So do I have then have to create a host for each of the masters to start off with? And how do I then indicate that in the rule set that has to be created at step 2.?
Or do I initially only create a host for master-0 and then the dynamic host configuration will pick up the additional masters along with the worker nodes?
Here is a screenshot of the nodes in the cluster I’d like to add to the checkmk monitoring, in case someone with a similar node setup is already using checkmk for monitoring on their K8s cluster, but the inclusion of the topology link in the original post was confusing the issue instead of clarifying it.
We also operate with a single ingress for this cluster.
What did you use as hostname for monitoring then instead of the master node?
The ingress url/ip-address?
