I was able to create a new check for the moxa switch. It is basically a copy and paste from the already existing checks if64 and if64_tplink
It is working, but not usable for all moxa switches because the vendor ifAlias ID is different for every switch series (.1.3.6.1.4.1.8691.7.18.1.9.1.1.7 EDS-G509) (.1.3.6.1.4.1.8691.7.7.1.9.1.1.7 EDS-408A)
So for a check to work for all moxa switches it would be necessary to determine the correct OID for the switch inside the check.
Because we only use this two types I just created two checks one for each switch series.
Here is the code, maybe it helps someone else…
#!/usr/bin/python
@network_interface_scan_registry.register
def snmp_scan_function_if64_moxa(oid):
return oid(".1.3.6.1.2.1.1.2.0").startswith(".1.3.6.1.4.1.8691.7.18")
def inventory_if64_moxa(info):
return inventory_if_common(info, has_nodeinfo=True)
def check_if64_moxa(item, params, info):
return check_if_common(item, params, info, has_nodeinfo=True)
check_info["if64_moxa_EDS-G509"] = {
'parse_function': parse_if64,
'check_function': check_if64_moxa,
'inventory_function': inventory_if64_moxa,
'service_description': 'Interface %s',
'has_perfdata': True,
'includes': ['if.include'],
'snmp_info': (
".1.3.6.1",
"2.1.2.2.1.1", # ifIndex 0
"2.1.2.2.1.2", # ifDescr 1
"2.1.2.2.1.3", # ifType 2
"2.1.2.2.1.5", # ifSpeed 3
"2.1.2.2.1.8", # ifOperStatus 4
"2.1.31.1.1.1.6", # ifHCInOctets 5
"2.1.31.1.1.1.7", # ifHCInUcastPkts 6
"2.1.31.1.1.1.8", # ifHCInMulticastPkts 7
"2.1.31.1.1.1.9", # ifHCInBroadcastPkts 8
"2.1.2.2.1.13", # ifInDiscards 9
"2.1.2.2.1.14", # ifInErrors 10
"2.1.31.1.1.1.10", # ifHCOutOctets 11
"2.1.31.1.1.1.11", # ifHCOutUcastPkts 12
"2.1.31.1.1.1.12", # ifHCOutMulticastPkts 13
"2.1.31.1.1.1.13", # ifHCOutBroadcastPkts 14
"2.1.2.2.1.19", # ifOutDiscards 15
"2.1.2.2.1.20", # ifOutErrors 16
"2.1.2.2.1.21", # ifOutQLen 17
"4.1.8691.7.18.1.9.1.1.7", # ifAlias special for Moxa Switch EDS G509
BINARY("2.1.2.2.1.6"), # ifPhysAddress 19
"2.1.31.1.1.1.15", # ifHighSpeed -1 (parse_if64 assumes this is the last element)
'snmp_scan_function': snmp_scan_function_if64_moxa,
'group': 'if',
'node_info': True,
'default_levels_variable': 'if_default_levels',
Thanks for the quick responses, this solves the problem for my environment
