Saphana db monitoring
i have copied the mkp_sap hana file to usr/lib/check_mk_agent/plugins . will agent pickit up from there? or do i need to use any other configuration here?
CMK version: Checkmk Raw Edition 2.2.0p8
OS version: sles 15 sp3
Agent plugins often contain a comment section documenting their use. Here it is:
Hi Sairam,
the good guys at checkmk have a KB entry for sap hana: SAP HANA - Checkmk Knowledge Base - Checkmk Knowledge Base
Hi @gstolz ,
i went through the link, tried to run the plugin manually using this command
MK_CONFDIR= /etc/check_mk /usr/lib/check_mk_agent/plugins/mk_sap_hana
and i m getting this error
hdbsql ERROR: * 10: authentication failed SQLSTATE: 28000.
However, the credentials thats been used here are valid and can able to login with those
Hi @SairamObili,
can you run:
export MK_CONFDIR=/etc/check_mk
(no space after the =)
and then
bash -x /usr/lib/check_mk_agent/plugins/mk_sap_hana
this will show you exactly how the hdbsql command is called and that makes it easier to spot the credential issue.
