Small Helper Scripts for CLI
here some small helpers … feel free to add
mutch better :wink:
thats the reason … share to get better :wink:
Tool to read a password from the password store. Needs the password ID as argument.
#!/usr/bin/env python3
from cmk.utils import password_store
from sys import argv
pw = password_store.lookup(
    pw_id=argv[1],
    pw_file=password_store.password_store_path()
print(pw)
pycache files should be recompiled by checkmk, but we just got confirmation on a bug that this doesn’t always happen, hopefully the clean-reload gets simpler again once this is fixed.
however, I would think for discovery over UI and other things to pick up changes, a β€œomd restart automation-helper” and β€œomd restart ui-job-scheduler” would be good to be safe?
This is my restart script for development:
#!/bin/bash
for s in automation-helper ui-job-scheduler apache; do
  omd restart $s
done
cmk -R
Scripte for automatic creation of checkman basic-pages according the check_name or inventory_name
#!/bin/bash
# Arguments: SITE + PLUGINNAME
if [[ -z "$1" || -z "$2" ]]; then
    echo "Usage: $0 <site> <pluginname>"
    echo "Example: $0 test xiq"
    exit 1
fi
SITE="$1"
PLUGIN="$2"
BASE="/opt/omd/sites/${SITE}/local/lib/python3/cmk_addons/plugins/${PLUGIN}"
SRC="${BASE}/agent_based"
DST="${BASE}/checkman"
echo "Site:         $SITE"
echo "Pluginname:   $PLUGIN"
echo "Source:       $SRC"
echo "Destination:  $DST"
echo
mkdir -p "$DST"
# Function: extract plugin name
# Supports:
#   check_plugin_<name> = CheckPlugin(
#   CheckPlugin(name="<name>"
#   inventory_plugin_<name> = InventoryPlugin(
#   InventoryPlugin(name="<name>"
extract_plugin_name() {
    local file="$1"
    local NAME=""
    # Variant A1: variable starts with check_plugin_
    NAME=$(grep -Po 'check_plugin_\K[A-Za-z0-9_]+' "$file")
    if [[ -n "$NAME" ]]; then
        echo "$NAME"
        return
    fi
    # Variant A2: variable starts with inventory_plugin_
    NAME=$(grep -Po 'inventory_plugin_\K[A-Za-z0-9_]+' "$file")
        echo "$NAME"
        return
    fi
    # Variant B1: name="xyz" inside CheckPlugin(...)
    NAME=$(grep -Po 'CheckPlugin\s*\(\s*name\s*=\s*"\K[^"]+' "$file")
        echo "$NAME"
        return
    fi
    # Variant B2: name="xyz" inside InventoryPlugin(...)
    NAME=$(grep -Po 'InventoryPlugin\s*\(\s*name\s*=\s*"\K[^"]+' "$file")
        echo "$NAME"
        return
    fi
    echo ""
# MAIN LOOP
for file in "$SRC"/*.py; do
    filename=$(basename "$file")
    echo "Processing: $filename"
    CHECK_NAME=$(extract_plugin_name "$file")
    if [[ -z "$CHECK_NAME" ]]; then
        echo "  -> No CheckPlugin / InventoryPlugin found. Skipping."
        continue
    fi
    target="${DST}/${CHECK_NAME}"
    if [[ -e "$target" ]]; then
        echo "  -> [SKIP] ${CHECK_NAME} (already exists)"
    else
        echo "  -> [NEW]  Creating ${target}"
        cat > "$target" <<EOF
title: ${CHECK_NAME}
agents: piggyback
catalog: custom/${PLUGIN}
license: GPLv2
distribution: check_mk
description:
 This man page was auto-generated for plugin '${CHECK_NAME}'.
 Please update this description manually.
discovery:
 One service or inventory entry is created.
EOF
        # Clean unsafe characters (Windows CP1252, BOM, HTML entities)
        sed -i 's/\r$//' "$target"
        sed -i 's/\xEF\xBB\xBF//g' "$target"
        sed -i 's/\x96/-/g' "$target"
        sed -i 's/\x97/-/g' "$target"
        sed -i 's/\x91/'\''/g' "$target"
        sed -i 's/\x92/'\''/g' "$target"
        sed -i 's/\x93/"/g' "$target"
        sed -i 's/\x94/"/g' "$target"
        sed -i 's/&gt;/>/g' "$target"
        sed -i 's/&lt;/</g' "$target"
    fi
done
echo
echo "Done."
Sample call and output
OMD[test]:~$ ./create_checkman_from_checks.sh test xiq
Site:         test
Pluginname:   xiq
Source:       /opt/omd/sites/test/local/lib/python3/cmk_addons/plugins/xiq/agent_based
Destination:  /opt/omd/sites/test/local/lib/python3/cmk_addons/plugins/xiq/checkman
Processing: check_ap_clients.py
  -> [SKIP] xiq_ap_clients (already exists)
Processing: check_ap_uptime.py
  -> [SKIP] xiq_ap_uptime (already exists)
Processing: check_neighbors.py
  -> [SKIP] xiq_ap_neighbors (already exists)
Processing: check_radios.py
  -> [SKIP] xiq_radios (already exists)
Processing: check_rate_limits.py
  -> [SKIP] xiq_rate_limits (already exists)
Processing: check_ssid_clients.py
  -> [SKIP] xiq_ssid_clients (already exists)
Processing: check_status.py
  -> [SKIP] xiq_ap_status (already exists)
Processing: check_summary.py
  -> [SKIP] xiq_summary (already exists)
Processing: common.py
Processing: inventory_active_clients.py
  -> [NEW]  Creating /opt/omd/sites/test/local/lib/python3/cmk_addons/plugins/xiq/checkman/xiq_active_clients
Processing: inventory_devices.py
  -> [NEW]  Creating /opt/omd/sites/test/local/lib/python3/cmk_addons/plugins/xiq/checkman/xiq_devices
Processing: inventory_neighbors.py
  -> [NEW]  Creating /opt/omd/sites/test/local/lib/python3/cmk_addons/plugins/xiq/checkman/xiq_neighbors
Processing: inventory_radios_bssids.py
  -> [NEW]  Creating /opt/omd/sites/test/local/lib/python3/cmk_addons/plugins/xiq/checkman/xiq_ap_radios_plugin
xiq_ap_bssids_plugin
Processing: sections.py
and another script to create the hole plugin Folder structure
call
OMD[test]:~$ ./create_plugin_structure.sh xiq
#!/bin/bash
#  Create Checkmk extension folder structure for a plugin
#  Usage: ./create_plugin_structure.sh <pluginname>
if [[ -z "$1" ]]; then
    echo "Usage: $0 <pluginname>"
    echo "Example: $0 xiq"
    exit 1
fi
PLUGIN="$1"
# Base folder inside the site environment
BASE_DIR="$HOME/local/lib/python3/cmk_addons/plugins/${PLUGIN}"
echo "Creating plugin folder structure for plugin: ${PLUGIN}"
echo "Base directory: ${BASE_DIR}"
echo
# List all required subdirectories according to Checkmk plugin API layout:
DIRS=(
    "agent_based"
    "checkman"
    "graphing"
    "inventory"
    "libexec"
    "rulesets"
    "server_side_calls"
    "web"
# Create directories
for d in "${DIRS[@]}"; do
    TARGET="${BASE_DIR}/${d}"
    if [[ -d "$TARGET" ]]; then
        echo "[SKIP] $TARGET (already exists)"
    else
        echo "[NEW]  $TARGET"
        mkdir -p "$TARGET"
    fi
done
echo
echo "Plugin directory structure created successfully."
sample output:
Creating plugin folder structure for plugin: xiq
Base directory: /omd/sites/test/local/lib/python3/cmk_addons/plugins/xiq
[NEW]  .../agent_based
[NEW]  .../checkman
[NEW]  .../graphing
[NEW]  .../inventory
[NEW]  .../libexec
[NEW]  .../rulesets
[NEW]  .../server_side_calls
[NEW]  .../web
and now the advanced version for special_agent_skeleton creator:
Call & output
OMD[test]:~$ ./special_agent_skeleton.sh myapi <-- YOUR_PLUGIN_NAME
Special Agent Skeleton Created!
Plugin: myapi
Location: /omd/sites/test/local/lib/python3/cmk_addons/plugins/myapi
Files created:
  βœ“ /omd/sites/test/local/lib/python3/cmk_addons/plugins/myapi/libexec/agent_myapi
  βœ“ /omd/sites/test/local/lib/python3/cmk_addons/plugins/myapi/rulesets/special_agent.py
  βœ“ /omd/sites/test/local/lib/python3/cmk_addons/plugins/myapi/server_side_calls/special_agent.py
  βœ“ /omd/sites/test/local/lib/python3/cmk_addons/plugins/myapi/README.md
Features:
  βœ“ Username/Password authentication
  βœ“ Encrypted password storage
  βœ“ SSL verification (configurable)
  βœ“ HTTP requests with error handling
Next steps:
  1. Edit libexec/agent_myapi - customize API calls
  2. Run: cmk -R
  3. Configure in Setup β†’ Agents β†’ VM, Cloud, Container
  4. Test with: cmk -D <HOSTNAME>
#!/usr/bin/env bash
# Create Checkmk 2.4 Special Agent Skeleton (with Authentication Template)
# Usage:
#   ./mk_special_agent_skeleton.sh <plugin_family> [<site_user>] [--with-checks]
# Example:
#   ./mk_special_agent_skeleton.sh myapi              # minimal (agent + ruleset + call)
#   ./mk_special_agent_skeleton.sh myapi test --with-checks  # includes check plugin
# Template based on logincheck agent showing:
# - Username/Password handling (encrypted storage)
# - HTTP requests with requests library
# - SSL verification option
# - Proper error handling
# - Response parsing
# References:
# - https://docs.checkmk.com/latest/en/devel_intro.html (Introduction to developing extensions)
# - https://docs.checkmk.com/latest/en/devel_special_agents.html (Special agents development)
# - https://docs.checkmk.com/latest/en/devel_check_plugins.html (Agent-based check plug-ins)
# - https://docs.checkmk.com/latest/en/devel_check_plugins_rulesets.html (Rulesets API)
# - Help > Developer resources > Plug-in API references (in Checkmk GUI)
set -euo pipefail
# ----- Parse arguments --------------------------------------------------------
PLUGIN_FAMILY=""
SITE_USER=""
WITH_CHECKS=false
while [[ $# -gt 0 ]]; do
  case "$1" in
    --with-checks) WITH_CHECKS=true; shift ;;
      if [[ -z "$PLUGIN_FAMILY" ]]; then
        PLUGIN_FAMILY="$1"
      elif [[ -z "$SITE_USER" ]]; then
        SITE_USER="$1"
      else
        echo "Unknown argument: $1" >&2
        exit 1
      fi
      shift
  esac
done
  echo "Usage: $0 <plugin_family> [<site_user>] [--with-checks]"
  exit 1
fi
# Validate plugin family name
if [[ ! "$PLUGIN_FAMILY" =~ ^[a-zA-Z0-9_][-a-zA-Z0-9_]*$ ]]; then
  echo "Error: <plugin_family> must match [a-zA-Z0-9_][-_a-zA-Z0-9_]*"
  exit 2
fi
# Base directory
BASE_DIR="${HOME}/local/lib/python3/cmk_addons/plugins/${PLUGIN_FAMILY}"
AGENT_BASENAME="${PLUGIN_FAMILY}"
AGENT_EXEC="agent_${AGENT_BASENAME}"
mkdir -p "${BASE_DIR}/libexec"
mkdir -p "${BASE_DIR}/rulesets"
mkdir -p "${BASE_DIR}/server_side_calls"
if [[ "$WITH_CHECKS" == true ]]; then
  mkdir -p "${BASE_DIR}/agent_based"
fi
# SPECIAL AGENT EXECUTABLE (with authentication)
AGENT_PATH="${BASE_DIR}/libexec/${AGENT_EXEC}"
if [[ ! -e "${AGENT_PATH}" ]]; then
  cat > "${AGENT_PATH}" <<'EOF'
# -*- coding: utf-8 -*-
Special Agent for PLUGIN_FAMILY
Connects to API with authentication and retrieves monitoring data.
import argparse
import json
import sys
from typing import Any
import requests
def fetch_api_data(
    url: str,
    username: str,
    password: str,
    insecure: bool = False,
    timeout: int = 60,
) -> dict[str, Any]:
    Fetch data from API endpoint with authentication.
    Args:
        url: API endpoint URL
        username: Authentication username
        password: Authentication password
        insecure: Disable SSL verification
        timeout: Request timeout in seconds
    Returns:
        Dictionary with API response data
    Raises:
        requests.RequestException: On connection/request errors
    session = requests.Session()
    if insecure:
        session.verify = False
        # Suppress InsecureRequestWarning
        import urllib3
        urllib3.disable_warnings(urllib3.exceptions.InsecureRequestWarning)
    # Configure authentication - adjust based on your API
    # Option 1: Basic Auth
    # session.auth = (username, password)
    # Option 2: Token-based (login first)
    payload = {
        "username": username,
        "password": password,
    headers = {
        "Content-Type": "application/json",
        "Accept": "application/json",
    # Login request (adjust endpoint and method as needed)
    try:
        login_resp = session.post(
            url,
            json=payload,
            headers=headers,
            timeout=timeout,
            allow_redirects=True,
        login_resp.raise_for_status()
    except requests.RequestException as e:
        raise requests.RequestException(f"Login failed: {e}")
    # Extract token or session cookie (adjust based on your API)
    # token = login_resp.json().get("token")
    # session.headers.update({"Authorization": f"Bearer {token}"})
    # Fetch actual data (replace with your API endpoints)
    # Example: Get system status
    try:
        status_resp = session.get(
            f"{url}/status",  # Adjust endpoint
            timeout=timeout,
        status_resp.raise_for_status()
        data = status_resp.json()
        raise requests.RequestException(f"Data fetch failed: {e}")
    return data
def output_section(name: str, data: Any) -> None:
    Output a Checkmk agent section.
    For JSON data, output on a single line so the check plugin
    can parse it correctly with itertools + json.loads().
    See: https://docs.checkmk.com/latest/en/devel_special_agents.html
    print(f"<<<{name}>>>")
    if isinstance(data, (dict, list)):
        # Output JSON on a single line
        print(json.dumps(data))
    elif isinstance(data, str):
        print(data)
    else:
        print(str(data))
def main() -> int:
    parser = argparse.ArgumentParser(
        description="Checkmk special agent: PLUGIN_FAMILY"
    parser.add_argument("--url", required=True, help="API endpoint URL")
    parser.add_argument("--username", required=True, help="Authentication username")
    parser.add_argument("--password", required=True, help="Authentication password")
    parser.add_argument("--insecure", action="store_true", help="Disable SSL verification")
    parser.add_argument("--timeout", type=int, default=60, help="Request timeout (seconds)")
    args = parser.parse_args()
    try:
        # Fetch data from API
        data = fetch_api_data(
            url=args.url,
            username=args.username,
            password=args.password,
            insecure=args.insecure,
            timeout=args.timeout,
        # Output section(s) - adjust based on your data structure
        # Example: Main status section
        output_section("PLUGIN_FAMILY_status", {
            "status": data.get("status", "UNKNOWN"),
            "code": data.get("code", "N/A"),
            "message": data.get("message", "No message"),
        # Example: Additional data section (if available)
        if "items" in data:
            output_section("PLUGIN_FAMILY_items", data["items"])
        return 0
        # Output error section so check plugin can handle it
            "status": "FAILED",
            "code": "EXCEPTION",
            "message": str(e)[:500],  # Limit error message length
        return 0  # Return 0 to allow check plugin to process error
    except Exception as e:
        print(f"ERROR: {e}", file=sys.stderr)
        return 1
if __name__ == "__main__":
    sys.exit(main())
EOF
  sed -i "s/PLUGIN_FAMILY/${PLUGIN_FAMILY}/g" "${AGENT_PATH}"
  chmod +x "${AGENT_PATH}"
fi
# SPECIAL AGENT RULESET (with Password field)
RULESET_PATH="${BASE_DIR}/rulesets/special_agent.py"
if [[ ! -e "${RULESET_PATH}" ]]; then
  cat > "${RULESET_PATH}" <<'EOF'
"""Special Agent Ruleset for PLUGIN_FAMILY"""
from cmk.rulesets.v1 import Title, Help
from cmk.rulesets.v1.form_specs import (
    DefaultValue,
    DictElement,
    Dictionary,
    migrate_to_password,
    Password,
    String,
    SingleChoice,
    SingleChoiceElement,
from cmk.rulesets.v1.rule_specs import SpecialAgent, Topic
def _parameter_form_PLUGIN_FAMILY():
    return Dictionary(
        title=Title("PLUGIN_FAMILY_UPPER API Connection"),
        help_text=Help(
            "This special agent connects to the PLUGIN_FAMILY_UPPER API "
            "using username/password authentication and retrieves monitoring data."
        elements={
            "url": DictElement(
                required=True,
                parameter_form=String(
                    title=Title("API Endpoint URL"),
                    help_text=Help(
                        "The full URL of the API endpoint. "
                        "Example: https://api.example.com or https://192.168.1.100:8443"
                    prefill=DefaultValue("https://"),
            "username": DictElement(
                required=True,
                    title=Title("Username"),
                    help_text=Help("Username for API authentication"),
            "password": DictElement(
                required=True,
                parameter_form=Password(
                    title=Title("Password"),
                    help_text=Help("Password (stored encrypted)"),
                    migrate=migrate_to_password,
            "insecure": DictElement(
                required=False,
                parameter_form=SingleChoice(
                    title=Title("SSL Certificate Verification"),
                    help_text=Help(
                        "Choose whether to verify SSL certificates. "
                        "Disabling verification should only be used for testing!"
                    elements=[
                        SingleChoiceElement(
                            name="verify",
                            title=Title("Verify SSL certificates (recommended)"),
                            name="insecure",
                            title=Title("Disable SSL verification (insecure!)"),
                    prefill=DefaultValue("verify"),
rule_spec_special_agent_PLUGIN_FAMILY = SpecialAgent(
    name="PLUGIN_FAMILY",
    title=Title("PLUGIN_FAMILY_UPPER"),
    topic=Topic.CLOUD,  # Adjust: CLOUD, GENERAL, SERVER_HARDWARE, etc.
    parameter_form=_parameter_form_PLUGIN_FAMILY,
EOF
  sed -i "s/PLUGIN_FAMILY/${AGENT_BASENAME}/g" "${RULESET_PATH}"
  sed -i "s/PLUGIN_FAMILY_UPPER/${PLUGIN_FAMILY^^}/g" "${RULESET_PATH}"
  chmod 0644 "${RULESET_PATH}"
fi
# SERVER-SIDE CALL (with password handling)
CALL_PATH="${BASE_DIR}/server_side_calls/special_agent.py"
if [[ ! -e "${CALL_PATH}" ]]; then
  cat > "${CALL_PATH}" <<'EOF'
"""Server-side call registration for PLUGIN_FAMILY"""
from cmk.server_side_calls.v1 import (
    SpecialAgentCommand,
    SpecialAgentConfig,
    noop_parser,
def _agent_arguments(params, host_config):
    """Generate command line arguments for the special agent."""
    args = []
    # Required parameters
    args.extend(["--url", params["url"]])
    args.extend(["--username", params["username"]])
    args.extend(["--password", params["password"].unsafe()])
    # Optional: SSL verification
    if params.get("insecure") == "insecure":
        args.append("--insecure")
    yield SpecialAgentCommand(command_arguments=args)
special_agent_PLUGIN_FAMILY = SpecialAgentConfig(
    parameter_parser=noop_parser,
    commands_function=_agent_arguments,
EOF
  sed -i "s/PLUGIN_FAMILY/${AGENT_BASENAME}/g" "${CALL_PATH}"
  chmod 0644 "${CALL_PATH}"
fi
# AGENT-BASED CHECK PLUGIN (optional)
  CHECK_PATH="${BASE_DIR}/agent_based/${AGENT_BASENAME}.py"
  if [[ ! -e "${CHECK_PATH}" ]]; then
    cat > "${CHECK_PATH}" <<'EOF'
"""Agent-based check plugin for PLUGIN_FAMILY"""
import itertools
import json
from cmk.agent_based.v2 import (
    AgentSection,
    CheckPlugin,
    CheckResult,
    DiscoveryResult,
    Result,
    Service,
    State,
    StringTable,
def parse_PLUGIN_FAMILY_status(string_table: StringTable) -> dict | None:
    Parse the <<<PLUGIN_FAMILY_status>>> section.
    The check plug-in receives the agent section as a two-dimensional
    list ('list of lists') of strings. We convert this to a flat list,
    concatenate with spaces, and parse as JSON.
    if not string_table:
        return None
    try:
        # Flatten two-dimensional list to one-dimensional
        flatlist = list(itertools.chain.from_iterable(string_table))
        # Concatenate array with spaces and parse JSON
        parsed = json.loads(" ".join(flatlist))
        return parsed
    except (json.JSONDecodeError, ValueError):
        return None
def discover_PLUGIN_FAMILY_status(section: dict | None) -> DiscoveryResult:
    """Discover the PLUGIN_FAMILY status service."""
    if section is not None:
        yield Service()
def check_PLUGIN_FAMILY_status(section: dict | None) -> CheckResult:
    """Check the PLUGIN_FAMILY status."""
    if section is None:
        yield Result(
            state=State.UNKNOWN,
            summary="No data received from agent"
        return
    status = section.get("status", "UNKNOWN")
    code = section.get("code", "N/A")
    message = section.get("message", "No message")
    # Determine check state based on status
    if status == "OK" or code == "200":
        state = State.OK
        summary = f"API connection successful (Code: {code})"
    elif status == "FAILED" or status == "EXCEPTION":
        state = State.CRIT
        summary = f"API connection failed (Code: {code})"
    else:
        state = State.WARN
        summary = f"Unknown status: {status} (Code: {code})"
    yield Result(
        state=state,
        summary=summary,
        details=f"Status: {status}\nCode: {code}\nMessage: {message}"
# Section registration
agent_section_PLUGIN_FAMILY_status = AgentSection(
    name="PLUGIN_FAMILY_status",
    parse_function=parse_PLUGIN_FAMILY_status,
# Check plugin registration
check_plugin_PLUGIN_FAMILY_status = CheckPlugin(
    service_name="PLUGIN_FAMILY_UPPER Status",
    sections=["PLUGIN_FAMILY_status"],
    discovery_function=discover_PLUGIN_FAMILY_status,
    check_function=check_PLUGIN_FAMILY_status,
EOF
    sed -i "s/PLUGIN_FAMILY/${AGENT_BASENAME}/g" "${CHECK_PATH}"
    sed -i "s/PLUGIN_FAMILY_UPPER/${PLUGIN_FAMILY^^}/g" "${CHECK_PATH}"
    chmod 0644 "${CHECK_PATH}"
  fi
fi
# README
README_PATH="${BASE_DIR}/README.md"
if [[ ! -e "${README_PATH}" ]]; then
  cat > "${README_PATH}" <<EOF
# ${PLUGIN_FAMILY} – Checkmk Special Agent
Special agent for monitoring ${PLUGIN_FAMILY^^} via API with authentication.
## Features
- Username/Password authentication
- SSL certificate verification (optional disable)
- Encrypted password storage
- HTTP request error handling
- Structured agent output
## Quick Start
### 1. Customize the Agent
Edit \`libexec/agent_${AGENT_BASENAME}\`:
\`\`\`python
# Adjust authentication method (Basic Auth, Token, etc.)
# Modify API endpoints
# Add custom data parsing
### 2. Activate Plugin
\`\`\`bash
cmk -R
### 3. Configure in GUI
**Setup β†’ Agents β†’ VM, Cloud, Container β†’ ${PLUGIN_FAMILY^^}**
- Enter API URL
- Provide username/password
- Optional: Disable SSL verification
### 4. Test
\`\`\`bash
# See generated command
cmk -D <HOSTNAME>
# Test agent manually
~/local/lib/python3/cmk_addons/plugins/${PLUGIN_FAMILY}/libexec/agent_${AGENT_BASENAME} \\
  --url "https://api.example.com" \\
  --username "myuser" \\
  --password "mypass"
# Run discovery
cmk -I <HOSTNAME>
## Authentication Methods
The template supports multiple authentication patterns:
### Basic Auth
\`\`\`python
### Token-based (Login + Bearer)
\`\`\`python
# Login to get token
resp = session.post(url, json={"username": username, "password": password})
token = resp.json()["token"]
# Use token in headers
### API Key
\`\`\`python
session.headers.update({"X-API-Key": api_key})
## Directory Structure
${PLUGIN_FAMILY}/
β”œβ”€β”€ libexec/agent_${AGENT_BASENAME}           # Special agent (Python)
β”œβ”€β”€ rulesets/special_agent.py                 # GUI configuration
β”œβ”€β”€ server_side_calls/special_agent.py        # Command generation
EOF
    cat >> "${README_PATH}" <<EOF
β”œβ”€β”€ agent_based/${AGENT_BASENAME}.py          # Check plugin
EOF
  fi
└── README.md
## Password Security
- Passwords are stored encrypted in Checkmk
- Use \`params["password"].unsafe()\` to access in server_side_calls
- Never log passwords in plain text
## References
- [Introduction to Developing Extensions](https://docs.checkmk.com/latest/en/devel_intro.html)
- [Developing Special Agents](https://docs.checkmk.com/latest/en/devel_special_agents.html)
- [Developing Agent-based Check Plug-ins](https://docs.checkmk.com/latest/en/devel_check_plugins.html)
- [Rulesets API](https://docs.checkmk.com/latest/en/devel_check_plugins_rulesets.html)
- [Password Handling in Rulesets](https://docs.checkmk.com/latest/en/devel_check_plugins_rulesets.html#passwords)
- **In Checkmk GUI:** Help > Developer resources > Plug-in API references
EOF
fi
# OWNERSHIP
if [[ -n "${SITE_USER}" ]]; then
  chown -R "${SITE_USER}:${SITE_USER}" "${BASE_DIR}"
fi
# SUMMARY
echo "========================================="
echo "Special Agent Skeleton Created!"
echo "Plugin: ${PLUGIN_FAMILY}"
echo "Location: ${BASE_DIR}"
echo ""
echo "Files created:"
echo "  βœ“ ${AGENT_PATH}"
echo "  βœ“ ${RULESET_PATH}"
echo "  βœ“ ${CALL_PATH}"
  echo "  βœ“ ${CHECK_PATH}"
fi
echo "  βœ“ ${README_PATH}"
echo ""
echo "Features:"
echo "  βœ“ Username/Password authentication"
echo "  βœ“ Encrypted password storage"
echo "  βœ“ SSL verification (configurable)"
echo "  βœ“ HTTP requests with error handling"
echo ""
echo "Next steps:"
echo "  1. Edit libexec/agent_${AGENT_BASENAME} - customize API calls"
echo "  2. Run: cmk -R"
echo "  3. Configure in Setup β†’ Agents β†’ VM, Cloud, Container"
echo "  4. Test with: cmk -D <HOSTNAME>"
echo ""
and i had extend the restart script for development …
Call & Output
OMD[test]:~$ ./dev_restart_adv.sh --help
Usage: ./dev_restart_adv.sh [OPTIONS]
Restart Checkmk development environment with various options.
Options:
  --full, -f           Full OMD restart (all services)
  --clean, -c          Clean Python cache before restart
  --validate, -v       Validate Python syntax before restart
  --log, -l            Tail web.log after restart
  --discover <HOST>    Run service discovery on HOST after restart
  --verbose            Show detailed output
  --help, -h           Show this help
Examples:
  ./dev_restart_adv.sh                           # Quick restart
  ./dev_restart_adv.sh --clean                   # Clean + restart
  ./dev_restart_adv.sh --full --clean            # Full restart with cache clean
  ./dev_restart_adv.sh -c -v                     # Clean + validate + restart
  ./dev_restart_adv.sh --clean --discover myhost # Clean + restart + discovery
  ./dev_restart_adv.sh --log                     # Restart + monitor logs
Development Workflow:
  1. Make code changes
  2. Run: ./dev_restart_adv.sh --clean --validate
  3. Test in GUI or with: cmk -I <hostname>
  4. Check logs with: tail -f ~/var/log/web.log
dev_restart_adv.sh
#!/bin/bash
# Checkmk Advanced Development Restart Script
# Comprehensive restart script for Checkmk plugin development with:
# - Selective service restarts
# - Python cache cleaning
# - Syntax validation
# - Log monitoring
# - Auto-discovery option
set -euo pipefail
# ----- Configuration ----------------------------------------------------------
QUICK_SERVICES=("automation-helper" "ui-job-scheduler" "apache")
SITE_NAME=$(omd config show CORE 2>/dev/null | head -1 || echo "unknown")
# Flags
FULL_MODE=false
CLEAN_CACHE=false
VALIDATE=false
TAIL_LOG=false
DISCOVER_HOST=""
VERBOSE=false
  case "$1" in
    --full|-f)
      FULL_MODE=true
      shift
    --clean|-c)
      CLEAN_CACHE=true
      shift
    --validate|-v)
      VALIDATE=true
      shift
    --log|-l)
      TAIL_LOG=true
      shift
    --discover)
      DISCOVER_HOST="$2"
      shift 2
    --verbose)
      VERBOSE=true
      shift
    --help|-h)
      cat <<EOF
Usage: $0 [OPTIONS]
Options:
Examples:
  $0                           # Quick restart
  $0 --clean                   # Clean + restart
  $0 --full --clean            # Full restart with cache clean
  $0 -c -v                     # Clean + validate + restart
  $0 --clean --discover myhost # Clean + restart + discovery
  $0 --log                     # Restart + monitor logs
  2. Run: $0 --clean --validate
EOF
      exit 0
      echo "Unknown option: $1" >&2
      echo "Use --help for usage information"
      exit 1
  esac
done
# ----- Helper functions -------------------------------------------------------
log_step() {
  echo "==> $1"
log_success() {
  echo "    βœ“ $1"
log_warn() {
  echo "    ⚠ Warning: $1" >&2
log_error() {
  echo "    βœ— Error: $1" >&2
# ----- Validate Python syntax (optional) --------------------------------------
if [[ "$VALIDATE" == true ]]; then
  log_step "Validating Python syntax..."
  ERROR_COUNT=0
  # Check all Python files in cmk_addons
  while IFS= read -r -d '' pyfile; do
    if ! python3 -m py_compile "$pyfile" 2>/dev/null; then
      log_error "Syntax error in: $pyfile"
      ERROR_COUNT=$((ERROR_COUNT + 1))
    elif [[ "$VERBOSE" == true ]]; then
      log_success "OK: $pyfile"
    fi
  done < <(find ~/local/lib/python3/cmk_addons -name "*.py" -print0 2>/dev/null)
  if [[ $ERROR_COUNT -gt 0 ]]; then
    log_error "Found $ERROR_COUNT syntax error(s). Fix them before restarting!"
    exit 1
  fi
  log_success "All Python files validated"
fi
# ----- Clean Python cache (optional) ------------------------------------------
if [[ "$CLEAN_CACHE" == true ]]; then
  log_step "Cleaning Python cache..."
  CACHE_DIRS=0
  CACHE_FILES=0
  # Count and remove __pycache__ directories
  while IFS= read -r dir; do
    CACHE_DIRS=$((CACHE_DIRS + 1))
  done < <(find ~/local/lib/python3/cmk_addons -type d -name "__pycache__" 2>/dev/null)
  find ~/local/lib/python3/cmk_addons -type d -name "__pycache__" -exec rm -rf {} + 2>/dev/null || true
  # Count and remove .pyc files
  while IFS= read -r file; do
    CACHE_FILES=$((CACHE_FILES + 1))
  done < <(find ~/local/lib/python3/cmk_addons -name "*.pyc" 2>/dev/null)
  find ~/local/lib/python3/cmk_addons -name "*.pyc" -delete 2>/dev/null || true
    log_success "Removed $CACHE_DIRS cache directories and $CACHE_FILES .pyc files"
  else
    log_success "Cache cleaned"
  fi
fi
# ----- Restart services -------------------------------------------------------
if [[ "$FULL_MODE" == true ]]; then
  log_step "Full OMD restart..."
    omd stop
    sleep 1
    omd start
  else
    omd stop >/dev/null 2>&1
    sleep 1
    omd start >/dev/null 2>&1
  fi
  log_success "All services restarted"
else
  log_step "Quick restart (GUI services only)..."
  for service in "${QUICK_SERVICES[@]}"; do
      echo "    Restarting $service..."
    fi
    if omd restart "$service" >/dev/null 2>&1; then
        log_success "$service restarted"
      fi
    else
      log_warn "Could not restart $service (may not be running)"
    fi
  done
  log_success "GUI services restarted"
fi
# ----- Reload Checkmk configuration -------------------------------------------
log_step "Reloading Checkmk configuration..."
  cmk -R
else
  cmk -R >/dev/null 2>&1
fi
log_success "Configuration reloaded"
# ----- Run service discovery (optional) ---------------------------------------
if [[ -n "$DISCOVER_HOST" ]]; then
  log_step "Running service discovery on $DISCOVER_HOST..."
  if cmk -I "$DISCOVER_HOST" 2>&1 | grep -q "SUCCESS"; then
    log_success "Discovery completed for $DISCOVER_HOST"
  else
    log_warn "Discovery may have failed for $DISCOVER_HOST"
  fi
fi
# ----- Status summary ---------------------------------------------------------
echo ""
echo "Development Environment Ready!"
[[ "$VALIDATE" == true ]] && echo "βœ“ Python syntax validated"
[[ "$CLEAN_CACHE" == true ]] && echo "βœ“ Python cache cleaned"
[[ "$FULL_MODE" == true ]] && echo "βœ“ All OMD services restarted" || echo "βœ“ GUI services restarted"
echo "βœ“ Configuration reloaded"
[[ -n "$DISCOVER_HOST" ]] && echo "βœ“ Discovery run on $DISCOVER_HOST"
echo ""
echo "Tips:"
echo "  β€’ Check service status: omd status"
echo "  β€’ View web logs: tail -f ~/var/log/web.log"
echo "  β€’ Test check: cmk -vvn <HOSTNAME>"
echo "  β€’ List plugins: cmk --list-checks | grep <name>"
# ----- Tail logs (optional) ---------------------------------------------------
if [[ "$TAIL_LOG" == true ]]; then
  echo ""
  echo "==> Monitoring ~/var/log/web.log (Ctrl+C to stop)..."
  echo ""
fi
debug script for CustomSidebarSnapins:
Call & Output
OMD[test]:~$ python3 debug_registration_snapin.py
CHECKMK SIDEBAR SNAPIN REGISTRATION DEBUGGER
Run at: 2026-02-13 08:55:27
Scanning directory: /omd/sites/test/local/lib/python3/cmk/gui/plugins/sidebar
Found 2 Python files:
   β€’ simple_test_snapin.py
   β€’ ticket_test.py
Testing import of each snapin...
β†’ Testing: simple_test_snapin
   βœ“ Module imported successfully
   βœ“ Found snapin class(es): ['CustomizableSidebarSnapin', 'HostMatrixSnapin']
β†’ Testing: ticket_test
   βœ“ Found snapin class(es): ['CustomizableSidebarSnapin', 'TicketTestSnapin']
FINAL SUMMARY
Total files scanned     : 2
Successfully loaded     : 2
Failed / problematic    : 0
SUCCESSFUL SNAPINS:
   βœ“ simple_test_snapin β†’ ['CustomizableSidebarSnapin', 'HostMatrixSnapin']
   βœ“ ticket_test β†’ ['CustomizableSidebarSnapin', 'TicketTestSnapin']
EMPFEHLUNGEN:
β€’ Wenn ein Snapin 'IMPORT_ERROR' zeigt β†’ falscher Import-Pfad
β€’ Wenn 'NO_SNAPIN' β†’ fehlender @snapin_registry.register
β€’ Wenn 'EXCEPTION' β†’ Syntax- oder Laufzeitfehler in der Datei
# debug_snapins.py - Detaillierter Snapin-Import-Debugger
import sys
import os
import importlib
import traceback
from pathlib import Path
from datetime import datetime
print("=" * 90)
print("CHECKMK SIDEBAR SNAPIN REGISTRATION DEBUGGER")
print("=" * 90)
print(f"Run at: {datetime.now().strftime('%Y-%m-%d %H:%M:%S')}\n")
# 1. Verzeichnis ermitteln
site_root = os.environ.get('OMD_ROOT')
if not site_root:
    print("ERROR: OMD_ROOT Umgebungsvariable nicht gesetzt!")
    sys.exit(1)
plugin_dir = Path(site_root) / "local" / "lib" / "python3" / "cmk" / "gui" / "plugins" / "sidebar"
print(f"Scanning directory: {plugin_dir}\n")
# 2. Alle .py Dateien finden (außer __init__.py)
py_files = [f for f in plugin_dir.glob("*.py") if f.name != "__init__.py"]
print(f"Found {len(py_files)} Python files:\n")
for f in sorted(py_files):
    print(f"   β€’ {f.name}")
print("\n" + "=" * 90)
print("Testing import of each snapin...\n")
results = []
for py_file in sorted(py_files):
    module_name = py_file.stem
    full_module = f"cmk.gui.plugins.sidebar.{module_name}"
    print(f"β†’ Testing: {module_name}")
    try:
        # Modul importieren
        module = importlib.import_module(full_module)
        print("   βœ“ Module imported successfully")
        # PrΓΌfen auf Snapin-Registrierung
        snapin_classes = []
        for name, obj in module.__dict__.items():
            if isinstance(obj, type) and hasattr(obj, 'type_name'):
                snapin_classes.append(name)
        if snapin_classes:
            print(f"   βœ“ Found snapin class(es): {snapin_classes}")
            results.append((module_name, "SUCCESS", snapin_classes))
        else:
            print("   ⚠ No snapin class found (missing @snapin_registry.register?)")
            results.append((module_name, "NO_SNAPIN", []))
    except ImportError as e:
        print(f"   βœ— ImportError: {e}")
        results.append((module_name, "IMPORT_ERROR", str(e)))
        print(f"   βœ— Exception: {e}")
        traceback.print_exc()
        results.append((module_name, "EXCEPTION", str(e)))
    print("-" * 70)
# 3. Zusammenfassung
print("FINAL SUMMARY")
print("=" * 90)
success = [r for r in results if r[1] == "SUCCESS"]
failed = [r for r in results if r[1] != "SUCCESS"]
print(f"Total files scanned     : {len(results)}")
print(f"Successfully loaded     : {len(success)}")
print(f"Failed / problematic    : {len(failed)}\n")
if success:
    print("SUCCESSFUL SNAPINS:")
    for name, _, classes in success:
        print(f"   βœ“ {name} β†’ {classes}")
if failed:
    print("\nPROBLEMATIC FILES:")
    for name, status, details in failed:
        print(f"   βœ— {name}: {status}")
        if details:
            print(f"      β†’ {details[:100]}...")
print("EMPFEHLUNGEN:")
print("β€’ Wenn ein Snapin 'IMPORT_ERROR' zeigt β†’ falscher Import-Pfad")
print("β€’ Wenn 'NO_SNAPIN' β†’ fehlender @snapin_registry.register")
print("β€’ Wenn 'EXCEPTION' β†’ Syntax- oder Laufzeitfehler in der Datei")
print("=" * 90)
Thanks, nice one!
Based on this, here’s a version to just list all passwords and their IDs:
# Load full password store
store = password_store.load(password_store.password_store_path())
for pw_id, entry in store.items():
    try:
        # Resolve/decrypt the password
            pw_id=pw_id,
        pw = f"<error: {e}>"
    print(f"{pw_id}: {pw}")
and here a script who extract a list of metrics from rrd
get_metrics.sh
#!/bin/bash
# Hilfe bei falschen Argumenten
if [ "$#" -lt 3 ]; then
    echo "Benutzung:"
    echo "  1. Letzte 24h: $0 <host> <service> <MODE>"
    echo "  2. Zeitraum:   $0 <host> <service> <MODE> \"YYYY-MM-DD HH:MM\" \"YYYY-MM-DD HH:MM\""
    echo ""
    echo "Beispiel: $0 dezili CPU_load MAX \"2026-05-07 10:00\" \"2026-05-07 14:00\""
    exit 1
fi
HOST="$1"
SERVICE="${2// /_}"
MODE="$3"
# Zeitlogik
if [ "$#" -eq 5 ]; then
    # Benutzerdefinierter Zeitraum
    EPOCH_START=$(date -d "$4" +%s)
    EPOCH_END=$(date -d "$5" +%s)
else
    # Default: Letzte 24 Stunden
    EPOCH_START=$(date --date='24 hours ago' +%s)
    EPOCH_END=$(date +%s)
fi
# Pfad zur RRD-Datei
RRD_FILE="$OMD_ROOT/var/check_mk/rrd/${HOST}/${SERVICE}.rrd"
if [[ ! -f "$RRD_FILE" ]]; then
    echo "Fehler: Datei nicht gefunden: $RRD_FILE"
    exit 1
fi
echo "--- Export: $HOST | $SERVICE | Modus: $MODE ---"
echo "Zeitraum: $(date -d @$EPOCH_START) bis $(date -d @$EPOCH_END)"
echo "------------------------------------------------------------"
echo "Zeitstempel;Werte"
# Abfrage und Formatierung
rrdtool fetch "$RRD_FILE" "$MODE" --start "$EPOCH_START" --end "$EPOCH_END" | \
awk -F': ' '
    NR > 2 {
        timestamp = $1;
        gsub(/^[ \t]+|[ \t]+$/, "", timestamp);
        values_raw = $2;
        if (values_raw !~ /nan/ && values_raw != "") {
            # Datum konvertieren
            cmd = "date -d @" timestamp " +\"%d.%m.%Y %H:%M:%S\""
            cmd | getline readable
            close(cmd)
            split(values_raw, v, " ");
            output_line = readable;
            for (i=1; i<=length(v); i++) {
                if (v[i] != "") {
                    output_line = output_line ";" sprintf("%.2f", v[i]);
            print output_line;
Script to force-remove a broken or partially deleted Checkmk OMD site
cleanup_broken_site.sh
#!/bin/bash
# Force-remove a broken or partially deleted Checkmk OMD site.
# Usage:  sudo bash cleanup_site.sh <site_name>
set -euo pipefail
SITE="${1:-}"
# Validation
if [[ -z "$SITE" ]]; then
    echo "Usage: $0 <site_name>"
    echo "Example: $0 test2"
    exit 1
fi
if [[ $EUID -ne 0 ]]; then
    echo "ERROR: Script must be run as root (sudo)."
    exit 1
fi
echo "============================================================"
echo " Checkmk Site Cleanup: $SITE"
echo ""
read -rp "Are you sure you want to remove site '$SITE'? [yes/NO]: " CONFIRM
if [[ "$CONFIRM" != "yes" ]]; then
    echo "Aborted."
    exit 0
fi
# Stop site if running (ignore errors if user/site is broken)
echo "[1/6] Stopping site (if running) ..."
omd stop "$SITE" 2>/dev/null || true
# Unmount tmpfs
echo "[2/6] Unmounting tmpfs ..."
TMPFS_PATH="/omd/sites/${SITE}/tmp"
if mountpoint -q "$TMPFS_PATH" 2>/dev/null; then
    umount -f "$TMPFS_PATH" && echo "      Unmounted: $TMPFS_PATH"
else
    echo "      Not mounted, skipping."
fi
# Remove fstab entry
echo "[3/6] Removing fstab entry ..."
if grep -q "$SITE" /etc/fstab; then
    cp /etc/fstab /etc/fstab.bak_cleanup_"$SITE"
    sed -i "/$SITE/d" /etc/fstab
    echo "      Removed from /etc/fstab (backup: /etc/fstab.bak_cleanup_$SITE)"
else
    echo "      No fstab entry found, skipping."
fi
# Remove site directory
echo "[4/6] Removing site directory /omd/sites/$SITE ..."
if [[ -d "/omd/sites/$SITE" ]]; then
    rm -rf "/omd/sites/${SITE}"
    echo "      Removed."
else
    echo "      Directory not found, skipping."
fi
# Remove system user and group
echo "[5/6] Removing system user and group ..."
if id "$SITE" &>/dev/null; then
    userdel "$SITE" && echo "      User '$SITE' removed."
else
    echo "      User '$SITE' not found, skipping."
fi
if getent group "$SITE" &>/dev/null; then
    groupdel "$SITE" && echo "      Group '$SITE' removed."
else
    echo "      Group '$SITE' not found, skipping."
fi
# Restart Apache
echo "[6/6] Restarting Apache ..."
systemctl restart apache2 && echo "      Apache restarted."
# Verify
echo ""
echo " Verification"
if omd sites | awk '{print $1}' | grep -qx "$SITE"; then
    echo "  WARNING: Site '$SITE' still listed in 'omd sites'."
else
    echo "  OK: Site '$SITE' no longer listed in 'omd sites'."
fi
[[ -d "/omd/sites/$SITE" ]] && echo "  WARNING: Directory /omd/sites/$SITE still exists." || echo "  OK: Site directory removed."
grep -q "$SITE" /etc/fstab && echo "  WARNING: fstab still contains '$SITE'." || echo "  OK: fstab clean."
id "$SITE" &>/dev/null && echo "  WARNING: User '$SITE' still exists." || echo "  OK: User removed."
echo ""
echo "Done. You can now recreate the site with: omd create $SITE"
