this is more or less a basic question and easy to test, but i want confidence.
I made a rule directing the Main Folder, does the rule now get inherited on all subfolders?
If i let me show the “used rules” in one subfolder, i don’t see the rule. Does it mean that i have to create a rule for every subfolder where the rule should work on?
I think i know what’s your problem.
You press the button “Used rulesets” and get an empty response.
That is a small bug inside the web interface.
Insert “.*” inside the search box and press “Search”.
Now you see all used rules inside this folder.
There is no search done with only the button “Used rulesets” pressed.
