Hello, i wrote a plugin for getting the cpu_utilization of a switch, but sadly im getting back errors trying to test it on my checkmk-instance. Maybe you can help me fixing this.
Best regards,
Lukas
CMK version:
2.1.0p30
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
huawei_cpu_default_levels = (80.0, 95.0)
def inventory_huawei_cpu(info):
if info and info[0] != [None, None]:
print(info)
import pprint
pprint.pprint(info)
return [(None, 'huawei_cpu_default_levels')]
def check_huawei_cpu(item, params, info):
if info[0] == [None, None]:
return 3, 'No information about the CPU utilization available'
if info[0][1]:
util = float(info[0][1])
else:
util = float(info[0][0])
infotext = "%2.1f%% utilization in the last 5 minutes" % util
warn, crit = params
perfdata = [("util", util, warn, crit, 0, 100)]
if util >= crit:
return (2, infotext + " (critical at %d%%)" % crit, perfdata)
elif util >= warn:
return (1, infotext + " (warning at %d%%)" % warn, perfdata)
else:
return (0, infotext, perfdata)
check_info["huawei_cpu"] = {
"check_function": check_huawei_cpu,
"inventory_function": inventory_huawei_cpu,
"service_description": "CPU utilization",
"has_perfdata": True,
"group": "cpu_utilization",
"snmp_info": (".1.3.6.1.4.1.2011.6.3.33", ["1"]),
"snmp_scan_function": lambda oid: True,
**Output of “cmk -vp --debug huawei_switch_cpu_utilization”:**
huawei_cpu: failed to convert scan function: <lambda>
File "/omd/sites/monitor254/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 392, in _compute_detect_spec
return _ast_convert_dispatcher(expression_ast)
File "/omd/sites/monitor254/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 347, in _ast_convert_dispatcher
raise ValueError(ast.dump(arg))
ValueError: Constant(value=True)
The above exception was the direct cause of the following exception:
File "/omd/sites/monitor254/lib/python3/cmk/base/config.py", line 2122, in _extract_agent_and_snmp_sections
create_snmp_section_plugin_from_legacy(
File "/omd/sites/monitor254/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/__init__.py", line 246, in create_snmp_section_plugin_from_legacy
detect_spec = create_detect_spec(
File "/omd/sites/monitor254/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 416, in create_detect_spec
_compute_detect_spec(
File "/omd/sites/monitor254/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 395, in _compute_detect_spec
raise NotImplementedError(msg) from exc
NotImplementedError: huawei_cpu: failed to convert scan function: <lambda>
File "/omd/sites/monitor254/bin/cmk", line 79, in <module>
errors = config.load_all_agent_based_plugins(check_api.get_check_api_context)
File "/omd/sites/monitor254/lib/python3/cmk/base/config.py", line 1530, in load_all_agent_based_plugins
errors.extend(load_checks(get_check_api_context, filelist))
File "/omd/sites/monitor254/lib/python3/cmk/base/config.py", line 1682, in load_checks
return _extract_agent_and_snmp_sections(
File "/omd/sites/monitor254/lib/python3/cmk/base/config.py", line 2143, in _extract_agent_and_snmp_sections
raise MKGeneralException(exc) from exc
cmk.utils.exceptions.MKGeneralException: huawei_cpu: failed to convert scan function: <lambda>
