SNMP MIB Files - FS Switch Monitoring
Dear Community,
I would want to ask you if you had similar problem - I configured for monitoring via SNMP two switches - FS. Expect the checks, we would want to receive also SNMP Traps. Here the problem comes - I configured the host, added the community / password into EC’s settings (v2c) and uploaded the MIB files which are related with the version of the switches. There were 2 folders - for standard mibs and ‘private’ which are exactly for the FS switches. First I uploaded the ‘private’ zip file, but a lot of dependencies were missing. I found them into ‘standard’ folder and uploaded also them. The information which was presented into the view which I prepared was not translated by EC and it was shown as OIDs, but I also noticed that other Cisco hosts were ‘broken’ - in place of translated information, OIDs were presented. I deleted one by one the FS mib files and some from the standard which I uploaded earlier, but the problem still exist and the following errors appear inside the log file of EC.
Do you know how can I resolve those problems?
CMK version:
1.6.19
OS version:
CentOS7.9
2022-04-20 16:30:11,655 [30] [cmk.mkeventd.EventServer.snmp] Failed to translate OIDs, no modules loaded (see above)
2022-04-20 16:30:12,259 [30] [cmk.mkeventd.EventServer.snmp] Failed to translate OIDs, no modules loaded (see above)
2022-04-20 16:30:15,497 [30] [cmk.mkeventd.EventServer.snmp] Failed to translate OIDs, no modules loaded (see above)
2022-04-20 16:30:16,347 [40] [cmk.mkeventd.StatusServer] Error handling client : [Errno 104] Connection reset by peer
File “/omd/sites//[instance_name]/lib/python/cmk/ec/main.py”, line 3031, in serve
File “/omd/sites//[instance_name]/lib/python/cmk/ec/main.py”, line 3051, in handle_client
for query in Queries(self, client_socket, self._logger):
File “/omd/sites//[instance_name]/lib/python/cmk/ec/main.py”, line 2511, in next
data = self._socket.recv(4096)
error: [Errno 104] Connection reset by peer
2022-04-20 16:29:53,569 [20] [cmk.mkeventd.EventServer.snmp] adding SNMPv1 system: communityIndex=snmpv2-11
2022-04-20 16:29:53,603 [20] [cmk.mkeventd.EventServer.snmp] Exception while loading MIB modules. Proceeding without modules!
2022-04-20 16:29:53,603 [40] [cmk.mkeventd.EventServer.snmp] Exception: MIB module “/omd/sites/[instance_name]/lib/python/pysnmp/smi/mibs/INTERFACETOPN-MIB.pyc” load error: [‘Traceback (most recent call last):\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 325, in loadModule\n exec (modData, g)\n’, ’ File “/tmp/pip-build-La65vO/pysnmp-mibs/pysnmp_mibs/INTERFACETOPN-MIB.py”, line 12, in \n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 400, in importSymbols\n self.loadModules(modName, **userCtx)\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 362, in loadModules\n self.loadModule(modName, **userCtx)\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 330, in loadModule\n ‘MIB module \"%s\" load error: %s’ % (modPath, traceback.format_exception(*sys.exc_info()))\n’, ‘MibLoadError: MIB module “/omd/sites/[instance_name]/local/share/check_mk/compiled_mibs/RMON-MIB.pyc” load error: [‘Traceback (most recent call last):\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 325, in loadModule\n exec (modData, g)\n’, ’ File “/omd/sites/[instance_name]/local/share/check_mk/compiled_mibs/RMON-MIB.py”, line 11, in \n DisplayString, = mibBuilder.importSymbols(“RFC1158-MIB”, “DisplayString”)\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 407, in importSymbols\n \‘No symbol %s::%s at %s\’ % (modName, symName, self)\n’, ‘SmiError: No symbol RFC1158-MIB::DisplayString at <pysnmp.smi.builder.MibBuilder object at 0x7f8646926cd0>\n’]\n’]
File “/omd/sites/[instance_name]/lib/python/cmk/ec/snmp.py”, line 231, in _construct_resolver
builder.loadModules()
‘MIB module “%s” load error: %s’ % (modPath, traceback.format_exception(*sys.exc_info()))
MibLoadError: MIB module “/omd/sites/[instance_name]/lib/python/pysnmp/smi/mibs/INTERFACETOPN-MIB.pyc” load error: [‘Traceback (most recent call last):\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 325, in loadModule\n exec (modData, g)\n’, ’ File “/tmp/pip-build-La65vO/pysnmp-mibs/pysnmp_mibs/INTERFACETOPN-MIB.py”, line 12, in \n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 400, in importSymbols\n self.loadModules(modName, **userCtx)\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 362, in loadModules\n self.loadModule(modName, **userCtx)\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 330, in loadModule\n ‘MIB module \"%s\" load error: %s’ % (modPath, traceback.format_exception(*sys.exc_info()))\n’, ‘MibLoadError: MIB module “/omd/sites/[instance_name]/local/share/check_mk/compiled_mibs/RMON-MIB.pyc” load error: [‘Traceback (most recent call last):\n’, ’ File “/omd/sites[instance_name]/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 325, in loadModule\n exec (modData, g)\n’, ’ File “/omd/sites/[instance_name]/local/share/check_mk/compiled_mibs/RMON-MIB.py”, line 11, in \n DisplayString, = mibBuilder.importSymbols(“RFC1158-MIB”, “DisplayString”)\n’, ’ File “/omd/sites/[instance_name]/lib/python/pysnmp/smi/builder.py”, line 407, in importSymbols\n \‘No symbol %s::%s at %s\’ % (modName, symName, self)\n’, ‘SmiError: No symbol RFC1158-MIB::DisplayString at <pysnmp.smi.builder.MibBuilder object at 0x7f8646926cd0>\n’]\n’]
2022-04-20 16:29:53,609 [20] [cmk.mkeventd.EventServer] Compiled 51 active rules (ignoring 31 disabled rules)
Thank you in advance!
Best regards,
Elena
Sorry for opening this topic unnecessary. Some ‘standard’ files were left there and after removing them I started adding the mib files one by one. The FS-System files break the logic somehow. The case is still under investigation, but I successfully resolved the problematic lines from the log file.
Sorry for the inconvenience!
Happy holidays!
Hi @Elena.Dzhordzhilova , can you tell me where you found FS mibs?
I would like to monitor environment status (temperature,PSU/FAN, etc…)
thanks!
Matteo
