I have a question when we do search in setup it displays currently indexing, please try again shortly.
We have below hosts count in CheckMK.
Will it be a reason because of number of hosts we have. We have a dedicated master node. How can I increase the resources or make config change that can help in fixing this search issue.
OMD[main]:~$ tail -f /var/log/web.log
tail: cannot open '/var/log/web.log' for reading: No such file or directory
tail: no files remaining
OMD[main]:~$ tail -f var/log/web.log
File "/omd/sites/main/lib/python3/cmk/gui/watolib/rulespecs.py", line 1340, in <genexpr>
if rulespec.title
File "/omd/sites/main/lib/python3/cmk/gui/watolib/rulespecs.py", line 460, in title
return self.valuespec.title()
File "/omd/sites/main/lib/python3/cmk/gui/watolib/rulespecs.py", line 453, in valuespec
return self._valuespec()
File "<string>", line 88, in _valuespec_active_checks_snmp
File "/omd/sites/main/lib/python3.9/typing.py", line 685, in __call__
raise TypeError(f"Type {self._name} cannot be instantiated; "
TypeError: Type Tuple cannot be instantiated; use tuple() instead
I guess there’s a small but significant typo in that KB article.
Instead of tail -f +/var/log/web.log it should read tail -f ~/var/log/web.log, i.e. tilde instead of plus character, so it references the log below the site dir, not the system-wide log (which probably doesn’t exist at that path anyway)
@mschlenker: not sure if that might be something for you to check/fix?
but looks like the same message … and I have no idea how it comes from…
2023-02-15 15:11:19,311 [40] [cmk.web.background-job 9519] Exception in background function
File "/omd/sites/main/lib/python3/cmk/gui/background_job.py", line 246, in _execute_function
func_ptr(*args, **kwargs)
File "/omd/sites/main/lib/python3/cmk/gui/watolib/search.py", line 496, in _build_index_background
IndexBuilder(match_item_generator_registry).build_full_index()
File "/omd/sites/main/lib/python3/cmk/gui/watolib/search.py", line 244, in build_full_index
self._build_index(self._registry.values())
File "/omd/sites/main/lib/python3/cmk/gui/watolib/search.py", line 129, in _build_index
self._do_build_index(match_item_generators)
File "/omd/sites/main/lib/python3/cmk/gui/watolib/search.py", line 147, in _do_build_index
self._add_language_dependent_item_generators_to_redis(
File "/omd/sites/main/lib/python3/cmk/gui/watolib/search.py", line 184, in _add_language_dependent_item_generators_to_redis
self._add_match_item_generator_to_redis(
File "/omd/sites/main/lib/python3/cmk/gui/watolib/search.py", line 206, in _add_match_item_generator_to_redis
cls._add_match_items_to_redis(
File "/omd/sites/main/lib/python3/cmk/gui/watolib/search.py", line 222, in _add_match_items_to_redis
for idx, match_item in enumerate(match_item_generator.generate_match_items()):
File "/omd/sites/main/lib/python3/cmk/gui/watolib/rulespecs.py", line 1327, in generate_match_items
yield from (
if rulespec.title
^C
OMD[main]:~$ tail -f ~/var/log/web.log
