CMK version:2.0.0p27 (CEE)
OS version:Debian GNU/Linux 9
Error message: Can’t see CPU utilization , mem, psu and other things when monitoring my huawei stuff. Affected machines are CE6870-48S6CQ-EI and NE40E-F1A-14H24Q
**Output of “cmk --debug -vvn hostname”:
Checkmk version 2.0.0p27
Trying to acquire lock on /omd/sites/tuke/var/check_mk/license_usage/next_run
Got lock on /omd/sites/tuke/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/tuke/var/check_mk/license_usage/history.json
Got lock on /omd/sites/tuke/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/tuke/var/check_mk/license_usage/history.json
Released lock on /omd/sites/tuke/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/tuke/var/check_mk/license_usage/next_run
Released lock on /omd/sites/tuke/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/tuke/var/check_mk/autochecks/DIST-TUKE.mk
+ FETCHING DATA
[cpu_tracking] Start [7f80b59f0d30]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/tuke/tmp/check_mk/data_source_cache/snmp/DIST-TUKE'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 47 sec, allowed is 0 sec)
No persisted sections loaded
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v2c -c sanet-2 -m "" -M "" -On -OQ -Oe -Ot 193.87.100.2 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Huawei Versatile Routing Platform Software]
b'Huawei Versatile Routing Platform Softwar'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v2c -c sanet-2 -m "" -M "" -On -OQ -Oe -Ot 193.87.100.2 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.2011.2.239.32]
b'.1.3.6.1.4.1.2011.2.239.32'
Using cached OID .1.3.6.1.2.1.1.1.0: 'Huawei Versatile Routing Platform Softwar'
SNMP scan found snmp_uptime
Trying to acquire lock on /omd/sites/tuke/tmp/check_mk/snmp_scan_cache/DIST-TUKE.193.87.100.2
Got lock on /omd/sites/tuke/tmp/check_mk/snmp_scan_cache/DIST-TUKE.193.87.100.2
Releasing lock on /omd/sites/tuke/tmp/check_mk/snmp_scan_cache/DIST-TUKE.193.87.100.2
Released lock on /omd/sites/tuke/tmp/check_mk/snmp_scan_cache/DIST-TUKE.193.87.100.2
huawei_entity_optical: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.47.1.1.1.1.7'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.4.1.2011.5.25.31.1.1.3.1.5'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.4.1.2011.5.25.31.1.1.3.1.7'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.4.1.2011.5.25.31.1.1.3.1.8'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.4.1.2011.5.25.31.1.1.3.1.9'
huawei_switch_fan: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.4.1.2011.5.25.31.1.1.10.1.5'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.4.1.2011.5.25.31.1.1.10.1.6'
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.3'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.5'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.8'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.6'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.7'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.8'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.9'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.13'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.14'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.10'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.11'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.12'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.13'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.19'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.20'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.21'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.2.2.1.6'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.31.1.1.1.15'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.1.1'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.1.4'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.1.5'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.1.6'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.1.3'
Running 'snmpwalk -v2c -c sanet-2 -m "" -M "" -Cc -OQ -OU -On -Ot 193.87.100.2 .1.3.6.1.2.1.25.1.1'
Write data to cache file /omd/sites/tuke/tmp/check_mk/data_source_cache/snmp/checking/DIST-TUKE
Trying to acquire lock on /omd/sites/tuke/tmp/check_mk/data_source_cache/snmp/checking/DIST-TUKE
Got lock on /omd/sites/tuke/tmp/check_mk/data_source_cache/snmp/checking/DIST-TUKE
Releasing lock on /omd/sites/tuke/tmp/check_mk/data_source_cache/snmp/checking/DIST-TUKE
Released lock on /omd/sites/tuke/tmp/check_mk/data_source_cache/snmp/checking/DIST-TUKE
[cpu_tracking] Stop [7f80b59f0d30 - Snapshot(process=posix.times_result(user=0.16000000000000014, system=0.18, children_user=0.13, children_system=0.22, elapsed=15.439999997615814))]
[cpu_tracking] Start [7f80b5c18d60]
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/tuke/tmp/check_mk/data_source_cache/piggyback/DIST-TUKE'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
No piggyback files for 'DIST-TUKE'. Skip processing.
No piggyback files for '193.87.100.2'. Skip processing.
[cpu_tracking] Stop [7f80b5c18d60 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f80b59f0dc0]
+ PARSE FETCHER RESULTS
-> Add sections: ['huawei_entity_optical', 'huawei_switch_fan', 'if64', 'snmp_info', 'snmp_uptime']
-> Add sections: []
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/tuke/tmp/check_mk/counters/DIST-TUKE
Got lock on /omd/sites/tuke/tmp/check_mk/counters/DIST-TUKE
Releasing lock on /omd/sites/tuke/tmp/check_mk/counters/DIST-TUKE
Released lock on /omd/sites/tuke/tmp/check_mk/counters/DIST-TUKE
DOM 10GE1/0/10 RX Signal power: -14.35 dBm, TX Signal power: -6.15 dBm, RX Deviation: 1.11 dBm, TX Deviation: 0.07 dBm
DOM 10GE1/0/11 RX Signal power: -12.16 dBm, TX Signal power: -6.19 dBm, RX Deviation: -0.10 dBm, TX Deviation: 0.00 dBm
DOM 10GE1/0/12 RX Signal power: -17.09 dBm, TX Signal power: -5.99 dBm, RX Deviation: 0.68 dBm, TX Deviation: -0.04 dBm
DOM 10GE1/0/13 RX Signal power: -13.89 dBm, TX Signal power: -6.02 dBm, RX Deviation: -0.17 dBm, TX Deviation: 0.03 dBm
DOM 10GE1/0/14 RX Signal power: -9.89 dBm, TX Signal power: -5.88 dBm, RX Deviation: -0.03 dBm, TX Deviation: -0.06 dBm
DOM 10GE1/0/15 RX Signal power: -8.06 dBm, TX Signal power: -5.90 dBm, RX Deviation: 3.90 dBm, TX Deviation: -0.01 dBm
DOM 10GE1/0/16 RX Signal power: -6.92 dBm, TX Signal power: -6.46 dBm, RX Deviation: -0.25 dBm, TX Deviation: 0.06 dBm
DOM 10GE1/0/17 RX Signal power: -10.72 dBm, TX Signal power: -5.97 dBm, RX Deviation: 1.98 dBm, TX Deviation: 0.06 dBm
DOM 10GE1/0/18 RX Signal power: -8.38 dBm, TX Signal power: -5.98 dBm, RX Deviation: -0.02 dBm, TX Deviation: -0.03 dBm
DOM 10GE1/0/19 RX Signal power: -14.42 dBm, TX Signal power: -5.86 dBm, RX Deviation: -0.80 dBm, TX Deviation: -0.07 dBm
DOM 10GE1/0/2 RX Signal power: -11.28 dBm, TX Signal power: -5.98 dBm, RX Deviation: 0.76 dBm, TX Deviation: -0.04 dBm
DOM 10GE1/0/20 RX Signal power: -10.55 dBm, TX Signal power: -6.95 dBm, RX Deviation: -0.07 dBm, TX Deviation: -0.01 dBm
DOM 10GE1/0/21 RX Signal power: -9.19 dBm, TX Signal power: -5.59 dBm, RX Deviation: 0.00 dBm, TX Deviation: 0.11 dBm
DOM 10GE1/0/22 RX Signal power: -16.98 dBm, TX Signal power: -5.99 dBm, RX Deviation: -0.31 dBm, TX Deviation: 0.00 dBm
DOM 10GE1/0/23 RX Signal power: -14.78 dBm, TX Signal power: -5.07 dBm, RX Deviation: 0.03 dBm, TX Deviation: 0.08 dBm
DOM 10GE1/0/3 RX Signal power: -7.05 dBm, TX Signal power: -6.23 dBm, RX Deviation: 0.00 dBm, TX Deviation: 0.09 dBm
DOM 10GE1/0/4 RX Signal power: -15.93 dBm, TX Signal power: -4.08 dBm, RX Deviation: -9.59 dBm, TX Deviation: 0.17 dBm
DOM 10GE1/0/7 RX Signal power: -9.17 dBm, TX Signal power: -5.55 dBm, RX Deviation: 0.14 dBm, TX Deviation: 0.13 dBm
DOM 10GE1/0/8 RX Signal power: -8.68 dBm, TX Signal power: -5.53 dBm, RX Deviation: 0.84 dBm, TX Deviation: -0.05 dBm
DOM 10GE1/0/9 RX Signal power: -15.11 dBm, TX Signal power: -6.94 dBm, RX Deviation: 0.41 dBm, TX Deviation: -0.01 dBm
Fan 1/1 40.0%
Fan 1/2 40.0%
Interface 100GE1/0/6 [Uplink NE40], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 40 GBit/s, In: 46.1 MB/s (0.92%), Out: 6.51 MB/s (0.13%)
Interface 10GE1/0/1 [CNL,GP,CSIRT,sanet.tuke.sk], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 289 kB/s (0.23%), Out: 2.63 MB/s (2.11%)
Interface 10GE1/0/10 [ZSKezmarska30-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 69.7 kB/s (0.06%), Out: 1.68 MB/s (1.34%)
Interface 10GE1/0/11 [ZSSlobody-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 23.6 kB/s (0.02%), Out: 104 kB/s (0.08%)
Interface 10GE1/0/12 [Gymnazium Trebisovska-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 547 kB/s (0.44%), Out: 3.93 MB/s (3.15%)
Interface 10GE1/0/13 [CVC-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 187 kB/s (0.15%), Out: 1.62 MB/s (1.30%)
Interface 10GE1/0/14 [SD SPSaOA-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 297 kB/s (0.24%), Out: 8.58 MB/s (6.87%)
Interface 10GE1/0/15 [Gymnazium Park Mladeze-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 304 kB/s (0.24%), Out: 1.53 MB/s (1.22%)
Interface 10GE1/0/16 [OAWatsonova-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 654 kB/s (0.52%), Out: 2.03 MB/s (1.63%)
Interface 10GE1/0/17 [Gymnazium sv.E.Steinovej-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 169 kB/s (0.13%), Out: 368 kB/s (0.29%)
Interface 10GE1/0/18 [SSOS-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 26.5 kB/s (0.02%), Out: 332 kB/s (0.27%)
Interface 10GE1/0/19 [SSKM-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 134 kB/s (0.11%), Out: 2.86 MB/s (2.29%)
Interface 10GE1/0/2 [SSUSfilmova-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 247 kB/s (0.20%), Out: 4.65 MB/s (3.72%)
Interface 10GE1/0/20 [ZSJanigova-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 35.5 kB/s (0.03%), Out: 652 kB/s (0.52%)
Interface 10GE1/0/21 [SZSSlobody-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 304 kB/s (0.24%), Out: 505 kB/s (0.40%)
Interface 10GE1/0/22 [ZSKrosnianska2-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 113 kB/s (0.09%), Out: 483 kB/s (0.39%)
Interface 10GE1/0/23 [SIC-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 29.5 kB/s (0.02%), Out: 168 kB/s (0.13%)
Interface 10GE1/0/24 [VUC Kosice], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 100 MBit/s, In: 552 kB/s (4.41%), Out: 1.64 MB/s (13.14%)
Interface 10GE1/0/26 [Elfa], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 78.6 kB/s (0.06%), Out: 1.95 MB/s (1.56%)
Interface 10GE1/0/27 [CheckPoint-MGMT], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 5.31 kB/s (<0.01%), Out: 6.43 kB/s (<0.01%)
Interface 10GE1/0/28 [Manazment-pripojenie SIX-KE-L2], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 2.58 kB/s (<0.01%), Out: 3.77 kB/s (<0.01%)
Interface 10GE1/0/3 [Gymnazium TA-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 162 kB/s (0.13%), Out: 1.22 MB/s (0.98%)
Interface 10GE1/0/4 [US-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 805 kB/s (0.64%), Out: 3.44 MB/s (2.75%)
Interface 10GE1/0/40 [UVT-Datacentrum], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 842 kB/s (0.67%), Out: 32.1 kB/s (0.03%)
Interface 10GE1/0/41 [UVT-Datacentrum], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 144 B/s (<0.01%), Out: 227 B/s (<0.01%)
Interface 10GE1/0/42 [UVT-Datacentrum], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 1.02 kB/s (<0.01%), Out: 1.56 kB/s (<0.01%)
Interface 10GE1/0/43 [UVT-Datacentrum], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 257 B/s (<0.01%), Out: 529 B/s (<0.01%)
Interface 10GE1/0/6 [Premonstratske gymnazium-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 70.6 kB/s (0.06%), Out: 906 kB/s (0.72%)
Interface 10GE1/0/7 [ZSTrebisovska-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 9.95 kB/s (<0.01%), Out: 207 kB/s (0.17%)
Interface 10GE1/0/8 [SPSEKE-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 331 kB/s (0.26%), Out: 3.66 MB/s (2.92%)
Interface 10GE1/0/9 [ZSKezmarska28-SANET], (up), MAC: 80:D4:A5:8F:7F:E1, Speed: 1 GBit/s, In: 308 kB/s (0.25%), Out: 1.70 MB/s (1.36%)
SNMP Info Huawei Versatile Routing Platform Software VRP (R) software, Version 8.220 (CE6870EI V200R022C00SPC500) Copyright (C) 2012-2022 Huawei Technologies Co., Ltd. Huawei CE6870-48S6CQ-EI, DIST-TUKE, Kosice, TU Kosice
Temperature 10GE1/0/10 28.0 °C
Temperature 10GE1/0/11 44.0 °C
Temperature 10GE1/0/12 26.0 °C
Temperature 10GE1/0/13 41.0 °C
Temperature 10GE1/0/14 35.0 °C
Temperature 10GE1/0/15 34.0 °C
Temperature 10GE1/0/16 24.0 °C
Temperature 10GE1/0/17 32.0 °C
Temperature 10GE1/0/18 33.0 °C
Temperature 10GE1/0/19 34.0 °C
Temperature 10GE1/0/2 38.0 °C
Temperature 10GE1/0/20 44.0 °C
Temperature 10GE1/0/21 27.0 °C
Temperature 10GE1/0/22 34.0 °C
Temperature 10GE1/0/23 24.0 °C
Temperature 10GE1/0/3 30.0 °C
Temperature 10GE1/0/4 25.0 °C
Temperature 10GE1/0/7 24.0 °C
Temperature 10GE1/0/8 33.0 °C
Temperature 10GE1/0/9 44.0 °C
Uptime Up since Nov 23 2023 08:59:51, Uptime: 19 days 5 hours
[cpu_tracking] Stop [7f80b59f0dc0 - Snapshot(process=posix.times_result(user=0.22999999999999998, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.25999999791383743))]
[snmp] Success, execution time 15.7 sec | execution_time=15.700 user_time=0.400 system_time=0.190 children_user_time=0.130 children_system_time=0.220 cmk_time_snmp=14.750 cmk_time_agent=0.000
