SMSEagle Notification
Hallo There,
I need help how to connect SMS Eagle LTE Modem with Checkmk Server.
I Installed SMS Eagle Plugin on the Checkmk Server, but I do have any response and SMSeagle Send no messages.
Has anyone idea how to config the SMS Eagle.
Thanks
I am not sure about the SMS Eagle but as an alternative you might want to have a look as SIGNL4 - a mobile alerting service. It alerts you even if there is an issue with the network connection (SIGNL4 | Heartbeat check and more - is your monitoring still alive?).
I hope this helps you.
Thanks and Best Regards
Ron
Hi mohammed,
can your checkmk server reach the SMS Eagle web interface? i.e. if you try it with wget?
Gerd
Hi Gerd,
thanks for your answer.
The SMS Eagle is reachable from Checkmk Server.
wget https://149.222.23.230
–2023-10-06 13:23:07-- https://149.222.23.230/
Connecting to 149.222.23.230:443… connected.
ERROR: The certificate of ‘149.222.23.230’ is not trusted.
ERROR: The certificate of ‘149.222.23.230’ doesn’t have a known issuer.
The certificate’s owner does not match hostname ‘149.222.23.230’
but I get this answer from Checkmk, how I can solve it.
which answer do you get from checkmk? :smiley: (it looks like maybe you wanted to share something that wasn’t included in your post?)
do you see anything useful in the ~/var/log/notify.log or mknotifyd.log?
