Hello All,
I’m using Check_MK RAW 2.1.0p9
I have set up an alert to monitor files from a path on a server.
I am being asked to configure notifications by time, for example (1):
from 08:00am to 20:00 - If a file has not been received within 1 hour, a notification like p2 is triggered, if a file has not been received within 4 hours, a P1 notification should be triggered.
They also want notifications by files, example (2):
If there are > 50 files in the FTP folder, a P2 alert is triggered
If there are > 100 files in the FTP folder, a P1 alert is triggered
The latter can be configured from the same alert in the parameters, but in example (1) I have not found any option to be able to configure it for these time periods. Is there a rule in Check_MK to be able to configure it like this?
When configuring notifications, can they be configured separately, that is; one notification for example (1) and another for example (2).
Example configuration (2)
Thanks in advance.
VIX
