ahanjrah
(Aman Hanjrah)
December 2, 2020, 6:32pm
1
We are seeing this error in our check_mk server in the logs for each and every host. How do I start the rrdcached service?
2020-12-02 10:25:44 [89254] [0] RRDs::update /omd/sites/lin/var/pnp4nagios/perfdata/serv12/Check_MK_children_user_time.rrd 1606933514:0.000
2020-12-02 10:25:44 [89254] [0] RRDs::update ERROR Unable to connect to rrdcached: Connection refused
2020-12-02 10:25:44 [89254] [0] RRDs::update /omd/sites/lin/var/pnp4nagios/perfdata/serv14/Check_MK_children_system_time.rrd 1606933514:0.000
2020-12-02 10:25:44 [89254] [0] RRDs::update /omd/sites/lin/var/pnp4nagios/perfdata/serv1/Check_MK_cmk_time_agent.rrd 1606933514:1.831
We are getting this kind of alerts for ALL hosts.
Server OS: RHEL 7.7
check_mk ver: RAW edition 1.6.0p11
ahanjrah
(Aman Hanjrah)
December 2, 2020, 6:34pm
2
Some more info:
$ omd status
mkeventd: running
rrdcached: stopped
npcd: running
nagios: running
apache: running
crontab: running
Overall state: partially running
ahanjrah
(Aman Hanjrah)
December 2, 2020, 7:38pm
3
Nevermind, we just restarted the whole site and it fixed the issue with rrdcached service not being working.
$ omd restart
$ omd status
mkeventd: running
rrdcached: running
npcd: running
nagios: running
apache: running
crontab: running
Overall state: running
Not sure how can I mark it resolved, but if someone from moderator team can do it, it’ll be great.
Thanks.
r.sander
(Robert Sander)
December 2, 2020, 7:51pm
4
You could have restarted just rrdcached with
omd restart rrdcached
ahanjrah
(Aman Hanjrah)
December 2, 2020, 8:16pm
5
r.sander— Ahh. I was not aware of that and I tried to find documentation for that as well to no avail. But it is good to know in the future. Thanks for the input.
ChristianM
(Christian Michaelski)
December 3, 2020, 8:04am
6
please have a look at the logs. The rrd can crash, if you have no space left on the device when you add new hosts on your system.
Cheers,
Christian
thorian93
(Robin Gierse)
October 4, 2021, 7:13am
7
@ahanjrah you can mark your own answer as the solution to your initial question. That way others can quickly see how you resolved your issue.
ahanjrah
(Aman Hanjrah)
October 4, 2021, 3:35pm
8
thorian, I marked r.sander’s answer as a solution, thanks for the reminder.
system
(system)
Closed
October 4, 2022, 3:36pm
9
