Indeed that was strange, I’ve tried running the cmd but I have me a strange error message which was related to a unsupported plugin, cdp_inv , which I then removed.
Using cached OID .1.3.6.1.2.1.1.2.0: ‘.1.3.6.1.4.1.9.1.2694’
Using cached OID .1.3.6.1.2.1.1.1.0: ‘Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.9.3, RELEASE SOFTWARE (fc2’
SNMP scan found cisco_cpu_memory cisco_cpu_multiitem cisco_fan cisco_fru_module_status cisco_fru_powerusage cisco_hsrp cisco_mem cisco_power cisco_qos cisco_redundancy cisco_secure cisco_temp_sensor cisco_temperature hr_mem if if64 inv_cisco_vlans inv_if pse_poe rmon_stats snmp_extended_info snmp_info snmp_os snmp_uptime
Try aquire lock on /omd/sites/SITE/tmp/check_mk/snmp_scan_cache/SWEU-BO-1-1.IPADDR
Got lock on /omd/sites/SITE/tmp/check_mk/snmp_scan_cache/SWEU-BO-1-1.IPADDR
Releasing lock on /omd/sites/SITE/tmp/check_mk/snmp_scan_cache/SWEU-BO-1-1.IPADDR
Released lock on /omd/sites/SITE/tmp/check_mk/snmp_scan_cache/SWEU-BO-1-1.IPADDR
cisco_cpu_memory: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.109.1.1.1.1.2’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.109.1.1.1.1.12’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.109.1.1.1.1.13’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.109.1.1.1.1.14’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.2.1.47.1.1.1.1.7’
cisco_cpu_multiitem: Fetching data (SNMP walk cache is disabled)
Already fetched OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.2
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.109.1.1.1.1.8’
Already fetched OID: .1.3.6.1.2.1.47.1.1.1.1.7
cisco_fan: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.13.1.4.1.2’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.13.1.4.1.3’
cisco_fru_module_status: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.2.1.47.1.1.1.1.2’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.2.1.47.1.1.1.1.5’
Saving walk of .1.3.6.1.2.1.47.1.1.1.1.2 to walk cache /omd/sites/SITE/var/check_mk/snmp_cache/SWEU-BO-1-1/.1.3.6.1.2.1.47.1.1.1.1.2
Try aquire lock on /omd/sites/SITE/var/check_mk/snmp_cache/SWEU-BO-1-1/.1.3.6.1.2.1.47.1.1.1.1.2
Got lock on /omd/sites/SITE/var/check_mk/snmp_cache/SWEU-BO-1-1/.1.3.6.1.2.1.47.1.1.1.1.2
Releasing lock on /omd/sites/SITE/var/check_mk/snmp_cache/SWEU-BO-1-1/.1.3.6.1.2.1.47.1.1.1.1.2
Released lock on /omd/sites/SITE/var/check_mk/snmp_cache/SWEU-BO-1-1/.1.3.6.1.2.1.47.1.1.1.1.2
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.117.1.2.1.1.2’
cisco_fru_powerusage: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.117.1.1.1.1.2’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.117.1.1.4.1.1’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.117.1.1.4.1.2’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.117.1.1.4.1.3’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.117.1.1.4.1.4’
cisco_hsrp: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.106.1.2.1.1.11’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.106.1.2.1.1.13’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.106.1.2.1.1.14’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.106.1.2.1.1.15’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.106.1.2.1.1.16’
cisco_mem: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.48.1.1.1.2’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.48.1.1.1.5’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.48.1.1.1.6’
Running ‘snmpbulkwalk -Cr10 -v2c -c COMMUNITY -m “” -M “” -Cc -OQ -OU -On -Ot IPADDR .1.3.6.1.4.1.9.9.48.1.1.1.7’
ERROR: SNMP error: Timeout: No Response from IPADDR
[cpu_tracking] Stop [7f295e4a07c0 - Snapshot(process=posix.times_result(user=0.31000000000000005, system=0.24000000000000002, children_user=0.05, children_system=0.21, elapsed=7.389999999664724))]
Try aquire lock on /omd/sites/SITE/var/check_mk/crashes/base/86f2e4b4-983f-11eb-a8e1-0050569328f5/crash.info
Got lock on /omd/sites/SITE/var/check_mk/crashes/base/86f2e4b4-983f-11eb-a8e1-0050569328f5/crash.info
Releasing lock on /omd/sites/SITE/var/check_mk/crashes/base/86f2e4b4-983f-11eb-a8e1-0050569328f5/crash.info
Released lock on /omd/sites/SITE/var/check_mk/crashes/base/86f2e4b4-983f-11eb-a8e1-0050569328f5/crash.info
File “/omd/sites/SITE/lib/python3/cmk/fetchers/snmp.py”, line 328, in _fetch_from_io
_from, until, _section = persisted_sections[section_name]
File “/omd/sites/SITE/lib/python3/cmk/fetchers/cache.py”, line 42, in getitem
return self._store.getitem(key)
KeyError: SectionName(‘cisco_mem’)
File “/omd/sites/SITE/bin/cmk”, line 92, in
File “/omd/sites/SITE/lib/python3/cmk/base/modes/init.py”, line 69, in call
return handler(*handler_args)
File “/omd/sites/SITE/lib/python3/cmk/base/modes/check_mk.py”, line 1531, in mode_discover
discovery.do_discovery(
File “/omd/sites/SITE/lib/python3/cmk/base/discovery.py”, line 370, in do_discovery
fetcher_messages=list(
File “/omd/sites/SITE/lib/python3/cmk/base/checkers/_checkers.py”, line 246, in fetch_all
raw_data = source.fetch()
File “/omd/sites/SITE/lib/python3/cmk/base/checkers/_abstract.py”, line 163, in fetch
return fetcher.fetch(self.mode)
File “/omd/sites/SITE/lib/python3/cmk/fetchers/_base.py”, line 221, in fetch
return result.OK(self._fetch(mode))
File “/omd/sites/SITE/lib/python3/cmk/fetchers/_base.py”, line 250, in _fetch
raw_data = self._fetch_from_io(mode)
File “/omd/sites/SITE/lib/python3/cmk/fetchers/snmp.py”, line 333, in _fetch_from_io
section = [
File “/omd/sites/SITE/lib/python3/cmk/fetchers/snmp.py”, line 334, in
snmp_table.get_snmp_table(
File “/omd/sites/SITE/lib/python3/cmk/snmplib/snmp_table.py”, line 55, in get_snmp_table
table_data = _get_snmp_table(
File “/omd/sites/SITE/lib/python3/cmk/snmplib/snmp_table.py”, line 99, in _get_snmp_table
rowinfo = _get_snmpwalk(
File “/omd/sites/SITE/lib/python3/cmk/snmplib/snmp_table.py”, line 205, in _get_snmpwalk
rowinfo = _perform_snmpwalk(section_name, base, fetchoid, backend=backend)
File “/omd/sites/SITE/lib/python3/cmk/snmplib/snmp_table.py”, line 221, in _perform_snmpwalk
rows = backend.walk(
File “/omd/sites/SITE/lib/python3/cmk/fetchers/snmp_backend/classic.py”, line 137, in walk
raise MKSNMPError(“SNMP Error on %s: %s (Exit-Code: %d)” %
cmk.utils.exceptions.MKSNMPError: SNMP Error on IPADDR: Timeout: No Response from IPADDR (Exit-Code: 1)
