It think it is possible to resolve this problem.
Create your status host on the main site and don’t use the ping as host check command.
Create a active check to test if port 6557 is available on the slave site. Then use this check result for your host check command.
If you want to extend this a little bit more you can use an active check what really tests if livestatus is answering your query.
create a normal status host with ping and one active check - “Check connecting to a TCP port” with port 6557
test if this is working
now change the host check command from ping to “Use the status of the service …” now insert here the name of your TCP port check like it is in your GUI
now check if the host shows down if you livestatus on the slave is stopped
if this is working you can use this status host inside your distributed configuration
I have Configured the “TCP Port connect to 6557” of all slaves as active check.
Configured Site configuration, Host check command to active check of respective slave.
Still the response of the multimaster is very slow. (But yes, it is better than earlier)
I have observed, some of slaves are UP and able to Telnet on port 6557 but livestatus query is taking longer time to respond. So Check_mk waits for (30 Sec) Timeout settings of respective slave in site configuration.
Is there any way to improve livestatus query response ??
