Hey All!
I’m working on setting up a POC of 2.0 enterprise and I have some questions specific to the slack integration. (these likely apply to cre as well)
I have some use cases where it might be nice to have a notification go to multiple slack channels/contact groups, but this does not seem possible in my testing with the current implementation. Had anyone been able to achieve having a single notification go to multiple slack channels? It seems to just end up going to the slack channel with the lowest logical rule.
Our slack users don’t use their check_mk username for their slack mention name, so mentions aren’t working properly. Is there any way to have the slack integration use a different user attribute for slack notification mentions?
Any insight into these two questions would be very helpful and appreciated.
Thanks!
Ryan
