CMK version: Checkmk Raw Edition 2.2.0p4 Docker
OS version: Docker - Debian 11
Error message: SNMP Connection Timeout
Hey everyone,
for some reason my CheckMK doesn’t connect to my new TP-Link Switch. I installed an SNMP Client on my PC and the computer Client is able to fetch SNMP Values from the Switch. CheckMK doesn’t. An IP allow list is not available, which means it should respond to every IP. The Switch is centralized Controlled by Omada.
Is there a deeper debugging tool sides CheckMK? In addition I made an snmp Bulkwalk on the Dockerhost via snmpwalk and I received SNMP data. So CheckMK doesn’t receive data.
Then you can only compare the configured SNMP settings for the host object (cmk -D hostname) and your used setting from the bulkwalk.
If these settings are the same i would do a “cmk --debug -vvI hostname” on the command line to see if it is only a slow response or no response.
Hey Andreas,
okay. Lets have a look. First I run it as root on the docker host:
snmpwalk -v 1 -c SNMPOmada 10.10.120.4
iso.3.6.1.2.1.1.1.0 = STRING: "JetStream 10-Port Gigabit Smart Switch with 8-Port PoE+"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.11863.5.158
iso.3.6.1.2.1.1.3.0 = Timeticks: (1391442) 3:51:54.42
iso.3.6.1.2.1.1.4.0 = ""
iso.3.6.1.2.1.1.5.0 = STRING: "TL-SG2210P"
iso.3.6.1.2.1.1.6.0 = ""
iso.3.6.1.2.1.1.7.0 = INTEGER: 3
iso.3.6.1.2.1.2.1.0 = INTEGER: 17
iso.3.6.1.2.1.2.2.1.1.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.1.100 = INTEGER: 100
iso.3.6.1.2.1.2.2.1.1.120 = INTEGER: 120
iso.3.6.1.2.1.2.2.1.1.140 = INTEGER: 140
iso.3.6.1.2.1.2.2.1.1.200 = INTEGER: 200
iso.3.6.1.2.1.2.2.1.1.210 = INTEGER: 210
iso.3.6.1.2.1.2.2.1.1.220 = INTEGER: 220
iso.3.6.1.2.1.2.2.1.1.49153 = INTEGER: 49153
iso.3.6.1.2.1.2.2.1.1.49154 = INTEGER: 49154
iso.3.6.1.2.1.2.2.1.1.49155 = INTEGER: 49155
iso.3.6.1.2.1.2.2.1.1.49156 = INTEGER: 49156
iso.3.6.1.2.1.2.2.1.1.49157 = INTEGER: 49157
iso.3.6.1.2.1.2.2.1.1.49158 = INTEGER: 49158
iso.3.6.1.2.1.2.2.1.1.49159 = INTEGER: 49159
iso.3.6.1.2.1.2.2.1.1.49160 = INTEGER: 49160
iso.3.6.1.2.1.2.2.1.1.49161 = INTEGER: 49161
iso.3.6.1.2.1.2.2.1.1.49162 = INTEGER: 49162
iso.3.6.1.2.1.2.2.1.2.1 = STRING: "Vlan-interface1"
iso.3.6.1.2.1.2.2.1.2.100 = STRING: "Vlan-interface100"
iso.3.6.1.2.1.2.2.1.2.120 = STRING: "Vlan-interface120"
iso.3.6.1.2.1.2.2.1.2.140 = STRING: "Vlan-interface140"
iso.3.6.1.2.1.2.2.1.2.200 = STRING: "Vlan-interface200"
iso.3.6.1.2.1.2.2.1.2.210 = STRING: "Vlan-interface210"
iso.3.6.1.2.1.2.2.1.2.220 = STRING: "Vlan-interface220"
iso.3.6.1.2.1.2.2.1.2.49153 = STRING: "gigabitEthernet 1/0/1"
iso.3.6.1.2.1.2.2.1.2.49154 = STRING: "gigabitEthernet 1/0/2"
iso.3.6.1.2.1.2.2.1.2.49155 = STRING: "gigabitEthernet 1/0/3"
iso.3.6.1.2.1.2.2.1.2.49156 = STRING: "gigabitEthernet 1/0/4"
iso.3.6.1.2.1.2.2.1.2.49157 = STRING: "gigabitEthernet 1/0/5"
iso.3.6.1.2.1.2.2.1.2.49158 = STRING: "gigabitEthernet 1/0/6"
iso.3.6.1.2.1.2.2.1.2.49159 = STRING: "gigabitEthernet 1/0/7"
iso.3.6.1.2.1.2.2.1.2.49160 = STRING: "gigabitEthernet 1/0/8"
iso.3.6.1.2.1.2.2.1.2.49161 = STRING: "gigabitEthernet 1/0/9"
iso.3.6.1.2.1.2.2.1.2.49162 = STRING: "gigabitEthernet 1/0/10"
iso.3.6.1.2.1.2.2.1.3.1 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.100 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.120 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.140 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.200 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.210 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.220 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49153 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49154 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49155 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49156 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49157 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49158 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49159 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49160 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49161 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.49162 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.4.1 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.100 = INTEGER: 0
iso.3.6.1.2.1.2.2.1.4.120 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.140 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.200 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.210 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.220 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.49153 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49154 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49155 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49156 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49157 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49158 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49159 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49160 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49161 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.4.49162 = INTEGER: 1518
iso.3.6.1.2.1.2.2.1.5.1 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.100 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.120 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.140 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.200 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.210 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.220 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.49153 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.49154 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.49155 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.49156 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.49157 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.49158 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.49159 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.49160 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.49161 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.5.49162 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.6.1 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.100 = Hex-STRING: 00 00 00 00 00 00
iso.3.6.1.2.1.2.2.1.6.120 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.140 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.200 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.210 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.220 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49153 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49154 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49155 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49156 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49157 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49158 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49159 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49160 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49161 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.6.49162 = Hex-STRING: 48 22 54 8A 24 CA
iso.3.6.1.2.1.2.2.1.7.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.100 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.120 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.140 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.200 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.210 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.220 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49153 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49154 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49155 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49156 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49157 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49158 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49159 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49160 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49161 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.49162 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.100 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.120 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.140 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.200 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.210 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.220 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.49153 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.49154 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.49155 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.49156 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.49157 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.49158 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.49159 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.49160 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.49161 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.49162 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.9.1 = Timeticks: (5318) 0:00:53.18
iso.3.6.1.2.1.2.2.1.9.100 = Timeticks: (133803) 0:22:18.03
iso.3.6.1.2.1.2.2.1.9.120 = Timeticks: (5427) 0:00:54.27
iso.3.6.1.2.1.2.2.1.9.140 = Timeticks: (5536) 0:00:55.36
iso.3.6.1.2.1.2.2.1.9.200 = Timeticks: (5646) 0:00:56.46
iso.3.6.1.2.1.2.2.1.9.210 = Timeticks: (5760) 0:00:57.60
iso.3.6.1.2.1.2.2.1.9.220 = Timeticks: (5872) 0:00:58.72
iso.3.6.1.2.1.2.2.1.9.49153 = Timeticks: (5190) 0:00:51.90
iso.3.6.1.2.1.2.2.1.9.49154 = Timeticks: (1200408) 3:20:04.08
iso.3.6.1.2.1.2.2.1.9.49155 = Timeticks: (484903) 1:20:49.03
iso.3.6.1.2.1.2.2.1.9.49156 = Timeticks: (1031922) 2:51:59.22
iso.3.6.1.2.1.2.2.1.9.49157 = Timeticks: (150584) 0:25:05.84
iso.3.6.1.2.1.2.2.1.9.49158 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.9.49159 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.9.49160 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.9.49161 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.9.49162 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.10.1 = Counter32: 1076
iso.3.6.1.2.1.2.2.1.10.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.10.120 = Counter32: 5708917
iso.3.6.1.2.1.2.2.1.10.140 = Counter32: 19701182
iso.3.6.1.2.1.2.2.1.10.200 = Counter32: 4935818
iso.3.6.1.2.1.2.2.1.10.210 = Counter32: 4927204
iso.3.6.1.2.1.2.2.1.10.220 = Counter32: 4921668
iso.3.6.1.2.1.2.2.1.10.49153 = Counter32: 87406391
iso.3.6.1.2.1.2.2.1.10.49154 = Counter32: 6360406
iso.3.6.1.2.1.2.2.1.10.49155 = Counter32: 1344703
iso.3.6.1.2.1.2.2.1.10.49156 = Counter32: 63491
iso.3.6.1.2.1.2.2.1.10.49157 = Counter32: 101046
iso.3.6.1.2.1.2.2.1.10.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.10.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.10.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.10.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.10.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.49153 = Counter32: 34976
iso.3.6.1.2.1.2.2.1.11.49154 = Counter32: 12244
iso.3.6.1.2.1.2.2.1.11.49155 = Counter32: 6615
iso.3.6.1.2.1.2.2.1.11.49156 = Counter32: 724
iso.3.6.1.2.1.2.2.1.11.49157 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.49153 = Counter32: 1064822
iso.3.6.1.2.1.2.2.1.12.49154 = Counter32: 12987
iso.3.6.1.2.1.2.2.1.12.49155 = Counter32: 500
iso.3.6.1.2.1.2.2.1.12.49156 = Counter32: 81
iso.3.6.1.2.1.2.2.1.12.49157 = Counter32: 188
iso.3.6.1.2.1.2.2.1.12.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49153 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49154 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49155 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49156 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49157 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49153 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49154 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49155 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49156 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49157 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49153 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49154 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49155 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49156 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49157 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.1 = Counter32: 496164
iso.3.6.1.2.1.2.2.1.16.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.120 = Counter32: 335861
iso.3.6.1.2.1.2.2.1.16.140 = Counter32: 1815777
iso.3.6.1.2.1.2.2.1.16.200 = Counter32: 2489
iso.3.6.1.2.1.2.2.1.16.210 = Counter32: 3742
iso.3.6.1.2.1.2.2.1.16.220 = Counter32: 2377
iso.3.6.1.2.1.2.2.1.16.49153 = Counter32: 10447921
iso.3.6.1.2.1.2.2.1.16.49154 = Counter32: 55910494
iso.3.6.1.2.1.2.2.1.16.49155 = Counter32: 10327233
iso.3.6.1.2.1.2.2.1.16.49156 = Counter32: 6151092
iso.3.6.1.2.1.2.2.1.16.49157 = Counter32: 143176
iso.3.6.1.2.1.2.2.1.16.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.49153 = Counter32: 29825
iso.3.6.1.2.1.2.2.1.17.49154 = Counter32: 14586
iso.3.6.1.2.1.2.2.1.17.49155 = Counter32: 8878
iso.3.6.1.2.1.2.2.1.17.49156 = Counter32: 1875
iso.3.6.1.2.1.2.2.1.17.49157 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.49153 = Counter32: 13028
iso.3.6.1.2.1.2.2.1.18.49154 = Counter32: 757072
iso.3.6.1.2.1.2.2.1.18.49155 = Counter32: 42723
iso.3.6.1.2.1.2.2.1.18.49156 = Counter32: 65217
iso.3.6.1.2.1.2.2.1.18.49157 = Counter32: 548
iso.3.6.1.2.1.2.2.1.18.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49153 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49154 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49155 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49156 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49157 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.100 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.120 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.140 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.200 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.210 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.220 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49153 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49154 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49155 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49156 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49157 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49158 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49159 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49160 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49161 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.49162 = Counter32: 0
iso.3.6.1.2.1.2.2.1.21.1 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.100 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.120 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.140 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.200 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.210 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.220 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49153 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49154 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49155 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49156 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49157 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49158 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49159 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49160 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49161 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.21.49162 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.22.1 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.100 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.120 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.140 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.200 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.210 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.220 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49153 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49154 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49155 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49156 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49157 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49158 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49159 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49160 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49161 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.49162 = OID: ccitt.0
iso.3.6.1.2.1.4.1.0 = INTEGER: 1
iso.3.6.1.2.1.4.2.0 = INTEGER: 64
iso.3.6.1.2.1.4.3.0 = Counter32: 9183
iso.3.6.1.2.1.4.4.0 = Counter32: 0
iso.3.6.1.2.1.4.5.0 = Counter32: 0
iso.3.6.1.2.1.4.6.0 = Counter32: 0
iso.3.6.1.2.1.4.7.0 = Counter32: 0
iso.3.6.1.2.1.4.8.0 = Counter32: 0
iso.3.6.1.2.1.4.9.0 = Counter32: 9188
iso.3.6.1.2.1.4.10.0 = Counter32: 9330
iso.3.6.1.2.1.4.11.0 = Counter32: 0
iso.3.6.1.2.1.4.12.0 = Counter32: 0
iso.3.6.1.2.1.4.13.0 = INTEGER: 0
iso.3.6.1.2.1.4.14.0 = Counter32: 0
iso.3.6.1.2.1.4.15.0 = Counter32: 0
iso.3.6.1.2.1.4.16.0 = Counter32: 0
iso.3.6.1.2.1.4.17.0 = Counter32: 0
iso.3.6.1.2.1.4.18.0 = Counter32: 0
iso.3.6.1.2.1.4.19.0 = Counter32: 0
iso.3.6.1.2.1.4.20.1.1.10.10.120.4 = IpAddress: 10.10.120.4
iso.3.6.1.2.1.4.20.1.1.10.10.140.122 = IpAddress: 10.10.140.122
iso.3.6.1.2.1.4.20.1.1.10.10.200.50 = IpAddress: 10.10.200.50
iso.3.6.1.2.1.4.20.1.1.10.10.220.56 = IpAddress: 10.10.220.56
iso.3.6.1.2.1.4.20.1.1.192.168.132.25 = IpAddress: 192.168.132.25
iso.3.6.1.2.1.4.20.1.2.10.10.120.4 = INTEGER: 120
iso.3.6.1.2.1.4.20.1.2.10.10.140.122 = INTEGER: 140
iso.3.6.1.2.1.4.20.1.2.10.10.200.50 = INTEGER: 200
iso.3.6.1.2.1.4.20.1.2.10.10.220.56 = INTEGER: 220
iso.3.6.1.2.1.4.20.1.2.192.168.132.25 = INTEGER: 210
iso.3.6.1.2.1.4.20.1.3.10.10.120.4 = IpAddress: 255.255.254.0
iso.3.6.1.2.1.4.20.1.3.10.10.140.122 = IpAddress: 255.255.254.0
iso.3.6.1.2.1.4.20.1.3.10.10.200.50 = IpAddress: 255.255.254.0
iso.3.6.1.2.1.4.20.1.3.10.10.220.56 = IpAddress: 255.255.254.0
iso.3.6.1.2.1.4.20.1.3.192.168.132.25 = IpAddress: 255.255.254.0
iso.3.6.1.2.1.4.20.1.4.10.10.120.4 = INTEGER: 1
iso.3.6.1.2.1.4.20.1.4.10.10.140.122 = INTEGER: 1
iso.3.6.1.2.1.4.20.1.4.10.10.200.50 = INTEGER: 1
iso.3.6.1.2.1.4.20.1.4.10.10.220.56 = INTEGER: 1
iso.3.6.1.2.1.4.20.1.4.192.168.132.25 = INTEGER: 1
iso.3.6.1.2.1.4.20.1.5.10.10.120.4 = INTEGER: 65535
iso.3.6.1.2.1.4.20.1.5.10.10.140.122 = INTEGER: 65535
iso.3.6.1.2.1.4.20.1.5.10.10.200.50 = INTEGER: 65535
iso.3.6.1.2.1.4.20.1.5.10.10.220.56 = INTEGER: 65535
iso.3.6.1.2.1.4.20.1.5.192.168.132.25 = INTEGER: 65535
iso.3.6.1.2.1.4.22.1.1.140.10.10.140.7 = INTEGER: 140
iso.3.6.1.2.1.4.22.1.1.210.192.168.132.1 = INTEGER: 210
iso.3.6.1.2.1.4.22.1.1.140.10.10.140.16 = INTEGER: 140
Error: OID not increasing: iso.3.6.1.2.1.4.22.1.1.210.192.168.132.1
>= iso.3.6.1.2.1.4.22.1.1.140.10.10.140.16
Next bash into the docker container:
root@f1bf9f5c8cb9:/# snmpwalk -v 1 -c SNMPOmada 10.10.120.4
Created directory: /var/lib/snmp/cert_indexes
Timeout: No Response from 10.10.120.4
Waaaaaaait … so the Dockercontainer is not able to connect Interesting Pinging the Container works. Weird thing … Okay, then I have to find out why
The only different thing i would do is, inside the docker container i would work as the site user. But from network side it must also work as root.
