr-xr-x 1 root root   13415 Nov 30  2023 check_ifstatus*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_imap -> check_tcp*
-rwxr-xr-x 1 root root    7065 Nov 30  2023 check_ircd*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_jabber -> check_tcp*
-rwxr-xr-x 1 root root   65176 Feb 13  2024 check_ldap*
lrwxrwxrwx 1 root root      10 Feb 13  2024 check_ldaps -> check_ldap*
-rwxr-xr-x 1 root root   52248 Feb 13  2024 check_load*
-rwxr-xr-x 1 root root    7170 Nov 30  2023 check_log*
-rwxr-xr-x 1 root root   10724 Jan 26  2024 check_mail*
-rwxr-xr-x 1 root root   13587 Jan 31  2024 check_mail_loop*
-rwxr-xr-x 1 root root    6801 Jan 23  2024 check_mailboxes*
-rwxr-xr-x 1 root root   23281 Nov 30  2023 check_mailq*
-rwxr-xr-x 1 root root 1068896 Feb 13  2024 check_mkevents*
-rwxr-xr-x 1 root root   52312 Feb 13  2024 check_mrtg*
-rwxr-xr-x 1 root root   52184 Feb 13  2024 check_mrtgtraf*
-rwxr-xr-x 1 root root   61048 Feb 13  2024 check_mysql*
-rwxr-xr-x 1 root root   52568 Feb 13  2024 check_mysql_query*
-rwxr-xr-x 1 root root   52280 Feb 13  2024 check_nagios*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_nntp -> check_tcp*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_nntps -> check_tcp*
-rwxr-xr-x 1 root root    2949 Jan 23  2024 check_notify_count*
-rwxr-xr-x 1 root root   53200 Feb 13  2024 check_nrpe*
-rwxr-xr-x 1 root root   64728 Feb 13  2024 check_nt*
-rwxr-xr-x 1 root root   64792 Feb 13  2024 check_ntp*
-rwxr-xr-x 1 root root   60888 Feb 13  2024 check_ntp_peer*
-rwxr-xr-x 1 root root   56600 Feb 13  2024 check_ntp_time*
-rwxr-xr-x 1 root root   68728 Feb 13  2024 check_nwstat*
-rwxr-xr-x 1 root root    9392 Nov 30  2023 check_oracle*
-rwxr-xr-x 1 root root   52312 Feb 13  2024 check_overcr*
-rwxr-xr-x 1 root root   65208 Feb 13  2024 check_pgsql*
-rwxr-xr-x 1 root root   60760 Feb 13  2024 check_ping*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_pop -> check_tcp*
-rwxr-xr-x 1 root root   61016 Feb 13  2024 check_procs*
-rwxr-xr-x 1 root root   52408 Feb 13  2024 check_real*
-rwxr-xr-x 1 root root    9671 Nov 30  2023 check_rpc*
-rwxr-xr-x 1 root root    1509 Nov 30  2023 check_sensors*
-rwxr-xr-x 1 root root    8624 Jan 23  2024 check_sftp*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_simap -> check_tcp*
-rwxr-xr-x 1 root root   73656 Feb 13  2024 check_smtp*
-rwxr-xr-x 1 root root   78104 Feb 13  2024 check_snmp*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_spop -> check_tcp*
-rwxr-xr-x 1 root root   15245 Jan 23  2024 check_sql*
-rwxr-xr-x 1 root root   52408 Feb 13  2024 check_ssh*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_ssmtp -> check_tcp*
-rwxr-xr-x 1 root root   48088 Feb 13  2024 check_swap*
-rwxr-xr-x 1 root root   69624 Feb 13  2024 check_tcp*
-rwxr-xr-x 1 root root   52376 Feb 13  2024 check_time*
-rwxr-xr-x 1 root root    8866 Jan 23  2024 check_traceroute*
lrwxrwxrwx 1 root root       9 Feb 13  2024 check_udp -> check_tcp*
-rwxr-xr-x 1 root root    3544 Jan 24  2024 check_uniserv*
-rwxr-xr-x 1 root root   56472 Feb 13  2024 check_ups*
-rwxr-xr-x 1 root root    9951 Nov 30  2023 check_uptime*
-rwxr-xr-x 1 root root   43896 Feb 13  2024 check_users*
-rwxr-xr-x 1 root root    3005 Nov 30  2023 check_wave*
-rwxr-xr-x 1 root root   48032 Feb 13  2024 negate*
-rwxr-xr-x 1 root root   39632 Feb 13  2024 urlize*
-rwxr-xr-x 1 root root    1973 Nov 30  2023 utils.pm*
-rwxr-xr-x 1 root root    2807 Nov 30  2023 utils.sh*
They are not running, this is only the folder where the default plugins located.
One more problem i had yesterday with similar outcome was a local check with many many performance vlaues (over 100). This check resulted also in a crash.
