Send sms notifications using SMS Modem Multitech MTCM2-L4G1-B03-KIT
hello everyone,
i have the this SMS Modem Multitech MTCM2-L4G1-B03-KIT and it works with my checkmk appliance.
i do can send an sms test from checkmk to a colleague of mine. so the modem is working 100%
but i have no idea what to do so that specific notification will be sent also over that SMS Gateway
can someone help? thank you in advance.
in the site directory ~/share/doc/check_mk/treasures/notifications you can find the script multitech. Copy this file to local/share/notifications. After that you should be able to select SMS via MultiTech SMS-Gateway as notification method.
Karl
@kdeutsch thanks for your repy.
i already made it work without doing anaything on the shell command.
all what i did isi added a new rule under Setup>Events>Notifications
and in the settings i did this.
and i add the number for the user under Users Configuration
and the users got the SMS notifications.
