**CMK version: 2.2.0p8 ** **OS version: CentOS 7 **
I am unable to find the window in the CheckMK GUI where MIBs are uploaded to CheckMK. I’ve got ‘Translate SNMP traps using the available MIBs’ enabled with the ‘Add OID descriptions’ checked. Please help.
for the Event Console you can do that in Setup - Event Console - Event Console - SNMP MIBs - Add one or multiple MIBS…
I finally found it in CheckMK but there are a couple additional steps.
Setup - > Events - > Event Console Rule Packs
Select the ‘Event Console’ menu - > SNMP MIBs
This is where the golden egg is located. Thanks for taking the time to look at this Andre.
