Several Ubiquiti Unifi Switchports in operational state unknown after update of Unifi Network Application and Switch Firmware
CMK version: 2.4.0p17
OS version: Debian 12.12
Error message: Switch Interface xy - Operational state: unknown
[?2004lvalue store: loading from diskCheckmk version 2.4.0p17e[33m+e[0m FETCHING DATASource: SourceInfo(Hostname ersetzt=‘’, ipaddress=‘’, ident=‘snmp’, fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)[cpu_tracking] Start [7f0617423710]Read from cache: SNMPFileCache(path_template=/omd/sites//tmp/check_mk/data_source_cache/snmp/{mode}/, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)Not using cache (Too old. Age is 17 sec, allowed is 0 sec)if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)Executing BULKWALK (v2c) of “.1.3.6.1.2.1.1.3” on .1.3.6.1.2.1.1.3.0 => [b’94926800’] ‘TICKS’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.25.1.1” on Executing SNMP _Mode.GET of .1.3.6.1.2.1.25.1.1 on => [None] NOSUCHOBJECTExecuting BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.1” on .1.3.6.1.2.1.2.2.1.1.1 => [b’1’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.2 => [b’2’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.3 => [b’3’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.4 => [b’4’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.5 => [b’5’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.6 => [b’6’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.7 => [b’7’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.8 => [b’8’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.9 => [b’9’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.10 => [b’10’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.11 => [b’11’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.12 => [b’12’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.13 => [b’13’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.14 => [b’14’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.15 => [b’15’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.16 => [b’16’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.17 => [b’17’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.18 => [b’18’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.19 => [b’19’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.20 => [b’20’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.21 => [b’21’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.22 => [b’22’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.23 => [b’23’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.24 => [b’24’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.25 => [b’25’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.26 => [b’26’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.65 => [b’65’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.66 => [b’66’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.67 => [b’67’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.68 => [b’68’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.69 => [b’69’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.70 => [b’70’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.71 => [b’71’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.72 => [b’72’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.73 => [b’73’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.74 => [b’74’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.75 => [b’75’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.76 => [b’76’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.77 => [b’77’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.78 => [b’78’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.79 => [b’79’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.80 => [b’80’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.81 => [b’81’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.82 => [b’82’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.83 => [b’83’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.84 => [b’84’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.85 => [b’85’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.86 => [b’86’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.87 => [b’87’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.88 => [b’88’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.89 => [b’89’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.90 => [b’90’] ‘INTEGER32’.1.3.6.1.2.1.2.2.1.1.91 => [b’91’] ‘INTEGER32’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.2” on .1.3.6.1.2.1.2.2.1.2.1 => [b’Slot: 0 Port: 1 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.2 => [b’Slot: 0 Port: 2 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.3 => [b’Slot: 0 Port: 3 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.4 => [b’Slot: 0 Port: 4 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.5 => [b’Slot: 0 Port: 5 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.6 => [b’Slot: 0 Port: 6 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.7 => [b’Slot: 0 Port: 7 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.8 => [b’Slot: 0 Port: 8 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.9 => [b’Slot: 0 Port: 9 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.10 => [b’Slot: 0 Port: 10 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.11 => [b’Slot: 0 Port: 11 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.12 => [b’Slot: 0 Port: 12 Gigabit - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.13 => [b’Slot: 0 Port: 13 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.14 => [b’Slot: 0 Port: 14 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.15 => [b’Slot: 0 Port: 15 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.16 => [b’Slot: 0 Port: 16 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.17 => [b’Slot: 0 Port: 17 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.18 => [b’Slot: 0 Port: 18 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.19 => [b’Slot: 0 Port: 19 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.20 => [b’Slot: 0 Port: 20 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.21 => [b’Slot: 0 Port: 21 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.22 => [b’Slot: 0 Port: 22 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.23 => [b’Slot: 0 Port: 23 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.24 => [b’Slot: 0 Port: 24 2.5G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.25 => [b’Slot: 0 Port: 25 10G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.26 => [b’Slot: 0 Port: 26 10G - Level’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.65 => [b’ CPU Interface for Slot: 5 Port: 1’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.66 => [b’ Link Aggregate 1’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.67 => [b’ Link Aggregate 2’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.68 => [b’ Link Aggregate 3’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.69 => [b’ Link Aggregate 4’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.70 => [b’ Link Aggregate 5’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.71 => [b’ Link Aggregate 6’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.72 => [b’ Link Aggregate 7’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.73 => [b’ Link Aggregate 8’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.74 => [b’ Link Aggregate 9’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.75 => [b’ Link Aggregate 10’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.76 => [b’ Link Aggregate 11’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.77 => [b’ Link Aggregate 12’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.78 => [b’ Link Aggregate 13’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.79 => [b’ Link Aggregate 14’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.80 => [b’ Link Aggregate 15’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.81 => [b’ Link Aggregate 16’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.82 => [b’ Link Aggregate 17’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.83 => [b’ Link Aggregate 18’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.84 => [b’ Link Aggregate 19’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.85 => [b’ Link Aggregate 20’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.86 => [b’ Link Aggregate 21’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.87 => [b’ Link Aggregate 22’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.88 => [b’ Link Aggregate 23’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.89 => [b’ Link Aggregate 24’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.90 => [b’ Link Aggregate 25’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.2.91 => [b’ Link Aggregate 26’] ‘OCTETSTR’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.3” on .1.3.6.1.2.1.2.2.1.3.1 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.2 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.3 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.4 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.5 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.6 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.7 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.8 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.9 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.10 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.11 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.12 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.13 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.14 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.15 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.16 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.17 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.18 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.19 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.20 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.21 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.22 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.23 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.24 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.25 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.26 => [b’6’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.65 => [b’1’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.66 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.67 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.68 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.69 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.70 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.71 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.72 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.73 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.74 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.75 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.76 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.77 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.78 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.79 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.80 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.81 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.82 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.83 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.84 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.85 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.86 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.87 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.88 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.89 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.90 => [b’161’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.3.91 => [b’161’] ‘INTEGER’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.5” on .1.3.6.1.2.1.2.2.1.5.1 => [b’1000000000’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.2 => [b’1000000000’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.3 => [b’1000000000’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.4 => [b’1000000000’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.5 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.6 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.7 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.8 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.9 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.10 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.11 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.12 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.13 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.14 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.15 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.16 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.17 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.18 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.19 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.20 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.21 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.22 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.23 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.24 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.25 => [b’4294967295’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.26 => [b’4294967295’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.65 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.66 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.67 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.68 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.69 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.70 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.71 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.72 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.73 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.74 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.75 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.76 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.77 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.78 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.79 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.80 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.81 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.82 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.83 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.84 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.85 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.86 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.87 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.88 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.89 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.90 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.2.2.1.5.91 => [b’0’] ‘GAUGE’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.8” on .1.3.6.1.2.1.2.2.1.8.1 => [b’1’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.2 => [b’1’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.3 => [b’1’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.4 => [b’1’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.5 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.6 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.7 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.8 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.9 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.10 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.11 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.12 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.13 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.14 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.15 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.16 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.17 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.18 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.19 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.20 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.21 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.22 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.23 => [b’2’] ‘INTEGER’.1.3.6.1.2.1.2.2.1.8.24 => [b’2’] ‘INTEGER’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.6” on .1.3.6.1.2.1.31.1.1.1.6.1 => [b’8884732002’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.2 => [b’9690392886’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.3 => [b’7003347029’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.4 => [b’1218051292’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.25 => [b’10898046459’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.26 => [b’54285882776’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.65 => [b’7883125824’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.6.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.7” on .1.3.6.1.2.1.31.1.1.1.7.1 => [b’15096304’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.2 => [b’17476099’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.3 => [b’12265229’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.4 => [b’3632327’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.25 => [b’6683670’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.26 => [b’61677162’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.65 => [b’2372958’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.7.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.8” on .1.3.6.1.2.1.31.1.1.1.8.1 => [b’47172’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.2 => [b’175726’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.3 => [b’209863’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.4 => [b’41966’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.25 => [b’41239121’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.26 => [b’24756263’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.65 => [b’39484230’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.8.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.9” on .1.3.6.1.2.1.31.1.1.1.9.1 => [b’47888’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.2 => [b’49078’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.3 => [b’47646’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.4 => [b’12600’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.25 => [b’52223813’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.26 => [b’28769071’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.65 => [b’51862633’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.9.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.13” on .1.3.6.1.2.1.2.2.1.13.1 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.2 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.3 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.4 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.5 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.6 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.7 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.8 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.9 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.10 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.11 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.12 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.13 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.14 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.15 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.16 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.17 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.18 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.19 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.20 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.21 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.22 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.23 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.24 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.25 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.26 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.65 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.66 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.67 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.68 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.69 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.70 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.71 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.72 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.73 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.74 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.75 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.76 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.77 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.78 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.79 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.80 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.81 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.82 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.83 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.84 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.85 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.86 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.87 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.88 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.89 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.90 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.13.91 => [b’0’] ‘COUNTER’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.14” on .1.3.6.1.2.1.2.2.1.14.1 => [b’70’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.2 => [b’183’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.3 => [b’199’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.4 => [b’100’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.5 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.6 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.7 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.8 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.9 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.10 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.11 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.12 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.13 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.14 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.15 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.16 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.17 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.18 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.19 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.20 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.21 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.22 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.23 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.24 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.25 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.26 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.65 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.66 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.67 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.68 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.69 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.70 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.71 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.72 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.73 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.74 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.75 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.76 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.77 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.78 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.79 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.80 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.81 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.82 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.83 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.84 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.85 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.86 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.87 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.88 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.89 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.90 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.14.91 => [b’0’] ‘COUNTER’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.10” on .1.3.6.1.2.1.31.1.1.1.10.1 => [b’22258294679’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.2 => [b’28000684108’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.3 => [b’17080301273’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.4 => [b’6831152919’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.25 => [b’2282005402’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.26 => [b’28568329043’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.65 => [b’824943486’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.10.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.11” on .1.3.6.1.2.1.31.1.1.1.11.1 => [b’20619390’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.2 => [b’25648979’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.3 => [b’16988357’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.4 => [b’3229641’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.25 => [b’7000175’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.26 => [b’43522091’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.65 => [b’2365979’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.11.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.12” on .1.3.6.1.2.1.31.1.1.1.12.1 => [b’11981878’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.2 => [b’12067470’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.3 => [b’11341683’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.4 => [b’11835042’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.25 => [b’1551908’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.26 => [b’18129708’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.65 => [b’2281841’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.12.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.13” on .1.3.6.1.2.1.31.1.1.1.13.1 => [b’50053022’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.2 => [b’50132741’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.3 => [b’49905845’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.4 => [b’50017752’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.5 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.6 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.7 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.8 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.9 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.10 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.11 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.12 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.13 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.14 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.15 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.16 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.17 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.18 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.19 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.20 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.21 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.22 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.23 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.24 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.25 => [b’431611’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.26 => [b’23932968’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.65 => [b’30862’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.66 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.67 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.68 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.69 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.70 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.71 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.72 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.73 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.74 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.75 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.76 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.77 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.78 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.79 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.80 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.81 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.82 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.83 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.84 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.85 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.86 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.87 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.88 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.89 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.90 => [b’0’] ‘COUNTER64’.1.3.6.1.2.1.31.1.1.1.13.91 => [b’0’] ‘COUNTER64’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.19” on .1.3.6.1.2.1.2.2.1.19.1 => [b’1415712’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.2 => [b’1417381’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.3 => [b’737014’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.4 => [b’1412554’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.5 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.6 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.7 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.8 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.9 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.10 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.11 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.12 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.13 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.14 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.15 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.16 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.17 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.18 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.19 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.20 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.21 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.22 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.23 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.24 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.25 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.26 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.65 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.66 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.67 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.68 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.69 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.70 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.71 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.72 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.73 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.74 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.75 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.76 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.77 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.78 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.79 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.80 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.81 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.82 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.83 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.84 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.85 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.86 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.87 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.88 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.89 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.90 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.19.91 => [b’0’] ‘COUNTER’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.20” on .1.3.6.1.2.1.2.2.1.20.1 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.2 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.3 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.4 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.5 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.6 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.7 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.8 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.9 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.10 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.11 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.12 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.13 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.14 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.15 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.16 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.17 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.18 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.19 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.20 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.21 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.22 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.23 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.24 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.25 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.26 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.65 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.66 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.67 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.68 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.69 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.70 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.71 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.72 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.73 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.74 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.75 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.76 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.77 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.78 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.79 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.80 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.81 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.82 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.83 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.84 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.85 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.86 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.87 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.88 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.89 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.90 => [b’0’] ‘COUNTER’.1.3.6.1.2.1.2.2.1.20.91 => [b’0’] ‘COUNTER’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.21” on Executing SNMP _Mode.GET of .1.3.6.1.2.1.2.2.1.21 on => [None] GAUGEExecuting BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.18” on .1.3.6.1.2.1.31.1.1.1.18.1 => [b’DV003-AP1’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.2 => [b’DV003-AP3’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.3 => [b’DV003-AP5’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.4 => [b’DV003-AP-5’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.5 => [b’Port 5’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.6 => [b’Port 6’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.7 => [b’Port 7’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.8 => [b’Port 8’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.9 => [b’Port 9’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.10 => [b’Port 10’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.11 => [b’Port 11’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.12 => [b’Port 12’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.13 => [b’Port 13’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.14 => [b’Port 14’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.15 => [b’Port 15’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.16 => [b’Port 16’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.17 => [b’Port 17’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.18 => [b’Port 18’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.19 => [b’Port 19’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.20 => [b’Port 20’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.21 => [b’Port 21’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.22 => [b’Port 22’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.23 => [b’Port 23’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.24 => [b’Port 24’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.25 => [b’SW-DV201-11 Port 26’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.26 => [b’SW-DV003-21 Port 26’] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.65 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.66 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.67 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.68 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.69 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.70 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.71 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.72 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.73 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.74 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.75 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.76 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.77 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.78 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.79 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.80 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.81 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.82 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.83 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.84 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.85 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.86 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.87 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.88 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.89 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.90 => [b’‘] ‘OCTETSTR’.1.3.6.1.2.1.31.1.1.1.18.91 => [b’‘] ‘OCTETSTR’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.2.2.1.6” on .1.3.6.1.2.1.2.2.1.6.1 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.2 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.3 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.4 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.5 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.6 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.7 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.8 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.9 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.10 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.11 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.12 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.13 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.14 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.15 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.16 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.17 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.18 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.19 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.20 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.21 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.22 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.23 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.24 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.25 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.26 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.65 => [b’$ZL\xa6\x84\x81’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.66 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.67 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.68 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.69 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.70 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.71 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.72 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.73 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.74 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.75 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.76 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.77 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.78 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.79 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.80 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.81 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.82 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.83 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.84 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.85 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.86 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.87 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.88 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.89 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.90 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’.1.3.6.1.2.1.2.2.1.6.91 => [b’$ZL\xa6\x84\x82’] ‘OCTETSTR’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.31.1.1.1.15” on .1.3.6.1.2.1.31.1.1.1.15.1 => [b’1000’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.2 => [b’1000’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.3 => [b’1000’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.4 => [b’1000’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.5 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.6 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.7 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.8 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.9 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.10 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.11 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.12 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.13 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.14 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.15 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.16 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.17 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.18 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.19 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.20 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.21 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.22 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.23 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.24 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.25 => [b’10000’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.26 => [b’10000’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.65 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.66 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.67 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.68 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.69 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.70 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.71 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.72 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.73 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.74 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.75 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.76 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.77 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.78 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.79 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.80 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.81 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.82 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.83 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.84 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.85 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.86 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.87 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.88 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.89 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.90 => [b’0’] ‘GAUGE’.1.3.6.1.2.1.31.1.1.1.15.91 => [b’0’] ‘GAUGE’snmp_info: Fetching data (SNMP walk cache is enabled: Use any locally cached information)Executing BULKWALK (v2c) of “.1.3.6.1.2.1.1.1” on .1.3.6.1.2.1.1.1.0 => [b’USW-Enterprise-24-PoE, 7.2.123.16565, Linux 3.6.5’] ‘OCTETSTR’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.1.2” on .1.3.6.1.2.1.1.2.0 => [b’.1.3.6.1.4.1.4413’] ‘OBJECTID’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.1.4” on .1.3.6.1.2.1.1.4.0 => [b’‘] ‘OCTETSTR’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.1.5” on .1.3.6.1.2.1.1.5.0 => [b’‘] ‘OCTETSTR’Executing BULKWALK (v2c) of “.1.3.6.1.2.1.1.6” on .1.3.6.1.2.1.1.6.0 => [b’‘] ‘OCTETSTR’snmp_uptime: Fetching data (SNMP walk cache is enabled: Use any locally cached information)Already fetched OID: .1.3.6.1.2.1.1.3Already fetched OID: .1.3.6.1.2.1.25.1.1Write data to cache file /omd/sites//tmp/check_mk/data_source_cache/snmp/checking/Trying to acquire lock on /omd/sites//tmp/check_mk/data_source_cache/snmp/checking/Got lock on /omd/sites//tmp/check_mk/data_source_cache/snmp/checking/Releasing lock on /omd/sites//tmp/check_mk/data_source_cache/snmp/checking/Released lock on /omd/sites//tmp/check_mk/data_source_cache/snmp/checking/[cpu_tracking] Stop [7f0617423710 - Snapshot(process=posix.times_result(user=0.10999999999999988, system=0.020000000000000018, children_user=0.0, children_system=0.0, elapsed=0.46000000089406967))][cpu_tracking] Start [7f0617b6acc0]e[33m+e[0m PARSE FETCHER RESULTSHostKey(Hostname ersetzt=’', source_type=<SourceType.HOST: 1>)  → Add sections: [‘if64’, ‘snmp_info’, ‘snmp_uptime’]Received no piggyback dataInterface DV003-AP-5 e[1me[32m[Slot: 0 Port: 4 Gigabit - Level], (up), MAC: , Speed: 1 GBit/s, In average 60min: 7.89 kBit/s (<0.01%), Out average 60min: 45.7 kBit/s (<0.01%)e[0mInterface DV003-AP1 e[1me[32m[Slot: 0 Port: 1 Gigabit - Level], (up), MAC: , Speed: 1 GBit/s, In average 60min: 9.22 kBit/s (<0.01%), Out average 60min: 46.8 kBit/s (<0.01%)e[0mInterface DV003-AP3 e[1me[32m[Slot: 0 Port: 2 Gigabit - Level], (up), MAC: , Speed: 1 GBit/s, In average 60min: 4.68 kBit/s (<0.01%), Out average 60min: 45.4 kBit/s (<0.01%)e[0mInterface DV003-AP5 e[1me[32m[Slot: 0 Port: 3 Gigabit - Level], (up), MAC: , Speed: 1 GBit/s, In average 60min: 10.1 kBit/s (<0.01%), Out average 60min: 46.8 kBit/s (<0.01%)e[0mInterface SW-DV003-21 Port 26 e[1me[31m[Slot: 0 Port: 26 10G - Level], (unknown)(!!), MAC: , Speed: 10 GBit/s, In average 60min: 37.7 Bit/s (<0.01%), Out average 60min: 65.6 kBit/s (<0.01%)e[0mInterface SW-DV201-11 Port 26 e[1me[31m[Slot: 0 Port: 25 10G - Level], (unknown)(!!), MAC: , Speed: 10 GBit/s, In average 60min: 76 kBit/s (<0.01%), Out average 60min: 37.9 kBit/s (<0.01%)e[0mSNMP Info            e[1me[32mUSW-Enterprise-24-PoE, 7.2.123.16565, Linux 3.6.5, , , e[0mUptime               e[1me[32mUp since 2025-12-28 15:13:35, Uptime: 10 days 23 hourse[0m[cpu_tracking] Stop [7f0617b6acc0 - Snapshot(process=posix.times_result(user=0.029999999999999805, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.029999997466802597))][snmp] Success, execution time 0.5 sec | execution_time=0.490 user_time=0.140 system_time=0.020 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.330Snapshot(process=posix.times_result(user=0.029999999999999805, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.029999997466802597))][snmp] Success, execution time 0.5 sec | execution_time=0.490 user_time=0.140 system_time=0.020 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.330
After updating Ubiquiti Unifi Network Application (v10.0.162) and Unifi Switches (v7.2.123) operational state on some Switch Interfaces changed to “unknown”, but some are still ok (up / down).
Interface SW-DV201-11 Port 26 e[1me[31m[Slot: 0 Port: 25 10G - Level], (unknown)(!!), MAC: <MAC-ersetzt>, Speed: 10 GBit/s, In average 60min: 76 kBit/s (<0.01%), Out average 60min: 37.9 kBit/s (<0.01%)e[0m
Resetting switch ports didn’t help. Also disabling/enabling did not change the state of the interface in CheckMK.
Anyone out there with similar issues in the past? Any idea how to solve, or further investigate this?
Any suggestions appreciated. Thanks in advance.
Cheers,
Sascha
Did you try a full discovery (Tabularasa)’?
Update: The problem has been solved by rebooting the switches.
Thanks for your reply.
