Smart-plugin reads no data from S.M.A.R.T. capable disks
Hello everyone,
My latest post here helped me to link drives with smartctl & megacli status and read the correct stats from the smart plugin. That part is solved now, but a new problem appeared with the next server.
Some of my controllers are just HBA’s and not RAID controllers. These controllers are quite dumb and just send the disk data towards the motherboard/OS so I can read their S.M.A.R.T. status without any issue.
Output of smartctl --scan:
root@storage01:~# smartctl --scan
/dev/sda -d scsi # /dev/sda, SCSI device
/dev/sdb -d scsi # /dev/sdb, SCSI device
/dev/sdc -d scsi # /dev/sdc, SCSI device
/dev/sdd -d scsi # /dev/sdd, SCSI device
/dev/sde -d scsi # /dev/sde, SCSI device
/dev/sdf -d scsi # /dev/sdf, SCSI device
/dev/sdg -d scsi # /dev/sdg, SCSI device
/dev/sdh -d scsi # /dev/sdh, SCSI device
/dev/sdi -d scsi # /dev/sdi, SCSI device
/dev/sdj -d scsi # /dev/sdj, SCSI device
/dev/sdk -d scsi # /dev/sdk, SCSI device
/dev/sdl -d scsi # /dev/sdl, SCSI device
/dev/sdm -d scsi # /dev/sdm, SCSI device
/dev/sdn -d scsi # /dev/sdn, SCSI device
/dev/sdo -d scsi # /dev/sdo, SCSI device
/dev/sdp -d scsi # /dev/sdp, SCSI device
/dev/sdq -d scsi # /dev/sdq, SCSI device
/dev/sdr -d scsi # /dev/sdr, SCSI device
/dev/sds -d scsi # /dev/sds, SCSI device
/dev/sdt -d scsi # /dev/sdt, SCSI device
/dev/sdu -d scsi # /dev/sdu, SCSI device
/dev/sdv -d scsi # /dev/sdv, SCSI device
/dev/sdw -d scsi # /dev/sdw, SCSI device
/dev/sdx -d scsi # /dev/sdx, SCSI device
/dev/sdy -d scsi # /dev/sdy, SCSI device
/dev/sdz -d scsi # /dev/sdz, SCSI device
/dev/sdaa -d scsi # /dev/sdaa, SCSI device
/dev/sdab -d scsi # /dev/sdab, SCSI device
/dev/sdac -d scsi # /dev/sdac, SCSI device
/dev/sdad -d scsi # /dev/sdad, SCSI device
/dev/sdae -d scsi # /dev/sdae, SCSI device
/dev/sdaf -d scsi # /dev/sdaf, SCSI device
/dev/sdag -d scsi # /dev/sdag, SCSI device
/dev/sdah -d scsi # /dev/sdah, SCSI device
/dev/sdai -d scsi # /dev/sdai, SCSI device
/dev/sdaj -d scsi # /dev/sdaj, SCSI device
/dev/sdak -d scsi # /dev/sdak, SCSI device
/dev/sdal -d scsi # /dev/sdal, SCSI device
All disks are visible and SMART support is: Available - device has SMART capability. See below.
root@storage01:~# smartctl -a /dev/sdx
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-40-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     ST18000NM000J-2TV103
Serial Number:    WR500KTT
LU WWN Device Id: 5 000c50 0e0287323
Firmware Version: SN02
User Capacity:    18,000,207,937,536 bytes [18.0 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Jul  7 09:37:13 2022 UTC
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1562) minutes.
Conveyance self-test routine
recommended polling time:        (   2) minutes.
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   079   064   044    Pre-fail  Always       -       74971906
  3 Spin_Up_Time            0x0003   095   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       4
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   083   060   045    Pre-fail  Always       -       183271102
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       2540
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       4
 18 Unknown_Attribute       0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   067   058   000    Old_age   Always       -       33 (Min/Max 27/37)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       4
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       2283
194 Temperature_Celsius     0x0022   033   042   000    Old_age   Always       -       33 (0 19 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       2314 (98 210 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       72478210092
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       11330974117085
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
To me everything looks great so far. Let’s now try and run the smart plugin that needs to send the actual smart data towards CheckMK.
root@storage01:/usr/lib/check_mk_agent/plugins# ./smart
tw_cli not found
<<<smart>>>
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870   5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870   9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       74
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870  12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       4
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 177 Wear_Leveling_Count     0x0013   100   100   000    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 195 Hardware_ECC_Recovered  0x001a   200   200   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 199 UDMA_CRC_Error_Count    0x003e   100   100   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 235 Unknown_Attribute       0x0012   099   099   000    Old_age   Always       -       2
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426555X ATA Samsung_SSD_870 252 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870   5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870   9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       74
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870  12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       4
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 177 Wear_Leveling_Count     0x0013   100   100   000    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 195 Hardware_ECC_Recovered  0x001a   200   200   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 199 UDMA_CRC_Error_Count    0x003e   100   100   000    Old_age   Always       -       0
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 235 Unknown_Attribute       0x0012   099   099   000    Old_age   Always       -       2
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       7805649
0ATA_Samsung_SSD_870_S6PENX0T426563A ATA Samsung_SSD_870 252 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
SEAGATE_ST18000NM004J_ZR53RK6W0000C203EHHL SEAGATE ST18000NM004J 194 Temperature_Celsius 0x0000 000 000 000 Old_age Always - 35 (0 0 0 0)
As you can see above the only three devices found by the smart plugin is my two boot SSD’s who are directly connected to my motherboard and one random disk through the HBA, disk /dev/sdp.
This results in only one temperature measurement in CheckMK. Can anyone support me on next steps? Looking to add the missing and smart capable 35 disks to CheckMK. I have already tried the following:
Installing smartctl
Installing ipmitool (maybe this showed disk temps too, but no)
Installing megaraid drivers
Installed a new LSI HBA (same results)
Please let me know if there is more data needed. Thanks for your help in advance! :smiling_face_with_three_hearts:
The smart plugin is looking for devices shown inside your system under the paths.
/dev/disk/by-id/scsi-*
/dev/disk/by-id/ata-*
/dev/disk/by-id/nvme-*
If all your HDD are shown as SCSI drives, what i hope, then further debugging inside the plugin is needed.
The last one line with the temperature shows also that not the complete smart output is fetched as this is like a dummy line for temperature only without the other values.
Here is the output:
root@storage01:/dev/disk/by-id# ls
ata-Samsung_SSD_870_EVO_250GB_S6PENX0T426555X              scsi-35000c500e0287323-part2                     scsi-SATA_ST18000NM000J-2T_ZR53Z79L-part2
ata-Samsung_SSD_870_EVO_250GB_S6PENX0T426563A              scsi-35000c500e0348e65                           scsi-SSEAGATE_ST18000NM004J_ZR53RK6W0000C203EHHL
ata-Samsung_SSD_870_EVO_250GB_S6PENX0T426563A-part1        scsi-35000c500e0348e65-part1                     scsi-SSEAGATE_ST18000NM004J_ZR53RK6W0000C203EHHL-part1
ata-Samsung_SSD_870_EVO_250GB_S6PENX0T426563A-part2        scsi-35000c500e0348e65-part2                     scsi-SSEAGATE_ST18000NM004J_ZR53RK6W0000C203EHHL-part2
scsi-0ATA_Samsung_SSD_870_S6PENX0T426555X                  scsi-35002538f4243d99e                           wwn-0x5000c500d7aac617
scsi-0ATA_Samsung_SSD_870_S6PENX0T426563A                  scsi-35002538f4243d9a6                           wwn-0x5000c500d7aac617-part1
scsi-0ATA_Samsung_SSD_870_S6PENX0T426563A-part1            scsi-35002538f4243d9a6-part1                     wwn-0x5000c500d7aac617-part2
scsi-0ATA_Samsung_SSD_870_S6PENX0T426563A-part2            scsi-35002538f4243d9a6-part2                     wwn-0x5000c500dc632ea4
scsi-1ATA_Samsung_SSD_870_EVO_250GB_S6PENX0T426555X        scsi-SATA_Samsung_SSD_870_S6PENX0T426555X        wwn-0x5000c500dc632ea4-part1
scsi-1ATA_Samsung_SSD_870_EVO_250GB_S6PENX0T426563A        scsi-SATA_Samsung_SSD_870_S6PENX0T426563A        wwn-0x5000c500dc632ea4-part2
scsi-1ATA_Samsung_SSD_870_EVO_250GB_S6PENX0T426563A-part1  scsi-SATA_Samsung_SSD_870_S6PENX0T426563A-part1  wwn-0x5000c500dc63bf2b
scsi-1ATA_Samsung_SSD_870_EVO_250GB_S6PENX0T426563A-part2  scsi-SATA_Samsung_SSD_870_S6PENX0T426563A-part2  wwn-0x5000c500dc63bf2b-part1
scsi-35000c500d7aac617                                     scsi-SATA_ST18000NM000J-2T_WR500KLF              wwn-0x5000c500dc63bf2b-part2
scsi-35000c500d7aac617-part1                               scsi-SATA_ST18000NM000J-2T_WR500KLF-part1        wwn-0x5000c500dc63cf1b
scsi-35000c500d7aac617-part2                               scsi-SATA_ST18000NM000J-2T_WR500KLF-part2        wwn-0x5000c500dc63cf1b-part1
scsi-35000c500dc632ea4                                     scsi-SATA_ST18000NM000J-2T_WR500KQ1              wwn-0x5000c500dc63cf1b-part2
scsi-35000c500dc632ea4-part1                               scsi-SATA_ST18000NM000J-2T_WR500KQ1-part1        wwn-0x5000c500dc63d2ba
scsi-35000c500dc632ea4-part2                               scsi-SATA_ST18000NM000J-2T_WR500KQ1-part2        wwn-0x5000c500dc63d2ba-part1
scsi-35000c500dc63bf2b                                     scsi-SATA_ST18000NM000J-2T_WR500KRB              wwn-0x5000c500dc63d2ba-part2
scsi-35000c500dc63bf2b-part1                               scsi-SATA_ST18000NM000J-2T_WR500KRB-part1        wwn-0x5000c500dc63e1ac
scsi-35000c500dc63bf2b-part2                               scsi-SATA_ST18000NM000J-2T_WR500KRB-part2        wwn-0x5000c500dc63e1ac-part1
scsi-35000c500dc63cf1b                                     scsi-SATA_ST18000NM000J-2T_WR500KTT              wwn-0x5000c500dc63e1ac-part2
scsi-35000c500dc63cf1b-part1                               scsi-SATA_ST18000NM000J-2T_WR500KTT-part1        wwn-0x5000c500dc63ff65
scsi-35000c500dc63cf1b-part2                               scsi-SATA_ST18000NM000J-2T_WR500KTT-part2        wwn-0x5000c500dc63ff65-part1
scsi-35000c500dc63d2ba                                     scsi-SATA_ST18000NM000J-2T_WR500KZS              wwn-0x5000c500dc63ff65-part2
scsi-35000c500dc63d2ba-part1                               scsi-SATA_ST18000NM000J-2T_WR500KZS-part1        wwn-0x5000c500dc640700
scsi-35000c500dc63d2ba-part2                               scsi-SATA_ST18000NM000J-2T_WR500KZS-part2        wwn-0x5000c500dc640700-part1
scsi-35000c500dc63e1ac                                     scsi-SATA_ST18000NM000J-2T_WR500L0N              wwn-0x5000c500dc640700-part2
scsi-35000c500dc63e1ac-part1                               scsi-SATA_ST18000NM000J-2T_WR500L0N-part1        wwn-0x5000c500dc644db9
scsi-35000c500dc63e1ac-part2                               scsi-SATA_ST18000NM000J-2T_WR500L0N-part2        wwn-0x5000c500dc644db9-part1
scsi-35000c500dc63ff65                                     scsi-SATA_ST18000NM000J-2T_WR500L0T              wwn-0x5000c500dc644db9-part2
scsi-35000c500dc63ff65-part1                               scsi-SATA_ST18000NM000J-2T_WR500L0T-part1        wwn-0x5000c500e0279ae4
scsi-35000c500dc63ff65-part2                               scsi-SATA_ST18000NM000J-2T_WR500L0T-part2        wwn-0x5000c500e0279ae4-part1
scsi-35000c500dc640700                                     scsi-SATA_ST18000NM000J-2T_WR500L28              wwn-0x5000c500e0279ae4-part2
scsi-35000c500dc640700-part1                               scsi-SATA_ST18000NM000J-2T_WR500L28-part1        wwn-0x5000c500e027a767
scsi-35000c500dc640700-part2                               scsi-SATA_ST18000NM000J-2T_WR500L28-part2        wwn-0x5000c500e027a767-part1
scsi-35000c500dc644db9                                     scsi-SATA_ST18000NM000J-2T_WR500LDK              wwn-0x5000c500e027a767-part2
scsi-35000c500dc644db9-part1                               scsi-SATA_ST18000NM000J-2T_WR500LDK-part1        wwn-0x5000c500e027a956
scsi-35000c500dc644db9-part2                               scsi-SATA_ST18000NM000J-2T_WR500LDK-part2        wwn-0x5000c500e027a956-part1
scsi-35000c500e0279ae4                                     scsi-SATA_ST18000NM000J-2T_WR500LE3              wwn-0x5000c500e027a956-part2
scsi-35000c500e0279ae4-part1                               scsi-SATA_ST18000NM000J-2T_WR500LE3-part1        wwn-0x5000c500e027c7a2
scsi-35000c500e0279ae4-part2                               scsi-SATA_ST18000NM000J-2T_WR500LE3-part2        wwn-0x5000c500e027c7a2-part1
scsi-35000c500e027a767                                     scsi-SATA_ST18000NM000J-2T_WR500LEC              wwn-0x5000c500e027c7a2-part2
scsi-35000c500e027a767-part1                               scsi-SATA_ST18000NM000J-2T_WR500LEC-part1        wwn-0x5000c500e027c8fd
scsi-35000c500e027a767-part2                               scsi-SATA_ST18000NM000J-2T_WR500LEC-part2        wwn-0x5000c500e027c8fd-part1
scsi-35000c500e027a956                                     scsi-SATA_ST18000NM000J-2T_WR500LEW              wwn-0x5000c500e027c8fd-part2
scsi-35000c500e027a956-part1                               scsi-SATA_ST18000NM000J-2T_WR500LEW-part1        wwn-0x5000c500e027c93b
scsi-35000c500e027a956-part2                               scsi-SATA_ST18000NM000J-2T_WR500LEW-part2        wwn-0x5000c500e027c93b-part1
scsi-35000c500e027c7a2                                     scsi-SATA_ST18000NM000J-2T_WR500LLE              wwn-0x5000c500e027c93b-part2
scsi-35000c500e027c7a2-part1                               scsi-SATA_ST18000NM000J-2T_WR500LLE-part1        wwn-0x5000c500e027ccbc
scsi-35000c500e027c7a2-part2                               scsi-SATA_ST18000NM000J-2T_WR500LLE-part2        wwn-0x5000c500e027ccbc-part1
scsi-35000c500e027c8fd                                     scsi-SATA_ST18000NM000J-2T_WR500LLG              wwn-0x5000c500e027ccbc-part2
scsi-35000c500e027c8fd-part1                               scsi-SATA_ST18000NM000J-2T_WR500LLG-part1        wwn-0x5000c500e027d5e8
scsi-35000c500e027c8fd-part2                               scsi-SATA_ST18000NM000J-2T_WR500LLG-part2        wwn-0x5000c500e027d5e8-part1
scsi-35000c500e027c93b                                     scsi-SATA_ST18000NM000J-2T_WR500LMF              wwn-0x5000c500e027d5e8-part2
scsi-35000c500e027c93b-part1                               scsi-SATA_ST18000NM000J-2T_WR500LMF-part1        wwn-0x5000c500e027d918
scsi-35000c500e027c93b-part2                               scsi-SATA_ST18000NM000J-2T_WR500LMF-part2        wwn-0x5000c500e027d918-part1
scsi-35000c500e027ccbc                                     scsi-SATA_ST18000NM000J-2T_WR500LMP              wwn-0x5000c500e027d918-part2
scsi-35000c500e027ccbc-part1                               scsi-SATA_ST18000NM000J-2T_WR500LMP-part1        wwn-0x5000c500e027d94c
scsi-35000c500e027ccbc-part2                               scsi-SATA_ST18000NM000J-2T_WR500LMP-part2        wwn-0x5000c500e027d94c-part1
scsi-35000c500e027d5e8                                     scsi-SATA_ST18000NM000J-2T_WR500LS4              wwn-0x5000c500e027d94c-part2
scsi-35000c500e027d5e8-part1                               scsi-SATA_ST18000NM000J-2T_WR500LS4-part1        wwn-0x5000c500e027d9b8
scsi-35000c500e027d5e8-part2                               scsi-SATA_ST18000NM000J-2T_WR500LS4-part2        wwn-0x5000c500e027d9b8-part1
scsi-35000c500e027d918                                     scsi-SATA_ST18000NM000J-2T_WR500LV8              wwn-0x5000c500e027d9b8-part2
scsi-35000c500e027d918-part1                               scsi-SATA_ST18000NM000J-2T_WR500LV8-part1        wwn-0x5000c500e027da1b
scsi-35000c500e027d918-part2                               scsi-SATA_ST18000NM000J-2T_WR500LV8-part2        wwn-0x5000c500e027da1b-part1
scsi-35000c500e027d94c                                     scsi-SATA_ST18000NM000J-2T_WR500LVH              wwn-0x5000c500e027da1b-part2
scsi-35000c500e027d94c-part1                               scsi-SATA_ST18000NM000J-2T_WR500LVH-part1        wwn-0x5000c500e027f574
scsi-35000c500e027d94c-part2                               scsi-SATA_ST18000NM000J-2T_WR500LVH-part2        wwn-0x5000c500e027f574-part1
scsi-35000c500e027d9b8                                     scsi-SATA_ST18000NM000J-2T_WR500LWP              wwn-0x5000c500e027f574-part2
scsi-35000c500e027d9b8-part1                               scsi-SATA_ST18000NM000J-2T_WR500LWP-part1        wwn-0x5000c500e027f7ab
scsi-35000c500e027d9b8-part2                               scsi-SATA_ST18000NM000J-2T_WR500LWP-part2        wwn-0x5000c500e027f7ab-part1
scsi-35000c500e027da1b                                     scsi-SATA_ST18000NM000J-2T_WR500LXT              wwn-0x5000c500e027f7ab-part2
scsi-35000c500e027da1b-part1                               scsi-SATA_ST18000NM000J-2T_WR500LXT-part1        wwn-0x5000c500e02801df
scsi-35000c500e027da1b-part2                               scsi-SATA_ST18000NM000J-2T_WR500LXT-part2        wwn-0x5000c500e02801df-part1
scsi-35000c500e027f574                                     scsi-SATA_ST18000NM000J-2T_WR500M0X              wwn-0x5000c500e02801df-part2
scsi-35000c500e027f574-part1                               scsi-SATA_ST18000NM000J-2T_WR500M0X-part1        wwn-0x5000c500e028033f
scsi-35000c500e027f574-part2                               scsi-SATA_ST18000NM000J-2T_WR500M0X-part2        wwn-0x5000c500e028033f-part1
scsi-35000c500e027f7ab                                     scsi-SATA_ST18000NM000J-2T_WR500M1Y              wwn-0x5000c500e028033f-part2
scsi-35000c500e027f7ab-part1                               scsi-SATA_ST18000NM000J-2T_WR500M1Y-part1        wwn-0x5000c500e0280abb
scsi-35000c500e027f7ab-part2                               scsi-SATA_ST18000NM000J-2T_WR500M1Y-part2        wwn-0x5000c500e0280abb-part1
scsi-35000c500e02801df                                     scsi-SATA_ST18000NM000J-2T_WR500M21              wwn-0x5000c500e0280abb-part2
scsi-35000c500e02801df-part1                               scsi-SATA_ST18000NM000J-2T_WR500M21-part1        wwn-0x5000c500e0280af0
scsi-35000c500e02801df-part2                               scsi-SATA_ST18000NM000J-2T_WR500M21-part2        wwn-0x5000c500e0280af0-part1
scsi-35000c500e028033f                                     scsi-SATA_ST18000NM000J-2T_WR500M65              wwn-0x5000c500e0280af0-part2
scsi-35000c500e028033f-part1                               scsi-SATA_ST18000NM000J-2T_WR500M65-part1        wwn-0x5000c500e0284417
scsi-35000c500e028033f-part2                               scsi-SATA_ST18000NM000J-2T_WR500M65-part2        wwn-0x5000c500e0284417-part1
scsi-35000c500e0280abb                                     scsi-SATA_ST18000NM000J-2T_WR500M74              wwn-0x5000c500e0284417-part2
scsi-35000c500e0280abb-part1                               scsi-SATA_ST18000NM000J-2T_WR500M74-part1        wwn-0x5000c500e0284699
scsi-35000c500e0280abb-part2                               scsi-SATA_ST18000NM000J-2T_WR500M74-part2        wwn-0x5000c500e0284699-part1
scsi-35000c500e0280af0                                     scsi-SATA_ST18000NM000J-2T_WR5013B9              wwn-0x5000c500e0284699-part2
scsi-35000c500e0280af0-part1                               scsi-SATA_ST18000NM000J-2T_WR5013B9-part1        wwn-0x5000c500e02847d6
scsi-35000c500e0280af0-part2                               scsi-SATA_ST18000NM000J-2T_WR5013B9-part2        wwn-0x5000c500e02847d6-part1
scsi-35000c500e0284417                                     scsi-SATA_ST18000NM000J-2T_ZR53YKMH              wwn-0x5000c500e02847d6-part2
scsi-35000c500e0284417-part1                               scsi-SATA_ST18000NM000J-2T_ZR53YKMH-part1        wwn-0x5000c500e0286dd2
scsi-35000c500e0284417-part2                               scsi-SATA_ST18000NM000J-2T_ZR53YKMH-part2        wwn-0x5000c500e0286dd2-part1
scsi-35000c500e0284699                                     scsi-SATA_ST18000NM000J-2T_ZR53YN2S              wwn-0x5000c500e0286dd2-part2
scsi-35000c500e0284699-part1                               scsi-SATA_ST18000NM000J-2T_ZR53YN2S-part1        wwn-0x5000c500e0286f74
scsi-35000c500e0284699-part2                               scsi-SATA_ST18000NM000J-2T_ZR53YN2S-part2        wwn-0x5000c500e0286f74-part1
scsi-35000c500e02847d6                                     scsi-SATA_ST18000NM000J-2T_ZR53YXVV              wwn-0x5000c500e0286f74-part2
scsi-35000c500e02847d6-part1                               scsi-SATA_ST18000NM000J-2T_ZR53YXVV-part1        wwn-0x5000c500e0286fd7
scsi-35000c500e02847d6-part2                               scsi-SATA_ST18000NM000J-2T_ZR53YXVV-part2        wwn-0x5000c500e0286fd7-part1
scsi-35000c500e0286dd2                                     scsi-SATA_ST18000NM000J-2T_ZR53Z57X              wwn-0x5000c500e0286fd7-part2
scsi-35000c500e0286dd2-part1                               scsi-SATA_ST18000NM000J-2T_ZR53Z57X-part1        wwn-0x5000c500e028713c
scsi-35000c500e0286dd2-part2                               scsi-SATA_ST18000NM000J-2T_ZR53Z57X-part2        wwn-0x5000c500e028713c-part1
scsi-35000c500e0286f74                                     scsi-SATA_ST18000NM000J-2T_ZR53Z5CH              wwn-0x5000c500e028713c-part2
scsi-35000c500e0286f74-part1                               scsi-SATA_ST18000NM000J-2T_ZR53Z5CH-part1        wwn-0x5000c500e0287323
scsi-35000c500e0286f74-part2                               scsi-SATA_ST18000NM000J-2T_ZR53Z5CH-part2        wwn-0x5000c500e0287323-part1
scsi-35000c500e0286fd7                                     scsi-SATA_ST18000NM000J-2T_ZR53Z5DD              wwn-0x5000c500e0287323-part2
scsi-35000c500e0286fd7-part1                               scsi-SATA_ST18000NM000J-2T_ZR53Z5DD-part1        wwn-0x5000c500e0348e65
scsi-35000c500e0286fd7-part2                               scsi-SATA_ST18000NM000J-2T_ZR53Z5DD-part2        wwn-0x5000c500e0348e65-part1
scsi-35000c500e028713c                                     scsi-SATA_ST18000NM000J-2T_ZR53Z5L3              wwn-0x5000c500e0348e65-part2
scsi-35000c500e028713c-part1                               scsi-SATA_ST18000NM000J-2T_ZR53Z5L3-part1        wwn-0x5002538f4243d99e
scsi-35000c500e028713c-part2                               scsi-SATA_ST18000NM000J-2T_ZR53Z5L3-part2        wwn-0x5002538f4243d9a6
scsi-35000c500e0287323                                     scsi-SATA_ST18000NM000J-2T_ZR53Z79L              wwn-0x5002538f4243d9a6-part1
scsi-35000c500e0287323-part1                               scsi-SATA_ST18000NM000J-2T_ZR53Z79L-part1        wwn-0x5002538f4243d9a6-part2
If the drives are shown as ATA and not SCSI, what then?
Also, when I do an “smartctl --scan-open” they look like this (except the readable disk /sdp)
root@storage01:~# smartctl --scan-open
/dev/sda -d sat # /dev/sda [SAT], ATA device
/dev/sdb -d sat # /dev/sdb [SAT], ATA device
/dev/sdc -d sat # /dev/sdc [SAT], ATA device
/dev/sdd -d sat # /dev/sdd [SAT], ATA device
/dev/sde -d sat # /dev/sde [SAT], ATA device
/dev/sdf -d sat # /dev/sdf [SAT], ATA device
/dev/sdg -d sat # /dev/sdg [SAT], ATA device
/dev/sdh -d sat # /dev/sdh [SAT], ATA device
/dev/sdi -d sat # /dev/sdi [SAT], ATA device
/dev/sdj -d sat # /dev/sdj [SAT], ATA device
/dev/sdk -d sat # /dev/sdk [SAT], ATA device
/dev/sdl -d sat # /dev/sdl [SAT], ATA device
/dev/sdm -d sat # /dev/sdm [SAT], ATA device
/dev/sdn -d sat # /dev/sdn [SAT], ATA device
/dev/sdo -d sat # /dev/sdo [SAT], ATA device
/dev/sdq -d sat # /dev/sdq [SAT], ATA device
/dev/sdr -d sat # /dev/sdr [SAT], ATA device
/dev/sds -d sat # /dev/sds [SAT], ATA device
/dev/sdt -d sat # /dev/sdt [SAT], ATA device
/dev/sdu -d sat # /dev/sdu [SAT], ATA device
/dev/sdv -d sat # /dev/sdv [SAT], ATA device
/dev/sdw -d sat # /dev/sdw [SAT], ATA device
/dev/sdx -d sat # /dev/sdx [SAT], ATA device
/dev/sdy -d sat # /dev/sdy [SAT], ATA device
/dev/sdz -d sat # /dev/sdz [SAT], ATA device
/dev/sdaa -d sat # /dev/sdaa [SAT], ATA device
/dev/sdab -d sat # /dev/sdab [SAT], ATA device
/dev/sdac -d sat # /dev/sdac [SAT], ATA device
/dev/sdad -d sat # /dev/sdad [SAT], ATA device
/dev/sdae -d sat # /dev/sdae [SAT], ATA device
/dev/sdaf -d sat # /dev/sdaf [SAT], ATA device
/dev/sdag -d sat # /dev/sdag [SAT], ATA device
/dev/sdah -d sat # /dev/sdah [SAT], ATA device
/dev/sdai -d sat # /dev/sdai [SAT], ATA device
/dev/sdaj -d sat # /dev/sdaj [SAT], ATA device
/dev/sdak -d sat # /dev/sdak [SAT], ATA device
/dev/sdal -d sat # /dev/sdal [SAT], ATA device
Best option is to check the single commands of the script to find the position where your discs are ignored or filtered. First i would insert some debug output to find the line where your devices are ignored.
Can you help me with this? I do not really know where to look. The script I use is the standard one from CheckMK.
