Is there any documentation of servicenow integration with checkmk
There is no setup guide yet, but you can click on the little button and you will get some help about what has to be put inside the input fields.
Can you explain your problems in detail?
As Simon stated, the inline help should give you the needed informations. If there are open questions we could adjust that.
Did you get this to work?
