Hello there, i tried wandering for solution but i’m still confused.
I have some HPE 5800 and 5500 switches and i want to check the Fan and PSU status. I see from core plugins hp_hh3c_power and hp_hh3c_fan.
i get success from discovery plugin, and with cmk -R i see the checks running for this host.
But, if i made a normal run service discovery from the GUI, the snmp plugins disappear.
I wandering in the setup and i made in “snmp rules” - “disabled or enabled sections SNMP” one rule for fan and one for power, obivously in the right folder in wato.
A this point things are weird, a few switch starting discovery but many others not. And for the few, if i make a run service discovery, check disappear again…
I missing something? there is a correct path to enabled this checks from wato?
Thanks for the reply, seems is report HP without E
HP Comware Platform Software, Software Version 5.20, Release 1211P06 HP A5800AF-48G Switch Copyright (c) 2010-2012 Hewlett-Packard Development Company, L.P.
ok, i think this can point me in the right direction
Thank you
Do not change the file as it will be lost with the next update.
Copy the file into the same directory below $OMD_ROOT/local of the site and change it there.
And send a feedback to the checkmk developers.
Thanks,
the firmware is old, before switching HP/HPE. this causing the issue. The core plugin is correct.
I will inform the developers, but i guess the response.
