Site partially running after appliance upgrade to v1.4.7
Upgraded my virtual appliance from 1.4.6 to 1.4.7 and now when I start the site it gives me some errors. Everything except crontab shows as running. Here’s the error:
Could not start site monitoring:
Cannot execute omd command omd start monitoring: Starting mkeventd (builtin: syslog-udp,syslog-tcp,snmptrap)...OK
Starting liveproxyd...OK
Starting mknotifyd...OK
Starting rrdcached...OK
Starting cmc...OK
Starting apache...OK
Starting dcd...OK
Starting xinetd...OK
Initializing Crontab.../var/spool/cron/: mkstemp: Permission denied
close failed in file object destructor:
sys.excepthook is missing
lost sys.stderr
ERROR
I took a look at that directory and there are no crontabs listed there at all.
Could I just grab a copy from my previous backup and put it back and restart the site or is there a way to recreate the file?
you could try the following command:
dpkg-reconfigure cron
This will reset the permissions on the folders. Maybe this works directly in your case.
That did the trick. Thank you!
never saw this problem while updating appliances.
You should check if something was changed by an user.
Ralf
Hi Ralf, I’m currently the only user touching this app at the moment.
I had some strange problems a while ago when the disk ran out of space.
Ralf
Hi, I got the same issue like Iravelo after upgrading to 1.4.8.
Just adding a +1 here because I had the exact same situation on two separate appliances which were installed just a few months ago and were never tempered with whatsoever. Might be worth a look from the Devops building the appliance to make sure this is not a general error.
We got the same problems after upgrade to 1.4.8.
Fixed by dpkg-reconfigure cron.
We got the same problem after upgrade to 1.4.8
also Fixed by dpkg-reconfigure cron
