Sensor is partially not updated in 2.3.0 enterprise
CMK version: 2.3.0
OS version: Debian 12 and Ubuntu 22.04
I have the phenomenon that in a host the sensors suddenly stop writing recordings for no apparent reason. The hosts are all integrated and registered with the CheckMK agent (default). For example, on one server everything is recorded cleanly and regularly for hours and then all of a sudden there is a gap of a few hours.
When I manually select the host in the web interface to reload the sensor information, it loads it again.
This happens with different hosts at different intervals. So not always with all of them and not always at the same time. On the network side, communication between the agent and the CheckMK server is not restricted.
Thank you and best regards
Output of “cmk --debug -vvn gal-stun-lnx22”:
value store: synchronizing
Trying to acquire lock on /omd/sites/***/tmp/check_mk/counters/gal-stun-lnx22
Got lock on /omd/sites/***/tmp/check_mk/counters/gal-stun-lnx22
Releasing lock on /omd/sites/***/tmp/check_mk/counters/gal-stun-lnx22
Released lock on /omd/sites/***/tmp/check_mk/counters/gal-stun-lnx22
Checkmk version 2.3.0
+ FETCHING DATA
  Source: SourceInfo(hostname='gal-stun-lnx22', ipaddress='10.0.20.21', ident='agent', fetcher_type=<FetcherType.TCP: 8>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f6204b5bfe0]
Read from cache: AgentFileCache(gal-stun-lnx22, path_template=/omd/sites/***/tmp/check_mk/cache/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 57 sec, allowed is 0 sec)
Connecting via TCP to 10.0.20.21:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS
Detected transport protocol: TransportProtocol.PLAIN
Closing TCP connection to 10.0.20.21:6556
Write data to cache file /omd/sites/***/tmp/check_mk/cache/gal-stun-lnx22
Trying to acquire lock on /omd/sites/***/tmp/check_mk/cache/gal-stun-lnx22
Got lock on /omd/sites/***/tmp/check_mk/cache/gal-stun-lnx22
Releasing lock on /omd/sites/***/tmp/check_mk/cache/gal-stun-lnx22
Released lock on /omd/sites/**/tmp/check_mk/cache/gal-stun-lnx22
[cpu_tracking] Stop [7f6204b5bfe0 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=6.150000002235174))]
  Source: SourceInfo(hostname='gal-stun-lnx22', ipaddress='10.0.20.21', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f6204b5b590]
Read from cache: NoCache(gal-stun-lnx22, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'gal-stun-lnx22'. Skip processing.
No piggyback files for '10.0.20.21'. Skip processing.
Get piggybacked data
[cpu_tracking] Stop [7f6204b5b590 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f6205ba52b0]
+ PARSE FETCHER RESULTS
<<<nfsmounts_v2:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<multipath>>> / Transition HostSectionParser -> HostSectionParser
<<<timesyncd>>> / Transition HostSectionParser -> HostSectionParser
<<<timesyncd_ntpmessage:sep(10)>>> / Transition HostSectionParser -> HostSectionParser
  HostKey(hostname='gal-stun-lnx22', source_type=<SourceType.HOST: 1>)  -> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'cpu', 'df_v2', 'diskstat', 'job', 'kernel', 'labels', 'lnx_if', 'local', 'md', 'mem', 'mounts', 'multipath', 'nfsmounts_v2', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'timesyncd', 'timesyncd_ntpmessage', 'uptime', 'vbox_guest']
  HostKey(hostname='gal-stun-lnx22', source_type=<SourceType.HOST: 1>)  -> Add sections: []
Received no piggyback data
CPU load             15 min load: 0.13, 15 min load per core: 0.13 (1 cores)
CPU utilization      Total CPU (15 min average): 11.52%
Check_MK Agent       Version: 2.3.0, OS: linux, Agent plug-ins: 0, Local checks: 0
Disk IO SUMMARY      Read: 910 B/s, Write: 18.7 kB/s, Latency: 612 microseconds
Filesystem /         [/dev/sda2], Used: 56.18% - 11.8 GB of 21.0 GB (warn/crit at 79.90%/89.95% used), therein reserved for root: 5.20% (1.09 GB), trend per 1 day 0 hours: +16.7 MB, trend per 1 day 0 hours: +0.08%, Time left until disk full: 1 year 183 days, Inodes used: 9.64%, Inodes available: 1,184,361 (90.36%)
Interface ens160     [2], (up), MAC: 00:50:56:97:73:26, Speed: 10 GBit/s, In average 15min: 264 kBit/s (<0.01%), Out average 15min: 620 kBit/s (<0.01%), Total average 15min: 884 kBit/s (<0.01%)
Interface lo         [1], (up), MAC: 00:00:00:00:00:00, Speed: unknown, In average 15min: 24.6 Bit/s, Out average 15min: 24.6 Bit/s, Total average 15min: 49.2 Bit/s
Kernel Performance   Process Creations: 4.19/s, Context Switches: 1311.52/s, Major Page Faults: 0.02/s, Page Swap in: 0.00/s, Page Swap Out: 0.16/s
Memory               Total virtual memory: 13.97% - 822 MiB of 5.75 GiB, 9 additional details available
Mount options of /   Mount options exactly as expected
Number of threads    283, Usage: 1.91%
Systemd Service Summary Total: 151, Disabled: 3, Failed: 0
Systemd Socket Summary Total: 22, Disabled: 0, Failed: 0
Systemd Timesyncd Time Offset: 1 millisecond, Time since last sync: 30 minutes 51 seconds, Time since last NTPMessage: 30 minutes 51 seconds, Stratum: 2.00, Jitter: 2 milliseconds, Synchronized on 185.125.190.56
TCP Connections      Established: 4
Uptime               Up since 2024-04-23 17:13:06, Uptime: 13 days 3 hours
[cpu_tracking] Stop [7f6205ba52b0 - Snapshot(process=posix.times_result(user=0.040000000000000036, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.03999999910593033))]
[agent] Success, [piggyback] Success (but no data found for this host), execution time 6.2 sec | execution_time=6.190 user_time=0.050 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=6.140
Hello together!
I have the same issue, service graphs (of some hosts ans sometimes even just single services of a host) not writing. For me, it’s on different host types (cmk agent, SNMP, even custom nagios checks).
Just upgraded to 2.3.0p1 to see if it makes any difference
Thanks!
I have also just updated to version 2.3.0p1. Now, however, the dashboard can no longer be loaded and hangs so that the browser tab has to be closed. No matter which browser. Edge, Firefox etc.
sounds stupid but can you please try “Ctrl+Shift+r” in that tab.
This would exclude that it’s related to old css/js definitions
Unfortunately, the problems also persist with version 2.3.0p1, which is unfortunately sobering.
Unfortunately no, cache deleted, page reloaded, cache deactivated etc. does not help.
is this the built-in dashboard or a custom dashboard?
Do you have any entries in ~/var/log/web.log of that site
Regarding cmk raw edition, i might have found the root cause for some of the graphs missing:
In /omd/sites//var/pnp4nagios/log/npcd.log
[05-08-2024 21:38:05] NPCD: ERROR: Executed command exits with return code '7'
[05-08-2024 21:38:05] NPCD: ERROR: Command line was '/omd/sites/<sitename>/lib/pnp4nagios/process_perfdata.pl -n -c /omd/sites/<sitename>/etc/pnp4nagios/process_perfdata.cfg -b /omd/sites/<sitename>/var/pnp4nagios/spool//perfdata.1715197070'
[05-08-2024 21:38:35] NPCD: ERROR: Executed command exits with return code '7'
[05-08-2024 21:38:35] NPCD: ERROR: Command line was '/omd/sites/<sitename>/lib/pnp4nagios/process_perfdata.pl -n -c /omd/sites/<sitename>/etc/pnp4nagios/process_perfdata.cfg -b /omd/sites/<sitename>/var/pnp4nagios/spool//perfdata.1715197085'
[05-08-2024 21:39:29] NPCD: ERROR: Executed command exits with return code '7'
[05-08-2024 21:39:29] NPCD: ERROR: Command line was '/omd/sites/<sitename>/lib/pnp4nagios/process_perfdata.pl -n -c /omd/sites/<sitename>/etc/pnp4nagios/process_perfdata.cfg -b /omd/sites/<sitename>/var/pnp4nagios/spool//perfdata.1715197145'
After some research, I found this post in the nagios forum, suggesting to increase processing timeout in process_perfdata.cfg: NPCD Error Code 7 - Nagios Support Forum
And in fact, after increasing the TIMEOUT value from the default of 15 to in my case 60 (just for testing) and then restarting the cmk site, the mentioned log errors no longer appear and all graphs seem to be rendered correctly. (Haven’t done long-term testing yet).
Unfortunately can’t speak for cmk enterprise/cmc, but maybe there is a similar parameter that can be tuned. Maybe someone from the dev team can help here?
My Assumption is that due to the increased resource usage of cmk 2.3.0 (see changelog), the processing time for perfdata increased above the configured threshold, creating the gaps.
I have also increased the value for myself, exactly the same problem. The dashboard I put together, which worked perfectly in version 2.3.0 Enterprise, no longer works with 2.3.0p1. The browser hangs. The support also leaves a lot to be desired. No response from either Support or Sales for almost two weeks now. I ask myself why I am actually paying money for this!
The sensor information is also still incomplete. Sometimes for days.
I can see an email, which might have been you from 4 days ago, which was forwarded to sales. I will check with them, where the hold up is.
Yes it was the second or 3th mail
Yes, I discovered the other mails from you in the sales system. I pinged the folks, so I guess on Monday someone will be answering.
After I adopted the following settings and went back from version 2.3.0p1 to 2.3.0, everything worked again. I now have all the graph data from the sensors for the first time and no hangs in the browser until now.
npcd.cfg
npcd_max_threads = 15
TIMEOUT = 60
