OMD[test]:~$ cmk -vv nas-test
Checkmk version 2.1.0p3
Trying to acquire lock on /omd/sites/test/var/check_mk/license_usage/next_run
Got lock on /omd/sites/test/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/test/var/check_mk/license_usage/history.json
Got lock on /omd/sites/test/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/test/var/check_mk/license_usage/history.json
Released lock on /omd/sites/test/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/test/var/check_mk/license_usage/next_run
Released lock on /omd/sites/test/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f3c223bdeb0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(nas-test, base_path=/omd/sites/test/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 33 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 172.29.4.30 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Linux nas-230 3.10.105 #25556 SMP Sat Aug 28 02:15:59 CST 2021 x86_64"]
b'Linux nas-230 3.10.105 #25556 SMP Sat Aug 28 02:15:59 CST 2021 x86_64'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 172.29.4.30 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.8072.3.2.10]
b'.1.3.6.1.4.1.8072.3.2.10'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.8072.3.2.10'
Using cached OID .1.3.6.1.2.1.1.1.0: 'Linux nas-230 3.10.105 #25556 SMP Sat Aug 28 02:15:59 CST 2021 x86_64'
Getting OID .1.3.6.1.2.1.2.2.1.*: Running 'snmpgetnext -Cf -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1'
SNMP answer: ==> [1]
b'1'
SNMP scan found hr_mem if snmp_uptime ucd_cpu_load
Trying to acquire lock on /omd/sites/test/tmp/check_mk/snmp_scan_cache/nas-test.172.29.4.30
Got lock on /omd/sites/test/tmp/check_mk/snmp_scan_cache/nas-test.172.29.4.30
Releasing lock on /omd/sites/test/tmp/check_mk/snmp_scan_cache/nas-test.172.29.4.30
Released lock on /omd/sites/test/tmp/check_mk/snmp_scan_cache/nas-test.172.29.4.30
hr_cpu: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.25.3.3.1.2'
ucd_cpu_load: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.10.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.10.1.6'
hr_fs: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.25.2.3.1.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.25.2.3.1.3'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.25.2.3.1.4'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.25.2.3.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.25.2.3.1.6'
hr_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.2
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.3
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.4
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.5
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.6
if: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.3'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.8'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.10'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.11'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.12'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.13'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.14'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.16'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.17'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.18'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.19'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.20'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.21'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.2.2.1.6'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.1.1'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.1.4'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.1.6'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.1.3'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.2.1.25.1.1'
synology_disks: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.2.1.1.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.2.1.1.3'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.2.1.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.2.1.1.6'
synology_fans: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.4.1'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.4.2'
synology_info: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.5.1'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.5.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.5.3'
synology_raid: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.3.1.1.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.3.1.1.3'
synology_status: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.1'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.3'
synology_update: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.4.1.6574.1.5.3
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.6574.1.5.4'
ucd_diskio: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.13.15.1.1.1'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.13.15.1.1.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.13.15.1.1.3'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.13.15.1.1.4'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.13.15.1.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 172.29.4.30 .1.3.6.1.4.1.2021.13.15.1.1.6'
Write data to cache file /omd/sites/test/tmp/check_mk/data_source_cache/snmp/checking/nas-test
Trying to acquire lock on /omd/sites/test/tmp/check_mk/data_source_cache/snmp/checking/nas-test
Got lock on /omd/sites/test/tmp/check_mk/data_source_cache/snmp/checking/nas-test
Releasing lock on /omd/sites/test/tmp/check_mk/data_source_cache/snmp/checking/nas-test
Released lock on /omd/sites/test/tmp/check_mk/data_source_cache/snmp/checking/nas-test
[cpu_tracking] Stop [7f3c223bdeb0 - Snapshot(process=posix.times_result(user=0.08000000000000007, system=0.21000000000000002, children_user=0.04, children_system=0.37, elapsed=2.0100000016391277))]
[cpu_tracking] Start [7f3c223bda60]
[PiggybackFetcher] Fetch with cache settings: NoCache(nas-test, base_path=/omd/sites/test/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'nas-test'. Skip processing.
No piggyback files for '172.29.4.30'. Skip processing.
[cpu_tracking] Stop [7f3c223bda60 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections
-> Add sections: ['hr_cpu', 'hr_fs', 'hr_mem', 'if', 'snmp_info', 'snmp_uptime', 'synology_disks', 'synology_fans', 'synology_info', 'synology_raid', 'synology_status', 'synology_update', 'ucd_cpu_load', 'ucd_diskio']
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f3c2232dca0]
value store: synchronizing
Trying to acquire lock on /omd/sites/test/tmp/check_mk/counters/nas-test
Got lock on /omd/sites/test/tmp/check_mk/counters/nas-test
Releasing lock on /omd/sites/test/tmp/check_mk/counters/nas-test
Released lock on /omd/sites/test/tmp/check_mk/counters/nas-test
CPU load 15 min load: 0.05, 15 min load per core: 0.05 (1 cores)
CPU utilization Total CPU: 0.5%
Disk Drive 1 Status: OK, Temperature: 28 °C, Model: WD30EFRX-68EUZN0
Disk Drive 2 Status: OK, Temperature: 31 °C, Model: DT01ACA300
Disk Drive 3 Status: OK, Temperature: 29 °C, Model: WD40EFRX-68N32N0
Disk Drive 4 Status: OK, Temperature: 28 °C, Model: WD30EFRX-68EUZN0
Disk Drive 5 Status: OK, Temperature: 28 °C, Model: WD30EFRX-68EUZN0
Disk IO dm-0 [55], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop0 [46], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop1 [47], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop2 [48], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop3 [49], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop4 [50], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop5 [51], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop6 [52], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO loop7 [53], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO md0 [37], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO md1 [38], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO md2 [54], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram0 [1], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram1 [2], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram10 [11], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram11 [12], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram12 [13], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram13 [14], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram14 [15], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram15 [16], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram2 [3], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram3 [4], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram4 [5], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram5 [6], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram6 [7], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram7 [8], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram8 [9], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO ram9 [10], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sda [29], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sda1 [30], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sda2 [31], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sda5 [32], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdb [33], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdb1 [34], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdb2 [35], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdb5 [36], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdc [17], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdc1 [18], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdc2 [19], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdc5 [20], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdd [21], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdd1 [22], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdd2 [23], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sdd5 [24], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sde [25], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sde1 [26], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sde2 [27], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO sde5 [28], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO synoboot [43], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO synoboot1 [44], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO synoboot2 [45], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO zram0 [39], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO zram1 [40], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO zram2 [41], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Disk IO zram3 [42], Read: 0.00 B/s, Write: 0.00 B/s, Read operations: 0.00 1/s, Write operations: 0.00 1/s
Fan CPU No failure reported
Fan System No failure reported
Filesystem / 46.33% used (1.05 of 2.28 GB), trend: 0.00 B / 24 hours
Filesystem /dev/shm 0.0004% used (4.00 kB of 993.41 MB), trend: 0.00 B / 24 hours
Filesystem /run 0.55% used (5.44 of 993.41 MB), trend: +10.91 kB / 24 hours
Filesystem /run/cgmanager/fs 0% used (0.00 B of 100.00 kB), trend: 0.00 B / 24 hours
Filesystem /sys/fs/cgroup 0% used (0.00 B of 4.00 kB), trend: 0.00 B / 24 hours
Filesystem /tmp 0.11% used (1.13 of 993.41 MB), trend: 0.00 B / 24 hours
Filesystem /volume1 0.002% used (52.17 MB of 2.62 TB), trend: 0.00 B / 24 hours
Info Model: DS1515+, S/N: 1591MQN705901, OS Version: DSM 6.2-25556
Interface 6 [eth3], (up), MAC: 00:11:32:4E:07:E4, Speed: 100 MBit/s, In: 3.25 kB/s (0.03%), Out: 1.63 kB/s (0.01%)
Memory Total (RAM + Swap): 14.92% - 297 MiB of 1.94 GiB RAM, RAM: 14.92% - 297 MiB of 1.94 GiB, Swap: 0% - 0 B of 3.16 GiB
RAID Volume 1 Status: OK
SNMP Info Linux nas-230 3.10.105 #25556 SMP Sat Aug 28 02:15:59 CST 2021 x86_64, nas-230, Unknown, admin@diskstation
Status System state OK, Power State OK
Update Update Status: Unavailable, Current Version: DSM 6.2-25556
Uptime Up since Jun 03 2022 14:31:31, Uptime: 25 days 1 hour
value store: already loaded
value store: writing to disk
[cpu_tracking] Stop [7f3c2232dca0 - Snapshot(process=posix.times_result(user=0.06000000000000005, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.06999999657273293))]
[snmp] Success, execution time 2.1 sec | execution_time=2.080 user_time=0.140 system_time=0.210 children_user_time=0.040 children_system_time=0.370 cmk_time_snmp=1.310 cmk_time_agent=0.000
